Mathematical modeling of the hormonal regulation of food intake and body weight - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2016
Modélisation mathématique de la régulation hormonale de la prise alimentaire et de la prise de poids
The regulation of food intake and energy expenditure usually limits important loss or gain of body weight. Hormones (leptin, ghrelin, insulin) and nutrients (glucose, triglycerides) are among the main regulators of food intake. Leptin is also involved in leptin resistance, often associated with obesity and characterized by a reduced efficacy to regulate food intake. Mathematical models describing the dynamics of body weight have been used to assist clinical weight loss interventions or to study an experimentally inaccessible phenomenon, such as starvation experiments in humans. Modeling of the effect of hormones on body weight has however been largely ignored. In this thesis, we first consider a model of body weight regulation by hormones in rats, made of nonlinear differential equations. It describes the dynamics of food intake, body weight and energy expenditure, regulated by leptin, ghrelin and glucose. It is able to reproduce and predict the evolution of body weight and food intake in rats submitted to different patterns of caloric restriction, showing the importance of the adaptation of energy expenditure. Second, we introduce the first model of leptin resistance development, based on the regulation of food intake by leptin and leptin receptors. We show that healthy individuals may become leptin resistant and obese due to perturbations in food intake or leptin concentration. Finally, modifications of these models are presented, characterized by simplified yet realistic body weight dynamics. The models prove able to fit the previous, as well as new sets of experimental data and allow to build a complete model combining both previous models regulatory mechanisms.
Réguler la prise alimentaire et la dépense énergétique permet en général de limiter d'importants changements de poids corporel. Hormones (leptine, ghréline, insuline) et nutriments sont impliqués dans ces régulations. La résistance à la leptine, souvent associée à l'obésité, limite la régulation de la prise alimentaire. La modélisation mathématique de la dynamique du poids contribue en particulier à une meilleure compréhension des mécanismes de régulation (notamment chez l’humain). Or les régulations hormonales sont largement ignorées dans les modèles existants. Dans cette thèse, nous considérons un modèle de régulation hormonale du poids appliqué aux rats, composé d'équations différentielles non-linéaires. Il décrit la dynamique de la prise alimentaire, du poids et de la dépense énergétique, régulés par la leptine, la ghréline et le glucose. Il reproduit et prédit l'évolution du poids et de la prise alimentaire chez des rats soumis à différents régimes hypocaloriques, et met en évidence l'adaptation de la dépense énergétique. Nous introduisons ensuite le premier modèle décrivant le développement de la résistance à la leptine, prenant en compte la régulation de la prise alimentaire par la leptine et ses récepteurs. Nous montrons que des perturbations de la prise alimentaire, ou de la concentration en leptine, peuvent rendre un individu sain résistant à la leptine et obèse. Enfin, nous présentons une simplification réaliste de la dynamique du poids dans ces modèles, permettant de construire un nouveau modèle combinant les deux modèles précédents.
these-jacquier.pdf (18.67 Mo) Télécharger le fichier
tel-01273347 , version 1 (12-02-2016)
tel-01273347 , version 2 (09-09-2016)
  • HAL Id : tel-01273347 , version 1
Marine Jacquier. Mathematical modeling of the hormonal regulation of food intake and body weight: Applications to caloric restriction and leptin resistance. Mathematics [math]. Université Claude Bernard Lyon 1, 2016. English. ⟨NNT : ⟩. ⟨tel-01273347v1⟩
807 Consultations
1233 Téléchargements
