Contribution au pronostic d'une pile à combustible de type PEMFC - approche par filtrage particulaire. - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2015
Contribution to prognostics of fuel cells of PEMFC type - approach based on particle filtering.
The development of new energy converters, more efficient and environment friendly, such as fuel cells, tends to accelerate. Nevertheless, their large scale diffusion supposes some guaranties in terms of safety and availability. A possible solution to do so is to develop Prognostics and Health Management (PHM) on these systems, in order to monitor and anticipate the failures, and to recommend the necessary actions to extend their lifetime. In this spirit, this thesis deals with the proposal of a prognostics approach based on particle filtering dedicated to PEMFCs. The reasoning focuses first on setting a formalization of the working framework and the expectations. This is pursued by the development of a physic-based modelling enabling a state of health estimation and its evolution in time. The state estimation is made thanks to particle filtering. Different variants of filters are considered on the basis of the literature and new proposals adapted to PHM are proposed and compared to existing ones. State of health estimates given by the filter are used to predict the future state of the system and its remaining useful life. All the proposals are validated on four datasets from PEMFC following different mission profiles. The results show good performances for predictions and remaining useful life estimates before failure.
Le développement de nouveaux convertisseurs d’énergie, plus efficients et plus respectueux de l’environnement, tels que les piles à combustibles, tend à s’accélérer. Leur diffusion à grande échelle suppose cependant des garanties en termes de sécurité et de disponibilité. Une solution possible pour ce faire est de développer des solutions de Prognostics and Health Management (PHM) de ces systèmes, afin de mieux les surveiller, anticiper les défaillances et recommander les actions nécessaires à l’allongement de leur durée de vie. Dans cet esprit, cette thèse porte sur la proposition d’une approche de pronostic dédiée aux piles à combustibles de types PEMFC à l’aide de filtrage particulaire. Le raisonnement s’attache tout d’abord à mettre en place une formalisation du cadre de travail ainsi que des exigences de mise en. Ceci se poursuit par le développement d’un modèle basé sur la physique permettant une estimation d’état de santé et de son évolution temporelle. L’estimation d’état est réalisée grâce à du filtrage particulaire. Différentes variantes de filtres sont considérées sur la base d’une de la littérature et de nouvelles propositions adaptées au PHM sont formulées et comparées à celles existantes. Les estimations d’état de santé fournies par le processus de filtrage sont utilisées pour réaliser des prédictions de l’état de santé futur du système, puis de sa durée de vie résiduelle. L’ensemble des propositions est validé sur 4 jeux de données obtenus sur des PEMFC suivant des profils de mission variés. Les résultats montrent de bonnes performances de prédictions et d’estimations de durée de vie résiduelle avant défaillance.
THESE Marine JOUIN 15 01 2016.pdf (8.63 Mo) Télécharger le fichier
tel-01264824 , version 1 (29-01-2016)
  • HAL Id : tel-01264824 , version 1
Marine Jouin. Contribution au pronostic d'une pile à combustible de type PEMFC - approche par filtrage particulaire.. Sciences de l'ingénieur [physics]. Université Bourgone Franche-Comté, 2015. Français. ⟨NNT : ⟩. ⟨tel-01264824⟩
193 Consultations
470 Téléchargements
