Theses
Échantillonnages Monte Carlo et quasi-Monte Carlo pour l'estimation des indices de Sobol' : application à un modèle transport-urbanisme
Abstract : Land Use and Transportation Integrated (LUTI) models have become a norm for representing the interactions between land use and the transportation of goods and people in a territory. These models are mainly used to evaluate alternative planning scenarios, simulating their impact on land cover and travel demand.LUTI models and other mathematical models used in various fields are most of the time based on complex computer codes. These codes often involve poorly-known inputs whose uncertainty can have significant effects on the model outputs.Global sensitivity analysis methods are useful tools to study the influence of the model inputs on its outputs. Among the large number of available approaches, the variance based method introduced by Sobol' allows to calculate sensitivity indices called Sobol' indices. These indices quantify the influence of each model input on the outputs and can detect existing interactions between inputs.In this framework, we favor a particular method based on replicated designs of experiments called replication method. This method appears to be the most suitable for our application and is advantageous as it requires a relatively small number of model evaluations to estimate first-order or second-order Sobol' indices.This thesis focuses on extensions of the replication method to face constraints arising in our application on the LUTI model Tranus, such as the presence of dependency among the model inputs, as far as multivariate outputs.Aside from that, we propose a recursive approach to sequentially estimate Sobol' indices. The recursive approach is based on the iterative construction of stratified designs, latin hypercubes and orthogonal arrays, and on the definition of a new stopping criterion. With this approach, more accurate Sobol' estimates are obtained while recycling previous sets of model evaluations. We also propose to combine such an approach with quasi-Monte Carlo sampling.An application of our contributions on the LUTI model Tranus is presented.
Document type :
Theses
Complete list of metadatas
Cited literature [119 references]  Display  Hide  Download
https://tel.archives-ouvertes.fr/tel-01403914
Contributor : Abes Star :  Contact
Submitted on : Wednesday, January 10, 2018 - 4:07:57 PM
Last modification on : Thursday, November 19, 2020 - 1:01:57 PM
File
GILQUIN_2016_archivage.pdf
Version validated by the jury (STAR)
Identifiers
  • HAL Id : tel-01403914, version 4
Collections
Citation
Laurent Gilquin. Échantillonnages Monte Carlo et quasi-Monte Carlo pour l'estimation des indices de Sobol' : application à un modèle transport-urbanisme. Analyse numérique [math.NA]. Université Grenoble Alpes, 2016. Français. ⟨NNT : 2016GREAM042⟩. ⟨tel-01403914v4⟩
Share
Metrics
Record views
644
Files downloads
1171
