Recours aux soins de santé primaires des personnes en situation de handicap : analyses économiques à partir des données de l’enquête Handicap-Santé - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2016
Primary Health Care Use Among People With Disabilities : Economic Analysis From The Health And Disability Survey Data
Disability is multifactorial. All its components are potential sources of barriers and disadvantages. The originality of this thesis is to take into account the complexity of disability definition to analyze the use of primary health care. The ultimate goal of primary health care is better health for all, reducing exclusion and social inequalities in access to the health care system. We approach disability in different ways, ending with a model that includes the three dimensions of a “disability situation” (functional dimension, environmental dimension and social participation). First we analyze the functional dimension considering people with disabilities as physically limited. Then, we investigate the environmental dimension through analysis among adults living in institutions. Finally, we adopt a global vision of disability that integrates all the dimensions simultaneously through the measures of latent capabilities. The estimated model approximates a fundamental inter-individual comparability and reveals all things being equal, the levels on which to act to overcome inequalities. The analyses suggest that favorable environment, societal and/or socioeconomic could offset the negative impact of the limitations and cognitive and physical restrictions. We conclude on several possible waysto improve the use of primary care: acting on the environmental dimension and acting on social participation.
Le handicap est multifactoriel. Toutes ses composantes sont potentiellement sources d’obstacles et de désavantages. L’originalité de cette thèse est de tenir compte de la complexité de définition du handicap dans l’analyse du recours aux soins de santé primaires. L’objectif ultime des soins de santé primaires est une meilleure santé pour tous, passant par la réduction des exclusions et des inégalités sociales d’accès au système santé. Nous appréhendons le handicap de différentes manières jusqu’à intégrer les trois dimensions d’« une situation de handicap » (dimension fonctionnelle, dimension environnementale, et participation sociale) dans un même modèle explicatif. D’abord, nous analysons la dimension fonctionnelle en considérant les personnes handicapées comme physiquement limitées. Puis, nous investiguons la dimension environnementale par une étude chez les adultes vivant en institution. Enfin, nous adoptons une vision globale du handicap en intégrant simultanément toutes les dimensions par la mesure de capabilités latentes. Le modèle estimé s’approche d’une comparabilité inter-individus révélant, toutes choses égales par ailleurs, les niveaux sur lesquels agir pour pallier les inégalités. Les analyses suggèrent qu’un environnement favorable, sociétal et/ou socioéconomique, pourrait compenser les effets négatifs des limitations et des restrictions cognitives et physiques. Nous concluons sur plusieurs voies possibles afin d’améliorer le recours aux soins primaires : agir sur la dimension environnementale et sur la participation sociale.
74062_BUSSIERE_2016_diffusion.pdf (3.23 Mo) Télécharger le fichier
tel-01320990 , version 1 (24-05-2016)
  • HAL Id : tel-01320990 , version 1
Clémence Bussière. Recours aux soins de santé primaires des personnes en situation de handicap : analyses économiques à partir des données de l’enquête Handicap-Santé. Santé publique et épidémiologie. Université Paris Saclay (COmUE), 2016. Français. ⟨NNT : 2016SACLS049⟩. ⟨tel-01320990⟩
1322 Consultations
2575 Téléchargements
