On some diffusion and spanning problems in configuration model - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2016
Sur certains problèmes de diffusion et de connexité dans le modèle de configuration
A number of real-world systems consisting of interacting agents can be usefully modelled by graphs, where the agents are represented by the vertices of the graph and the interactions by the edges. Such systems can be as diverse and complex as social networks (traditional or online), protein-protein interaction networks, internet, transport network and inter-bank loan networks. One important question that arises in the study of these networks is: to what extent, the local statistics of a network determine its global topology. This problem can be approached by constructing a random graph constrained to have some of the same local statistics as those observed in the graph of interest. One such random graph model is configuration model, which is constructed in such a way that a uniformly chosen vertex has a given degree distribution. This is the random graph which provides the underlying framework for this thesis. As our first problem, we consider propagation of influence on configuration model, where each vertex can be influenced by any of its neighbours but in its turn, it can only influence a random subset of its neighbours. Our (enhanced) model is described by the total degree of the typical vertex and the number of neighbours it is able to influence. We give a tight condition, involving the joint distribution of these two degrees, which allows with high probability the influence to reach an essentially unique non-negligible set of the vertices, called a big influenced component, provided that the source vertex is chosen from a set of good pioneers. We explicitly evaluate the asymptotic relative size of the influenced component as well as of the set of good pioneers, provided it is non-negligible. Our proof uses the joint exploration of the configuration model and the propagation of the influence up to the time when a big influenced component is completed, a technique introduced in Janson & Luczak~(2008). Our model can be seen as a generalization of the classical Bond and Node percolation on configuration model, with the difference stemming from the oriented conductivity of edges in our model. We illustrate these results using a few examples which are interesting from either theoretical or real-world perspective. The examples are, in particular, motivated by the viral marketing phenomenon in the context of social networks. Next, we consider the isolated vertices and the longest edge of the minimum spanning tree of a weighted configuration model. Using Stein-Chen method, we compute the asymptotic distribution of the number of vertices which are separated from the rest of the graph by some critical distance, say alpha. This distribution gives the scaling of the length of the longest edge of the nearest neighbour graph with the size of the graph. We then use the results of Fountoulakis (2007) on percolation to prove that after removing all the edges of length greater than alpha, the subgraph obtained is connected but for the isolated vertices. This leads us to conclude that the longest edge of the minimal spanning tree and that of the nearest neighbour graph coincide with high probability. Finally, we investigate a more general question, that is, whether some ordering based on local statistics of the graph would lead to an ordering of the global topological properties, so that the bounds for more complex graphs could be obtained from their simplified versions. To this end, we introduce a convex order on random graphs and discuss some implications, particularly how it can lead to the ordering of percolation probabilities in certain situations.
Un certain nombre de systèmes dans le monde réel, comprenant des agents interagissant, peut être utilement modélisé par des graphes, où les agents sont représentés par les sommets du graphe et les interactions par les arêtes. De tels systèmes peuvent être aussi divers et complexes que les réseaux sociaux (traditionnels ou virtuels), les réseaux d'interaction protéine-protéine, internet, réseaux de transport et les réseaux de prêts interbancaires. Une question importante qui se pose dans l'étude de ces réseaux est: dans quelle mesure, les statistiques locales d'un réseau déterminent sa topologie globale. Ce problème peut être approché par la construction d'un graphe aléatoire contraint d'avoir les mêmes statistiques locales que celles observées dans le graphe d'intérêt. Le modèle de configuration est un tel modèle de graphe aléatoire conçu de telle sorte qu'un sommet uniformément choisi présente une distribution de degré donnée. Il fournit le cadre sous-jacent à cette thèse. En premier lieu nous considérons un problème de propagation de l'influence sur le modèle de configuration, où chaque sommet peut être influencé par l'un de ses voisins, mais à son tour, il ne peut influencer qu'un sous-ensemble aléatoire de ses voisins. Notre modèle étendu est décrit par le degré total du sommet typique et le nombre de voisins il est capable d'influencer. Nous donnons une condition stricte sur la distribution conjointe de ces deux degrés, qui permet à l'influence de parvenir, avec une forte probabilité, à un ensemble non négligeable de sommets, essentiellement unique, appelé la composante géante influencée, à condition que le sommet de la source soit choisi à partir d'un ensemble de bons pionniers. Nous évaluons explicitement la taille relative asymptotique de la composant géante influencée, ainsi que de l'ensemble des bons pionniers, à condition qu'ils soient non-négligeable. Notre preuve utilise l'exploration conjointe du modèle de configuration et de la propagation de l'influence jusqu'au moment où une grande partie est influencée, une technique introduite dans Janson et Luczak (2008). Notre modèle peut être vu comme une généralisation de la percolation classique par arêtes ou par sites sur le modèle de configuration, avec la différence résultant de la conductivité orientée des arêtes dans notre modèle. Nous illustrons ces résultats en utilisant quelques exemples, en particulier, motivés par le marketing viral - un phénomène connu dans le contexte des réseaux sociaux. Ensuite, nous considérons les sommets isolés et les arêtes longues de l'arbre couvrant minimal du modèle de configuration dont les arêtes sont indépendamment pondérée par des nombres non-négatifs interprétés comme des longueurs. En utilisant la méthode de Stein-Chen, nous calculons la distribution asymptotique du nombre de sommets qui sont séparés du reste du graphe par une certaine distance critique, par exemple alpha. Cette distribution donne la loi d'échelle de la longueur de la plus longue arête du graphe de plus proche voisin. Nous utilisons ensuite les résultats de Fountoulakis (2007) sur la percolation pour démontrer que, après la suppression de toutes les arêtes d'une longueur supérieure à alpha, le sous-graphe obtenu est connexe, sauf pour les sommets isolés. Cela nous amène à conclure que l'arête la plus long de l'arbre couvrant minimal et celle du graphe de plus proche voisin coïncident avec une forte probabilité. Enfin, nous étudions une question plus générale, à savoir si une certaine comparaison basée sur des statistiques locales du graphe conduirait à la comparaison des propriétés topologiques globales, de sorte que des résultats pour certains graphes plus complexes pourraient être obtenus par leur comparaison à des graphes plus simples à étudier. À cette fin, nous introduisons un ordre convexe sur les graphes aléatoires et nous discutons des implications, notamment la façon dont cet ordre peut conduire à la comparaison des probabilités de percolation dans certaines situations.
thesis-Kumar-Gaurav-final-en.pdf (762.57 Ko) Télécharger le fichier
tel-01400999 , version 1 (22-11-2016)
tel-01400999 , version 2 (01-03-2017)
  • HAL Id : tel-01400999 , version 1
Kumar Gaurav. On some diffusion and spanning problems in configuration model. Strongly Correlated Electrons [cond-mat.str-el]. UPMC - Université Paris 6 Pierre et Marie Curie, 2016. English. ⟨NNT : ⟩. ⟨tel-01400999v1⟩
Collections
UPMC
697 Consultations
211 Téléchargements
