Quantitative a posteriori error estimators in Finite Element-based shape optimization - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2016
Estimations d’erreur a posteriori quantitatives pour l’approximation des problèmes d’optimisation de forme par la méthode des éléments finis
Gradient-based shape optimization strategies rely on the computation of the so-called shape gradient. In many applications, the objective functional depends on the solution of a PDE which can only be solved approximately (e.g. via the Finite Element Method). This is also the case for the shape gradient. Hence, the direction computed using the discretized shape gradient may not be a genuine descent direction for the objective functional. This Ph.D. thesis is devoted to the construction of a certification procedure for the descent direction in gradient-based shape optimization methods using a posteriori estimators of the error due to the Finite Element approximation of the shape gradient. By means of a goal-oriented procedure, we derive a fully computable certified upper bound of the aforementioned error. The resulting Certified Descent Algorithm (CDA) for shape optimization is able to identify a genuine descent direction at each iteration and features a reliable stopping criterion based on the norm of the shape gradient. Two main applications are tackled in the thesis. First, we consider the scalar inverse identification problem of Electrical Impedance Tomography and we investigate several a posteriori estimators. A first procedure is inspired by the complementary energy principle and involves the solution of additional global problems. In order to reduce the computational cost of the certification step, an estimator which depends solely on local quantities is derived via an equilibrated fluxes approach. The estimators are validated for a two-dimensional case and some numerical simulations are presented to test the discussed methods. A second application focuses on the vectorial problem of optimal design of elastic structures. Within this framework, we derive the volumetric expression of the shape gradient of the compliance using both the pure displacement and the dual mixed variational formulations of the linear elasticity equation. Some preliminary numerical tests are performed to minimize the compliance under a volume constraint in 2D using the Boundary Variation Algorithm and an a posteriori estimator of the error in the shape gradient is obtained via the complementary energy principle.
Les méthodes de gradient en optimisation de forme reposent sur le calcul de la dérivée de forme. Dans beaucoup d’applications, la fonctionnelle coût dépend de la solution d’une EDP. Il s’en suit qu’elle ne peut être résolue exactement et que seule une approximation de celle-ci peut être calculée, par exemple par la méthode des éléments finis. Il en est de même pour la dérivée de forme. Ainsi, les méthodes de gradient en optimisation de forme - basées sur des approximations du gradient - ne garantissent pas a priori que la direction calculée à chaque itération soit effectivement une direction de descente pour la fonctionnelle coût. Cette thèse est consacrée à la construction d’une procédure de certification de la direction de descente dans des algorithmes de gradient en optimisation de forme grâce à des estimations a posteriori de l’erreur introduite par l’approximation de la dérivée de forme par la méthode des éléments finis. On présente une procédure pour estimer l’erreur dans une Quantité d’Intérêt et on obtient une borne supérieure certifiée et explicitement calculable. L’Algorithme de Descente Certifiée (CDA) pour l’optimisation de forme identifie une véritable direction de descente à chaque itération et permet d’établir un critère d’arrêt fiable basé sur la norme de la dérivée de forme. Deux applications principales sont abordées dans la thèse. Premièrement, on considère le problème scalaire d’identification de forme en tomographie par impédance électrique et on étudie différentes estimations d’erreur. Une première approche est basée sur le principe de l’énergie complémentaire et nécessite la résolution de problèmes globaux additionnels. Afin de réduire le coût de calcul de la procédure de certification, une estimation qui dépend seulement de quantités locales est dérivée par la reconstruction des flux équilibrés. Après avoir validé les estimations de l’erreur pour un cas bidimensionnel, des résultats numériques sont présentés pour tester les méthodes discutées. Une deuxième application est centrée sur le problème vectoriel de la conception optimale des structures élastiques. Dans ce contexte, on calcule l’expression volumique de la dérivée de forme de la compliance à partir de la formulation primale en déplacements et de la formulation duale mixte pour l’équation de l’élasticité linéaire. Quelques résultats numériques préliminaires pour la minimisation de la compliance sous une contrainte de volume en 2D sont obtenus à l’aide de l’Algorithme de Variation de la Frontière et une estimation a posteriori de l’erreur de la dérivée de forme basée sur le principe de l’énergie complémentaire est calculée.
Giacomini_PhD.pdf (5.56 Mo) Télécharger le fichier
tel-01418841 , version 1 (17-12-2016)
tel-01418841 , version 2 (29-03-2017)
  • HAL Id : tel-01418841 , version 1
Matteo Giacomini. Quantitative a posteriori error estimators in Finite Element-based shape optimization. Numerical Analysis [math.NA]. Ecole polytechnique; Université Paris-Saclay, 2016. English. ⟨NNT : 2016SACLX070⟩. ⟨tel-01418841v1⟩
Collections
INRIA INRIA2
697 Consultations
546 Téléchargements
