Biology of mouse mucosal-associated invariant T cells - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2015
Biologie des cellules MAIT chez la souris
Yue Cui
  • Fonction : Auteur
Mucosal-associated invariant T cells (MAIT) are innate lymphocytes that express a semi-invariant T cell receptor (iTCR) and are restricted by the major histocompatibility complex (MHC) related molecule, MR1. In human, MAIT cells are abundant in the blood (1-10%), gut (3-5%), and liver (20-40%). They react against microbial-derived riboflavin metabolites that are common in bacteria and yeast. Due to the paucity of MAIT cells in classical inbred laboratory mice, studies on mouse MAIT cells were mostly performed in TCR-transgenic (Tg) mice. However, these Tg MAIT cells do not adequately recapitulate the phenotype of human MAIT cells. Herein, we present a recently generated congenic mouse strain harboring MAIT cells that closely resemble human MAIT cells and use this tool to study the characteristics of natural mouse MAIT cell. An analysis of wild-derived inbred mouse strains revealed that CAST/Ei strain has increased frequency of MAIT cells than C57BL/6 mice. This was linked to a locus on the TCRα region. Introduction of such locus into C57BL/6 mice generated a “MAIT” congenic strain, which were further crossed to Rorc(γt)-GfpTG reporter strain based on previous findings of RORγt expression on human MAIT cells. Using this tool, we show that natural mouse MAIT cells are CD4−CD8−/lo, display an effector memory phenotype (CD44+), and coexpress the transcription factors PLZF and RORγt. They exhibit tissue-homing properties (CCR6+CCR7−) and preferentially reside in peripheral non-lymphoid tissues, including lung, liver, and skin. Upon TCR ligation, MAIT cells produce TH1/2/17 type cytokines and react to bacterial-derived antigens (i.e. semi-purified bacterial fraction or 5-OP-RU) in an MR1-dependent manner. They have high expression of cytokine receptors (IL-7R, IL-18Rα, IL-12Rβ) and may respond to the corresponding innate cytokines. During experimental urinary tract infection, MAIT cells migrate to the bladder and display a protective anti-bacterial activity. Altogether, our results demonstrate that mouse MAIT cells resemble their human counterparts more closely than previously recognized and therefore this new mouse model will be a powerful tool for advancing our understanding of MAIT cell biology in health and disease.
Les cellules T invariantes associées aux muqueuse (MAIT) sont des lymphocytes innés caractérisés par l'expression d'un récepteur des cellules T semi-invariant (iTCR) et restreints par la molécule du complexe majeur d'histocompatibilité de classe Ib, MR1. Chez l'homme, les cellules MAIT sont abondantes dans le sang (1 à 10%), l'intestin (3 à 5%) et le foie (20 à 40%) et réagissent contre des métabolites microbiens. En raison de leur rareté dans les souris de laboratoire classiques, les études sur les cellules MAIT murines ont été principalement effectuées sur des souris transgéniques (Tg) pour des TCR MAIT. Cependant, ces cellules MAIT Tg ne récapitulent pas de manière adéquate le phénotype des cellules MAIT humaines. Ici, nous décrivons une souche de souris congénique que nous avons générée qui possède des cellules MAIT qui ressemblent aux cellules MAIT humaines. Nous utilisons cet outil pour étudier les caractéristiques des cellules MAIT murines. L'étude de souches de souris consanguines d'origine sauvage montre que la souche CAST/Ei présente une fréquence des cellules MAIT nettement supérieur à celle retrouvée dans la souche C57BL/6. Un seul locus est impliqué et a été localisé dans la région TCRα. Ceci a permis la génération d'une souche "MAIT" congénique, qui ont été en outre croisé à une souris Tg pour un rapporteur GFP du facteur transcriptionnel RORγt sur la base de données antérieurs montrant que les MAITs humaines expriment ce facteur. Grâce à cet outil, nous montrons que les MAITs murines sont CD4−CD8−/lo, ont un phénotype mémoire effecteurs (CD44+) et coexpriment PLZF et RORγt. Ces MAITs murines sont orientées vers une localisation tissulaire (CCR6+CCR7−) et résident préférentiellement dans les tissus non lymphoïdes périphériques, y compris les poumons, le foie et la peau. Après stimulation du TCR, les MAITs produisent des cytokines TH1/2/17 et sont aussi activées par de antigènes bactériens (par exemple semi-purifié fraction bactérienne ou 5-OP-RU) d'une manière dépendant de MR1. Les MAITs ont une forte expression de récepteurs de cytokines (IL-7R, IL-18Rα, IL-12Rβ) et peuvent ainsi répondre à des cytokines innées. Lors d'une infection expérimentale des voies urinaires, les MAITs migrent vers la vessie et ont une activité protectrice anti-bactérienne. Au total, nos résultats démontrent que les cellules MAIT murines ressemblent étroitement à leurs homologues humains. Ce nouveau modèle murin sera un outil puissant pour faire avancer notre compréhension de la biologie des cellules MAIT en situation normale et pathologique.
Immunologie
va_Cui_Yue.pdf (5.78 Mo) Télécharger le fichier
tel-01356272 , version 1 (25-08-2016)
  • HAL Id : tel-01356272 , version 1
Yue Cui. Biology of mouse mucosal-associated invariant T cells. Immunology. Université Sorbonne Paris Cité, 2015. English. ⟨NNT : 2015USPCB015⟩. ⟨tel-01356272⟩
309 Consultations
305 Téléchargements
