Le théorème d’Ax-Lindemann mixte et ses applications à la conjecture de Zilber-Pink - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2014
The mixed Ax-Lindemann theorem and its applications to the Zilber-Pink conjecture
The Zilber-Pink conjecture is a diophantine conjecture concerning unlikely intersections in mixed Shimura varieties. It is a common generalization of the André-Oort conjecture and the Mordell-Lang conjecture. This dissertation is aimed to study the Zilber-Pink conjecture. More concretely, we will study the André-Oort conjecture, which predicts that a subvariety of a mixed Shimura variety having dense intersection with the set of special points is special, and the André-Pink-Zannier conjecture which predicts that a subvariety of a mixed Shimura variety having dense intersection with a generalized Hecke orbit is weakly special. The latter conjecture generalizes the Mordell-Lang conjecture as explained by Pink.In the Pila-Zannier method, a key point to study the Zilber-Pink conjec- ture is to prove the Ax-Lindemann theorem, which is a generalization of the functional analogue of the classical Lindemann-Weierstrass theorem. One of the main results of this dissertation is to prove the Ax-Lindemann theorem in its most general form, i.e. the mixed Ax-Lindemann theorem. This generalizes results of Pila, Pila-Tsimerman, Ullmo-Yafaev and Klingler-Ullmo-Yafaev concerning the Ax-Lindemann theorem for pure Shimura varieties.Another main result of this dissertation is to prove the André-Oort conjecture for a large class of mixed Shimura varieties: unconditionally for any mixed Shimura variety whose pure part is a subvariety of AN6 (e.g. products of universal families of abelian varieties of dimension 6 and the Poincaré bundle over A6) and under GRH for all mixed Shimura varieties of abelian type. This generalizes existing theorems of Klinger-Ullmo-Yafaev, Pila, Pila-Tsimerman and Ullmo concerning pure Shimura varieties.As for the André-Pink-Zannier conjecture, we prove several cases when the ambient mixed Shimura variety is the universal family of abelian varieties. First we prove the overlap of André-Oort and André-Pink-Zannier, i.e. we study the generalized Hecke orbit of a special point. This generalizes results of Edixhoven-Yafaev and Klingler-Ullmo-Yafaev for Ag. Secondly we prove the conjecture in the following case: a subvariety of an abelian scheme over a curve is weakly special if its intersection with the generalized Hecke orbit of a torsion point of a non CM fiber is Zariski dense. Finally for the generalized Hecke orbit of an arbitrary algebraic point, we prove the conjecture for curves. These generalize existing results of Habegger-Pila and Orr for Ag.In all these proofs, the o-minimal theory, in particular the Pila-Wilkie counting theorems, plays an important role.
La conjecture de Zilber-Pink est une conjecture diophantienne concernant les intersections atypiques dans les variétés de Shimura mixtes. C’est une généralisation commune de la conjecture d’André-Oort et de la conjecture de Mordell-Lang. Le but de cette thèse est d’étudier Zilber-Pink. Plus concrètement, nous étudions la conjecture d’André-Oort, selon laquelle une sous-variété d’une variété de Shimura mixte est spéciale si son intersection avec l’ensemble des points spéciaux est dense, et la conjecture d’André-Pink-Zannier, selon laquelle une sous-variété d’une variété de Shimura mixte est faiblement spéciale si son intersection avec une orbite de Hecke généralisée est dense. Cette dernière conjecture généralise Mordell-Lang comme expliqué par Pink.Dans la méthode de Pila-Zannier, un point clef pour étudier la conjecture de Zilber-Pink est de démontrer le théorème d’Ax-Lindemann qui est une généralisation du théorème classique de Lindemann-Weierstrass dans un cadre fonctionnel. Un des résultats principaux de cette thèse est la démonstration du théorème d’Ax-Lindemann dans sa forme la plus générale, c’est- à-dire le théorème d’Ax-Lindemann mixte. Ceci généralise les résultats de Pila, Pila-Tsimerman, Ullmo-Yafaev et Klingler-Ullmo-Yafaev concernant Ax-Lindemann pour les variétés de Shimura pures.Un autre résultat de cette thèse est la démonstration de la conjecture d’André-Oort pour une grande collection de variétés de Shimura mixtes : in- conditionnellement pour une variété de Shimura mixte arbitraire dont la par- tie pure est une sous-variété de AN6 (par exemple les produits des familles universelles des variétés abéliennes de dimension 6 et le fibré de Poincaré sur A6) et sous GRH pour toutes les variétés de Shimura mixtes de type abélien. Ceci généralise des théorèmes connus de Klinger-Ullmo-Yafaev, Pila, Pila-Tsimerman et Ullmo pour les variétés de Shimura pures.Quant à la conjecture d’André-Pink-Zannier, nous démontrons plusieurs cas valables lorsque la variété de Shimura mixte ambiante est la famille universelle des variétés abéliennes. Tout d’abord nous démontrons l’intersection d’André-Oort et André-Pink-Zannier, c’est-à-dire que l’on étudie l’orbite de Hecke généralisée d’un point spécial. Ceci généralise des résultats d’Edixhoven-Yafaev et Klingler-Ullmo-Yafaev pour Ag. Nous prouvons ensuite la conjecture dans le cas suivant : une sous-variété d’un schéma abélien au dessus d’une courbe est faiblement spéciale si son intersection avec l’orbite de Hecke généralisée d’un point de torsion d’une fibre non CM est Zariski dense. Finalement pour une orbite de Hecke généralisée d’un point algébrique arbitraire, nous démontrons la conjecture pour toutes les courbes. Ces deux derniers cas généralisent des résultats de Habegger-Pila et Orr pour Ag.Dans toutes les démonstrations, la théorie o-minimale, en particulier le théorème de comptage de Pila-Wilkie, joue un rôle important.
VD2_GAO_ZIYANG_24112014.pdf (1.95 Mo) Télécharger le fichier
VD2_GAO_ZIYANG_24112014_Synthese_en_franais_annexes.pdf (354.55 Ko) Télécharger le fichier
Format : Autre
tel-01321110 , version 1 (25-05-2016)
  • HAL Id : tel-01321110 , version 1
Ziyang Gao. Le théorème d’Ax-Lindemann mixte et ses applications à la conjecture de Zilber-Pink. Mathématiques générales [math.GM]. Université Paris Sud - Paris XI; Universiteit Leiden (Leyde, Pays-Bas), 2014. Français. ⟨NNT : 2014PA112347⟩. ⟨tel-01321110⟩
332 Consultations
215 Téléchargements
