Étude du rôle des facteurs de transcription inducteurs d’EMT dans la mélanomagenèse - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2015
EMT-transcription factors involvement during melanomagenesis
Geoffrey Richard
  • Fonction : Auteur
  • PersonId : 778160
  • IdRef : 193388154
Embryonic transcription factors inducers of Epithelial to Mesenchymal Transition (EMT-TFs) are frequently and aberrantly reactivated in many cancers. In carcinomas they promote, in early stage, tumor development by inhibiting the failsafe programs of the cell like senescence and apoptosis, and in final stages, they promote metastases formation. In melanoma we highlighted antagonist’s functions of these factors: it was known that ZEB2 and SNAIL2 were involved in delamination of neural crest cells and melanocytes determination but unexpectedly, ZEB2 and SNAIL2 are also expressed in normal adult melanocytes and their expression is decreased during malignant progression, for the benefit of ZEB1 and TWIST1 factors. This change in expression profiling is a factor of poor prognosis for patients. The results I provide show that this antagonistic effect might go through the regulation of MITF, the key factor in the development of melanocytic. ZEB2 and SNAIL2 exert an oncosuppressive function by activating the expression of MITF and promoting melanocytic differentiation. On the contrary, ZEB1 TWIST1 plays an oncogenic role in inhibiting MITF and promotes the acquisition of stem cells properties. In order to go deeper in the study of TWIST1 oncogenic functions, I used an in vivo Melanoma murine model induced by the BRAFV600 oncogene. I thus put in evidence that the combined expression of TWIST1 and BRAFV600 leads to the formation of aggressive, dedifferentiated and invasive melanoma. Finally, I analyzed and characterized the involvement of these factors in the process of resistance to targeted therapies against BRAFV600E melanomas. I demonstrated that ZEB1 may contribute to BRAF inhibitors resistance. Indeed, ZEB1 expression is increased in resistant (innate or acquired) melanomas cells, compared to sensitive cells. While ZEB1 expression promotes the emergence of resistant cells, targeting ZEB1 increases the sensitivity to BRAF inhibitor and sensitizes resistants cells, highlighting the interest of this combination from a therapeutic point of view
Les facteurs de transcription inducteurs de la transition épithélio-mésenchymateuse (EMT) sont fréquemment réactivés de manière aberrante dans de nombreux cancers. Dans les carcinomes, ils favorisent dans les étapes précoces le développement tumoral en inhibant les systèmes de sauvegarde tels que la sénescence ou l'apoptose et à terme dans les étapes finales, promeuvent la formation de métastases. Dans le cadre du mélanome nous avons mis en évidence des fonctions antagonistes de ces facteurs : il était connu que ZEB2 et SNAIL2 sont impliqués dans la délamination de la crête neurale et la détermination mélanocytaire mais de manière inattendue ZEB2 et SNAIL2 sont aussi exprimés dans les mélanocytes adultes normaux et leur expression est diminuée au cours de la progression maligne, au profit des facteurs ZEB1 et TWIST1. Ce changement de profil d'expression est un facteur de mauvais pronostic pour les patients. Mes travaux ont permis de montrer que cet effet antagoniste passe par la régulation de MITF, le facteur clef du développement mélanocytaire. ZEB2 et SNAIL2 exercent une fonction oncosuppressive en activant l'expression de MITF et en promouvant la différenciation mélanocytaire. Au contraire, ZEB1 et TWIST1 jouent un rôle oncogénique en inhibant MITF et favorisent l'acquisition de propriétés de cellules souches. J'ai poursuivi l'étude de la fonction oncogénique de Twist1 in vivo dans un modèle murin de mélanome induit par l'oncogène BRAFV600. J'ai ainsi mis en évidence que l'expression conjointe de Twist1 et de BRAFV600 entraîne la formation de mélanomes agressifs, dédifférenciés et invasifs. Enfin, j'ai analysé et caractérisé l'implication de ces facteurs dans le processus de résistance aux thérapies ciblées anti-BRAF dans les mélanomes BRAFV600E. J'ai démontré que ZEB1 peut contribuer à la résistance aux inhibiteurs de BRAF. En effet, l'expression de ZEB1 est augmentée dans des cellules de mélanomes résistantes (innée ou acquise), par rapport aux cellules sensibles. Tandis que l'expression de ZEB1 favorise l'émergence de cellules résistantes, cibler ZEB1 augmente la sensibilité des cellules à l'inhibiteur de BRAF et resensibilise les cellules résistantes, mettant en évidence l'intérêt de cette combinaison d'un point de vue thérapeutique
TH2015RichardGeoffrey.pdf (37.55 Mo) Télécharger le fichier
tel-01323026 , version 1 (30-05-2016)
  • HAL Id : tel-01323026 , version 1
Geoffrey Richard. Étude du rôle des facteurs de transcription inducteurs d’EMT dans la mélanomagenèse. Cancer. Université Claude Bernard - Lyon I, 2015. Français. ⟨NNT : 2015LYO10141⟩. ⟨tel-01323026⟩
656 Consultations
128 Téléchargements
