Recherche d’un neutrino stérile avec l’expérience STEREO - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2016
Search for a sterile neutrino with the STEREO experiment
The re-evaluation of the theoretical antineutrino flux emitted by nuclear reactors revealed a deficit of about 6% between the observed flux and the expected one. This so-called reactor antineutrino anomaly has a statistical significance of $2.7\sigma$, and one possible explanation for this deficit could be the existence of a light sterile neutrino state into which reactor antineutrino oscillate at very short distances. The STEREO project, which will be presented in this thesis, aims to find an evidence of such oscillation. The measurement will take place at only few meters ($\sim 10~m$) from the compact core of the Institut Laue-Langevin (ILL) research reactor in Grenoble, France, which provides a large flux of electron antineutrinos with an energy range from 1 to 10 MeV. The sensitive volume of the STEREO detector is $2~m^3$ of organic liquid scintillator doped with Gadolinium, segmented in 6 cells stacked along the direction of the core and detecting anti-neutrinos via inverse beta decay. This setup will provide excellent sensitivity to short-baseline oscillations effects by precisely measuring any relative distortion of the antineutrino spectrum as a function of both energy and baseline. The close proximity to the reactor yield a high background environment from the reactor and also generated in nearby experiments which is managed by the means of heavy shielding surrounding the detector. Many measurements campaign have been performed to characterized this background and had allowed the improvement of the passive shielding design installed on-site. Moreover, an additional detector is settled above STEREO to tag the presence of an incoming cosmic muon and define a muon veto. These muons will produce fast neutrons during their interaction through the shieldings of STEREO and these neutrons can mimick the expected antineutrino signal. Therefore it is crucial to define the most efficient and homogenous veto to these muons. It consists of a tank of $2.5~m^3$ of water detecting muons by their Cerenkov radiation. The light emitted is collected thanks to 20 photomultipliers positionned at the top of the tank and a chemical compound is added into the water to improve the light collection on the photomultipliers. This muon veto fully covers the STEREO detector along with its shieldings. Several configurations of the muon veto system using prototypes before the final instrumental have allowed to define a trigger system which allows an excellent efficiency to cosmic muons whereas having a little sensitivity to others particles. These numerous tests were also used to check and optimize the dedicated electronics builded at LPSC, which is the same for both the STEREO detector and muon veto. After characterization of the muon flux on site and with respect to the muon veto efficiency, a simulation has been developped to evaluate the rate of fake antineutrino events expected from the muon-induced fast neutrons. Thus, this estimation has confirmed the scientific requirements of the experience, which is the ability to probe the reactor antineutrino anomaly in 300 days of reactor data. STEREO is at the moment being integrated at the ILL and should deliver his first physics results early 2017.
La réévaluation théorique du flux d'antineutrinos émis par les réacteurs nucléaires a révélé un déficit de 6% entre le flux observé et le flux attendu. Cette anomalie des antineutrinos de réacteur est significative à $2.7\sigma$, et une possible interprétation de ce résultat est l'existence d'un état stérile léger du neutrino vers lequel les neutrinos pourraient osciller à très courte distance. Le projet STEREO présenté dans ce manuscrit a pour objectif de prouver ou d'infirmer l'existence d'une telle oscillation. L'expérience est installée près ($\sim 10~m$) du cœur compact du réacteur de recherche de l'Institut Laue-Langevin (ILL) à Grenoble, France, qui produit un important flux d'antineutrinos électroniques avec une énergie comprise entre 1 et 10~MeV. Le volume utile du détecteur STEREO consiste en une structure de $2~m^3$ segmentée en six cellules identiques remplies de scintillateur liquide dopé au gadolinium et alignées dans la direction du cœur. La détection s'effectue à l'aide de la réaction beta-inverse. Cette configuration offre une excellente sensibilité à une éventuelle oscillation à courte distance en mesurant la distorsion relative du spectre des antineutrinos dans chaque cellule en fonction de l'énergie et de la distance. Les lignes expérimentales de faisceaux de neutrons de l'ILL produisent un fort bruit de fond qui a été caractérisé à l'occasion de plusieurs campagnes de mesure. Leur analyse a permis de valider le design des lourds blindages passifs installés autour du détecteur et de la zone d'installation pour modérer leurs effets sur l’expérience STEREO. De plus, un détecteur supplémentaire est installé en haut de STEREO pour signaler la présence d'un muon issu du rayonnement cosmique et définir un veto aux mesures physiques. Ces muons, lors de leur passage à travers les blindages du détecteur, peuvent produire des neutrons rapides capables d’imiter le signal attendu par les antineutrinos. Il est donc essentiel de définir un veto qui soit le plus efficace et homogène possible. Il prend la forme d'une cuve de $2.5~m^3$ remplie d'eau dont la détection est basée sur l’effet Tcherenkov. Cette lumière émise par le passage des muons est récoltée sur 20 tubes photomultiplicateurs répartis au-dessus de la cuve et un additif est rajouté dans l'eau pour améliorer la collection de lumière sur les photomultiplicateurs. Ce veto à muons couvre complètement le haut du détecteur STEREO ainsi que de ces blindages L'étude de plusieurs configurations de ce veto à muons sous la forme de prototypes avant la construction de l'instrument final a permis de définir une méthode de déclenchement du signal pour les muons extrêmement efficace tout en conservant une sensibilité réduite aux autres particules. Ces nombreux tests ont par ailleurs permis la validation et l'optimisation de l'électronique développée au LPSC pour l'expérience qui est la même pour le détecteur STEREO et pour le veto à muons. Après avoir caractérisé le flux de muons sur place et l'efficacité du veto à muons, une simulation a été développée et a permis d'évaluer le nombre de faux événements dus à ces neutrons. Ainsi, ce résultat a confirmé les prérequis scientifiques de l'expérience, à savoir la capacité à sonder l'anomalie des antineutrinos de réacteur en 300 jours de données réacteur. Le détecteur est actuellement en place sur site et les prises de données sont prévus pour début octobre~2016. Les premiers résultats sont attendus au printemps~2017.
plan.pdf (62.36 Mo) Télécharger le fichier
tel-01409026 , version 1 (05-12-2016)
tel-01409026 , version 2 (22-08-2017)
  • HAL Id : tel-01409026 , version 1
Stephane Zsoldos. Recherche d’un neutrino stérile avec l’expérience STEREO : Construction du veto à muons et estimation du bruit de fond corrélé. Physique des Hautes Energies - Expérience [hep-ex]. Univ. Grenoble Alpes, 2016. Français. ⟨NNT : ⟩. ⟨tel-01409026v1⟩
722 Consultations
284 Téléchargements
