Modeling of wind turbine noise sources and propagation in the atmosphere - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2016
Modélisation des sources et de la propagation dans l'atmosphère du bruit des éoliennes
The purpose of this work is to model wind turbine noise sources and propagation in the atmosphere in order to better understand the characteristics of wind turbine noise at long range and to help wind turbine manufacturers and wind farm developers meet the noise regulations. By coupling physically-based aeroacoustic source and propagation models, we are able to predict wind turbine noise spectra, directivity and amplitude modulation in various atmospheric conditions. Amiet's analytical model is chosen to predict turbulent inflow noise and trailing edge noise, considering several improvements to the original theory. The two models are validated against several wind tunnel experiments from the literature using fixed airfoils. Amiet's model is then applied on a full-size wind turbine to predict the noise emission level in the near field. Doppler effect and blade rotation are taken into account. Cases with constant wind profiles and no turbulence are used first, then wind shear and atmospheric turbulence effects obtained from Monin-Obukhov similarity theory are included. Good agreements against field measurements are found when both turbulent inflow noise and trailing edge noise are considered. We finally propose a method to couple the source model to a parabolic equation code to take into account ground and atmospheric refraction effects. Depending on the propagation direction, noise levels vary because the ground effect is influenced by wind shear and a shadow zone is present upwind.
L'objectif de ce travail est de modéliser les sources et la propagation atmosphérique du bruit généré par les éoliennes afin de mieux comprendre les caractéristiques de ce bruit à grande distance et d'aider les fabricants d'éoliennes et les développeurs de parc à respecter la réglementation. En couplant des modèles physiques de source aéroacoustique et de propagation, nous sommes capables de prédire les spectres de bruit, ainsi que la directivité et les modulations d'amplitude associées, pour différentes conditions atmosphériques. Le modèle analytique d'Amiet est choisi pour prédire le bruit d'impact de turbulence et le bruit de bord de fuite, en considérant plusieurs améliorations par rapport à la théorie initiale. Ces modèles sont validés par comparaison avec des mesures de la littérature en soufflerie avec des profils fixes. Le modèle d'Amiet est ensuite appliqué à une éolienne complète pour prédire le bruit émis en champ proche. L'effet de la rotation des pales et l'effet Doppler sont pris en compte. On utilise d'abord des profils de vent constant sans turbulence, puis l'effet du cisaillement du vent et de la turbulence atmosphérique sont inclus à l'aide de la théorie de la similitude de Monin-Obukhov. De bons accords sont obtenus avec des mesures sur site éolien lorsque l'on considère à la fois les bruits de bord de fuite et d'impact de turbulence. On propose finalement une méthode pour coupler le modèle de source à un code d'équation parabolique afin de prendre en compte les effets de sol et de réfraction atmosphérique. En fonction de la direction de propagation, les niveaux de bruit varient car l'effet de sol est influencé par les gradients de vent et car une zone d'ombre est présente dans la direction opposée au vent.
These_Yuan_Tian_internet.pdf (19.94 Mo) Télécharger le fichier
tel-01335869 , version 1 (22-06-2016)
tel-01335869 , version 2 (25-08-2016)
  • HAL Id : tel-01335869 , version 1
Yuan Tian. Modeling of wind turbine noise sources and propagation in the atmosphere. Acoustics [physics.class-ph]. Université Paris-Saclay, 2016. English. ⟨NNT : 2016SACLY003⟩. ⟨tel-01335869v1⟩
Collections
CEA CNRS
975 Consultations
1154 Téléchargements
