Etude des ouvrages maçonnés en pierre par la méthode des éléments discrets : caractérisation et modélisation du comportement cohésif des joints - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2016
Study of stone masonry building with discrete element method : Caracterization and modeling of themortar joints cohesive behavior
Stone masonry is an age-old constructive technique, nevertheless the mechnicalbehavior of this type of construction is still misunderstood. Consequently, standardsfor masonry structural design are very conservative and overestimate design of this kind ofstructures. Moreover, engineers cannot rely on suitable design code to assess masonry buildings.This research project aims to develop a design code suitable for structural masonrydesign to help engineers.Discrete element code LMGC90 was picked for its capacity to take into account masonrydiscontinuities. A mixed mode I+II cohesive interface law is established in order to considerprogressive damage and energy dissipation associated to quasi-brittle behaviour of mortarjoints. An experimental procedure was also carried out to estimate the whole cohesive andfrictional parameters ofmortar joints.The proposed numerical model is confronted to two experimental tests on shear masonrywalls under two different boundary conditions. The results of the analysis shows that thedeveloped model fails at reproducing precisely the shear behaviour especially when the normalstress to the joint strongly increses during the test. Thus we discuss on the Mode II law,and more specifically on the separation of frictional and cohesive behaviours which must beresponsible for the deficient results.
Bien que la maçonnerie en pierre soit une technique de construction ancestrale,le comportement mécanique de ce type de construction reste encore aujourd’hui méconnu.En conséquence, la réglementation concernant ces ouvrages est restrictive et considèredes marges de sécurité importantes, qui conduisent à un surdimensionnement de cetype de structure. Ce projet de recherche vise à développer un code de calcul adapté à l’étudede structures maçonnées, utilisable en bureau d’études afin d’aider les ingénieurs qui nepossèdent pas d’outils adaptés aux ouvrages maçonnés sur lesquels s’appuyer.Le logiciel de calcul aux éléments discrets LMGC90 a été choisi pour sa capacité à représenterle caractère discontinu de la maçonnerie. Une loi d’interface cohésive enmode mixte (I+II) aété mise au point afin de prendre en compte l’endommagement progressif et la dissipationd’énergie associés au comportement quasi-fragile des joints de mortier. Un protocole expérimentalpermettant d’estimer l’ensemble des paramètres cohésifs et frictionnels des jointsde mortier a également été mis au point.Le modèle numérique proposé est confronté à deux essais expérimentaux menés sur desmurs sollicités en cisaillement sous deux conditions aux limites différentes. L’analyse desrésultats obtenusmet en avant l’insuffisance de la loi deMode II proposée à décrire précisémentle comportement en cisaillement dans certains cas. Des voies d’amélioration concernantla modélisation sont donc proposées, comprenant notamment l’étude précise du couplageentre l’endommagement (comportement cohésif) et le comportement frictionnel desjoints sollicités en cisaillement.
SAUVE_BISOFFI_MARIE_2016.pdf (29.99 Mo) Télécharger le fichier
tel-01373072 , version 1 (28-09-2016)
  • HAL Id : tel-01373072 , version 1
Marie Bisoffi-Sauve. Etude des ouvrages maçonnés en pierre par la méthode des éléments discrets : caractérisation et modélisation du comportement cohésif des joints. Autre. Université de Bordeaux, 2016. Français. ⟨NNT : 2016BORD0069⟩. ⟨tel-01373072⟩
892 Consultations
4069 Téléchargements
