Profile Guided Hybrid Compilation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2016
Compilation hybride guidée pour Profil
Diogo N. Sampaio
  • Fonction : Auteur
  • PersonId : 997535
Heat dissipation limitations caused a paradigm change in how computational capacity of chips are scaled, from increasing the clock frequency to growing parallelism. In order to explore this characteristic computer applications must be made parallel, a hard job left to software developers. To aid in this process many optimizing compilers and frameworks have been developed, such as polyhedral compilation tools (e.g. PLuTo). In order to apply a transformation to a code, compilers must prove that this preserves the original programs semantics. When the transformation selection and validation is done solely by reasoning over the source-code, this process is called static. With transforming syntax poor code, such as code containing memory references with multiple possible indirections, static compilers are often unable to verify applicability and many optimization opportunities are lost. To overcome this lack of information that can be extracted from the source code dynamic compilers perform the transformation at run-time, when all variables of the program have assigned values. However their analyses and optimizations are rather simplistic, since the time used for validation and optimization introduces an overhead to the application execution time, or perform a constant-time validation, as the observed application behavior might change, invalidating performed predictions. Hybrid analyses use run-time information and feed it back into a static compiler to help with transformation selection and validation. This works advocates for the use of hybrid analyses when optimizing loops, regions where the majority of programs spend most of their time. It proposes a framework that statically applies a sequence of complex loop transformations in a speculative manner. Based on memory access expressions it generates lightweight run-time tests to ensure that data dependencies are not violated by a given transformation. Using information collected at run-time it discards transformations that would never be used due too constraining validity tests. At the heart of this technique is a powerful quantifier elimination scheme over multivariate integer polynomials, which provides a more precise result than any other known tool. The soundness of the framework is demonstrated against a modified version of the Polybench 4.1 benchmark suite, where all data structures have been linearized. Performing the same transformations that a polyhedral optimizer would apply over the original programs, our framework generates tests that correctly validate transformations uses, either by proving correct ones or blocking invalid ones. To further illustrate the generality of our run-time test generation scheme, we demonstrate the capacity to correctly generate tests for programs with polynomial memory accesses, caused by packed triangular matrix access patterns.
N/A
NunesSampaio_Diogo.pdf (971.28 Ko) Télécharger le fichier
tel-01428425 , version 1 (14-03-2017)
tel-01428425 , version 2 (11-01-2018)
  • HAL Id : tel-01428425 , version 1
Diogo N. Sampaio. Profile Guided Hybrid Compilation. Computer Science [cs]. Université Grenoble-Alpes, 2016. English. ⟨NNT : ⟩. ⟨tel-01428425v1⟩
803 Consultations
413 Téléchargements
