Analyse des pressions anthropiques sur l’environnement littoral européen et français - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2015
Analysis of anthropogenic pressures on the French and European coastal environment
Coastal management and conservation require the synthesis of geographic data on the distribution and intensity of human activities and their combined impacts on marine and terrestrial coastal ecosystems. Currently, across the European or French coasts, few studies provide a global view of risks on terrestrial and marine habitats. How are human pressures on biodiversity distributed? How to define the littoral system and thus improve management of this territory? At the European level, using 24 human pressures from EUROSTAT across the NUTS classification, we cut the European coasts in strips of 10 km to a limit of 100 km and identified the distribution and relative intensity pressures on coastal environments. We have shown that the great majority of the pressures occurs directly on the coastline and in the first 30 kilometers, then decreases sharply to the limit of 100 km. This division of the European coasts has also allowed us to use factorial correspondence analyses coupled with a hierarchical cluster analysis to divide the coastal territories in 4 coherent groups with the same pressures and relative intensities across Europe. At the French level, we have also developed a spatial model weighted by expert opinions based on geolocation of 15 human pressures on 81 marine and terrestrial biophysical habitats present on the metropolitan French coasts. The information is synthesized in the form of impact score applied to a mesh composed of 26000 cells (25 km²). This method of cumulative anthropogenic impacts scoring in an additive model shows areas with higher risks on both the marine and land territory. Again, the most affected areas by the human disturbances are close to the coast. Conversely, the least affected areas are those with a strong bathymetry and those with a significant elevation. We finally developed a participatory website that includes integrated GIS that allows the collection and dissemination of analysis of these human pressures on France following our additive model and allows at more local scales to return our analysis from any type of user. In the end few areas are not affected by human activities (0.1%) and a rather large fraction present very high risk (4.8%). The nearer the coastline, the more the risks are high. These analyses and maps are tools that give better understanding of conservation issues for the implementation of a socio-ecosystems coastal management and that will target the priorities in the conservation of our territories at a continental, national or local scale.
La gestion et la conservation des littoraux exigent la synthèse de données géographiques sur la répartition et l'intensité des activités humaines et sur le cumul de leurs impacts sur les écosystèmes côtiers marins et terrestres. Actuellement, à l’échelle du littoral européen ou français, peu d’études offrent une vision globale des risques sur les habitats terrestres et marins. Comment s’y répartissent les pressions humaines sur la biodiversité ? Comment mieux définir le système littoral et ainsi améliorer la gestion de ce territoire ? A l’échelle européenne, à l’aide de 24 pressions anthropiques issues d’EUROSTAT sur une classification NUTS, nous avons découpé le littoral terrestre européen en bandes de 10 km jusqu’à une limite de 100 km et identifié la répartition et l’intensité relative des pressions sur les environnements côtiers. Nous avons ainsi montré que la grande majorité des pressions se situent directement sur le trait de côte et les 30 premiers kilomètres, puis diminue fortement jusqu’à la limite des 100 km. Ce découpage du littoral européen nous a aussi permis, à l’aide d’analyses factorielles des correspondances couplées à de la classification hiérarchique ascendante, de diviser les territoires littoraux en 4 groupes cohérents présentant les mêmes pressions et intensités relatives à l’échelle de l’Europe. A l’échelle française, nous avons également développé un modèle spatial pondéré par dires d’experts basé sur la géolocalisation de 15 pressions anthropiques pour 81 habitats biophysiques marins et terrestres présents sur les littoraux français métropolitains. L’information est synthétisée sous la forme de score appliqué à un maillage composé de 26000 cellules de 25 km². Cette méthode de scoring cumulative, dans un modèle additif des impacts anthropiques, nous montre les aires à risques à la fois sur le territoire marin et terrestre. Encore une fois, les zones les plus affectées par les perturbations humaines sont les plus proches du littoral. A contrario, les zones les moins affectées sont celles avec une bathymétrie forte et celles avec une élévation importante. Nous avons finalement développé un site web participatif qui comporte de la SIG intégrée pour permettre la collecte et la diffusion de l’analyse de ces pressions anthropiques sur la France métropolitaine en suivant notre modèle additif et permet à des échelles plus locales de restituer notre analyse à tout type d’utilisateur. Au final, peu de zones ne sont pas affectées par les activités humaines (0,1%) et au contraire, une fraction importante présente de très forts risques (4,8%). Les risques sont de plus en plus forts en se rapprochant du trait de côte. Ces analyses et les cartes développées sont des outils permettant de mieux comprendre les enjeux de conservation pour la mise en œuvre d’une gestion des socio-écosystèmes littoraux et permettront de mieux cibler les priorités dans la conservation de notre territoire à échelle continentale, nationale ou locale.
2015Daeden71658.pdf (11.65 Mo) Télécharger le fichier
tel-01373455 , version 1 (28-09-2016)
  • HAL Id : tel-01373455 , version 1
Jonathan Daeden. Analyse des pressions anthropiques sur l’environnement littoral européen et français. Géographie. Université de La Rochelle, 2015. Français. ⟨NNT : 2015LAROS019⟩. ⟨tel-01373455⟩
1067 Consultations
4080 Téléchargements
