Vision périphérique, caractérisation et suppléance de ses fonctions spatiales - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2015
Peripheral vision, characterization and substitution of its spatial functions
The loss of peripheral vision (tunnel vision) leads to numerous deficits, reducing both independence and quality of life. These deficits reflect spatial cognition impairments, and highlight the close relationship between peripheral vision and spatial representations. This thesis has two main objectives: reaching a better understanding of the nature of these relationships, and using the acquired knowledge in order to propose adaptive, performant and innovative assistive devices able to overcome the peripheral loss. At first, I address the role of peripheral vision in egocentric space coding. I collaborated in a psychophysics experiment, involving detection of visual objects placed in peripheral vision. The visual objects formed similar images on the retina and differed only with respect to their egocentric location: either straight-ahead or eccentric with respect to the head/body midline. We found that straight-ahead objects elicit consistently shorter behavioral responses than eccentric objects. I took in charge a second study evaluating the link between the privileged sensory processing of the straight ahead direction and the dynamic of ocular saccades. Comparison between centripetal and centrifugal pro-saccades and anti-saccades revealed that the superior dynamic of centripetal saccades comes from both sensory and oculomotor factors. These works reveal the early integration of both visual and oculomotor signals in peripheral vision, leading to egocentric representations in which the straight ahead direction is highlighted. Secondly, I investigated the influence of peripheral vision in extracting allocentric spatial representations. In order to assess the role of peripheral vision in allocentric coding, I performed a memory-based pointing task toward previously gazed targets, which were briefly superimposed with visual cues placed at different eccentricities. The results showed that visual cues in peripheral (>10°) vision can contribute to the allocentric coding of a fixated target. A complementary experiment showed that these peripheral allocentric cues play a functional role, notably by facilitating visual searches. These works highlight the importance of peripheral vision in extracting functional spatial relationships between distant elements of the visual environment. Finally, I wanted to promote the development of new assistive devices, able to substitute both egocentric and allocentric spatial functions of the peripheral vision. As a proof of concept, I designed and evaluated a tactile interface mounted on wrist, communicating the spatial location of specific objects and facilitating visual search. Results showed that healthy subjects with artificial tunnel vision (10°) were able to increase by three visual search speeds thank to this tactile interface. Similar results were obtained on a glaucoma subject (field of view 10x15°). My multidisciplinary thesis highlights new roles of peripheral vision in spatial representations and proposes an innovative solution to develop assistive device for tunnel vision.
La perte de vision périphérique (vision tubulaire) a pour conséquence de nombreux déficits qui réduisent fortement l'autonomie des personnes qui en sont atteintes et par conséquent leur qualité de vie. Nombre de ces déficits témoignent d'une cognition spatiale dégradée mettant en jeu des relations étroites entre vision périphérique et représentations spatiales. Le double objectif de ce travail de thèse consiste à mieux comprendre la nature de ces relations et, sur la base de ces connaissances, contribuer à l'émergence de dispositifs d'assistance plus adaptés et performants, capables de suppléer l'absence de vision périphérique. Dans un premier temps, je me suis intéressé au rôle de la vision périphérique dans la construction de représentations spatiales égocentrées. J'ai d'abord collaboré à une expérience de psychophysique impliquant la détection en vision périphérique de cibles visuelles situées soit droit-devant, soit excentrées par rapport à l'axe du corps. En mesurant les temps de réaction nous avons pu démontrer que les sujets humains répondaient plus rapidement aux cibles présentées droit-devant qu'aux cibles excentrées. J'ai pris en charge une deuxième étude complémentaire portant sur le lien entre ce traitement sensoriel privilégié du droit-devant en vision périphérique et la dynamique des saccades oculaires de recentrage. En comparant les dynamiques de pro-saccades et d'anti-saccades de recentrage ou d' " excentrage ", j'ai pu mettre en évidence que la supériorité dynamique des saccades de recentrage guidées par la vision périphérique reposait à la fois sur des facteurs sensoriels et oculomoteurs. Ces travaux révèlent l'intégration précoce de signaux visuels et oculomoteurs en vision périphérique, pouvant servir à localiser les éléments visuels par rapport à soi et à privilégier le traitement des éléments situés dans l'axe droit-devant. Dans un deuxième temps, mes travaux ont abordé l'influence de la vision périphérique dans les représentations spatiales allocentrées. Pour étudier l'implication de la vision périphérique dans le codage allocentré, j'ai réalisé une expérience impliquant une tâche de pointage vers des cibles visuelles en vision centrale, accompagnées ou non d'indices visuels à différentes distances en vision périphérique. Les résultats obtenus montrent que des indices visuels capturés par la vision périphérique peuvent effectivement contribuer au codage allocentré d'une cible fixée, et ce même lorsque ces indices périphériques doivent être extraits de scène visuelles complexes en moins de 200 ms. Dans une étude complémentaire, j'ai montré que l'utilisation de ces indices allocentrés situés en périphérie avait un véritable rôle fonctionnel, accélérant les recherches visuelles. Ainsi, ces travaux révèlent une implication fonctionnelle forte de la vision périphérique dans l'extraction des relations spatiales entre éléments présents dans l'environnement visuel. J'ai voulu, durant la dernière partie de ma thèse, initier le développement d'un dispositif d'assistance dont la finalité est de suppléer les fonctions spatiales, égocentrées et allocentrées, de la vision périphérique. Comme preuve de concept, mon travail a consisté à concevoir et développer un dispositif tactile placé sur le poignet et capable de communiquer la position spatiale d'objets d'intérêt pour en simplifier leurs recherches visuelles. Les résultats obtenus chez des sujets sains avec un champ visuel artificiellement réduit (10°) montrent que l'interface tactile permet d'accélérer par trois la vitesse de recherche visuelle. Des résultats similaires ont été observés chez une personne atteinte de glaucome (champ visuel de 10x15°). Ma thèse pluridisciplinaire permet d'apporter un nouvel éclairage sur l'implication de la vision périphérique dans la construction de représentations spatiales, et elle propose de nouvelles pistes pour le développement de dispositifs d'assistance adaptés aux personnes atteintes de vision tubulaire.
2015TOU30115.pdf (6.02 Mo) Télécharger le fichier
tel-01321437 , version 1 (25-05-2016)
  • HAL Id : tel-01321437 , version 1
Damien Camors. Vision périphérique, caractérisation et suppléance de ses fonctions spatiales. Neurosciences [q-bio.NC]. Université Paul Sabatier - Toulouse III, 2015. Français. ⟨NNT : 2015TOU30115⟩. ⟨tel-01321437⟩
515 Consultations
1646 Téléchargements
