Creative Adaptation through Learning - Inria - Institut national de recherche en sciences et technologies du numérique Access content directly
Theses Year : 2015
Adaptation Créative par Apprentissage
Robots have transformed many industries, most notably manufacturing, and have the power to deliver tremendous benefits to society, for example in search and rescue, disaster response, health care, and transportation. They are also invaluable tools for scientific exploration of distant planets or deep oceans. A major obstacle to their widespread adoption in more complex environments and outside of factories is their fragility. While animals can quickly adapt to injuries, current robots cannot “think outside the box” to find a compensatory behavior when they are damaged: they are limited to their pre-specified self-sensing abilities, which can diagnose only anticipated failure modes and strongly increase the overall complexity of the robot. In this thesis, we propose a different approach that considers having robots learn appropriate behaviors in response to damage. However, current learning techniques are slow even with small, constrained search spaces. To allow fast and creative adaptation, we combine the creativity of evolutionary algorithms with the learning speed of policy search algorithms through three contributions: the behavioral repertoires, the damage recovery using these repertoires and the transfer of knowledge across tasks. Globally, this work aims to provide the algorithmic foundations that will allow physical robots to be more robust, effective and autonomous.
Les robots ont profondément transformé l’industrie manufacturière et sont susceptibles de délivrer de grands bénéfices pour la société, par exemple en intervenant sur des lieux de catastrophes naturelles, lors de secours à la personne ou dans le cadre de la santé et des transports. Ce sont aussi des outils précieux pour la recherche scientifique, comme pour l’exploration des planètes ou des fonds marins. L’un des obstacles majeurs à leur utilisation en dehors des environnements parfaitement contrôlés des usines ou des laboratoires, est leur fragilité. Alors que les animaux peuvent rapidement s’adapter à des blessures, les robots actuels ont des difficultés à faire preuve de créativité lorsqu’ils doivent surmonter un problème inattendu: ils sont limités aux capteurs qu’ils embarquent et ne peuvent diagnostiquer que les situations qui ont été anticipées par leur concepteurs. Dans cette thèse, nous proposons une approche différente qui consiste à laisser le robot apprendre de lui-même un comportement palliant la panne. Cependant, les méthodes actuelles d’apprentissage sont lentes même lorsque l’espace de recherche est petit et contraint. Pour surmonter cette limitation et permettre une adaptation rapide et créative, nous combinons la créativité des algorithmes évolutionnistes avec la rapidité des algorithmes de recherche de politique à travers trois contributions : les répertoires comportementaux, l’adaptation aux dommages et le transfert de connaissance entre plusieurs tâches. D’une manière générale, ces travaux visent à apporter les fondations algorithmiques permettant aux robots physiques d’être plus robustes, performants et autonomes.
cully_phd_small.pdf (14.98 Mo) Télécharger le fichier
Dates and versions
tel-01265957 , version 1 (01-02-2016)
tel-01265957 , version 2 (23-09-2016)
Identifiers
  • HAL Id : tel-01265957 , version 2
Cite
Antoine Cully. Creative Adaptation through Learning. Artificial Intelligence [cs.AI]. Université Pierre et Marie Curie - Paris VI, 2015. English. ⟨NNT : 2015PA066664⟩. ⟨tel-01265957v2⟩
761 View
1014 Download
Share
