Opérer les réseaux de l'Internet des Objets à l'aide de contrats de qualité de service (Service Level Agreements) - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2016
To manage IoT networks using service level agreements (SLA)
With the growing use of distributed wireless technologies for modern services, the de- ployments of dedicated radio infrastructures do not enable to ensure large-scale, low-cost and reliable communications. This PhD research work aims at enabling an operator to deploy a radio network infrastructure for several client applications, hence forming the In- ternet of Things (IoT). We evaluate the benefits earned by sharing an architecture among different traffic flows, in order to reduce the costs of deployment, obtaining a wide cove- rage through efficient use of the capacity on the network nodes. We thus need to ensure a differentiated Quality of Service (QoS) for the flows of each application. We propose to specify QoS contracts, namely Service Level Agreements (SLAs), in the context of the IoT. SLAs include specific Key Performance Indicators (KPIs), such as the transit time and the delivery ratio, concerning connected devices that are geographically distributed in the environment. The operator agrees with each client on the sources and amount of traffic for which the performance is guaranteed. Secondly, we describe the fea- tures needed to implement SLAs on the operated network, and we organize them into an SLA management architecture. We consider the admission of new flows, the analysis of current performance and the configuration of the operator’s relays. Based on a robust, multi-hop technology, IEEE Std 802.15.4-2015 TSCH mode, we provide two essential elements to implement the SLAs : a mechanism for the monitoring of the KPIs, and KAUSA, a resource allocation algorithm with multi-flow QoS constraints. The former uses existing data frames as a transport medium to reduce the overhead in terms of communication resources. We compare different piggybacking strategies to find a tradeoff between the performance and the efficiency of the monitoring. With the latter, KAUSA, we dedicate adjusted time-frequency resources for each message, hop by hop. KAUSA takes into account the interference, the reliability of radio links and the expected load to improve the distribution of allocated resources and prolong the network lifetime. We show the gains and the validity of our contributions with a simulation based on realistic traffic scenarios and requirements.
Avec l’utilisation grandissante des technologies distribuées sans fil pour la modernisa- tion des services, les déploiements d’infrastructures radio dédiées ne permettent plus de garantir des communications fiables, à grande échelle et pour un bas coût. Cette thèse vise à permettre à un opérateur de déployer une infrastructure de réseau radio pour plusieurs applications clientes de l’Internet des Objets (IoT). Nous étudions la mutualisation d’une architecture pour différents flux de trafic afin de rentabiliser le déploiement du réseau en partageant la capacité des nœuds et une large couverture. Nous devons alors garantir une Qualité de Service (QoS) différenciée pour les flux de chaque application. Nous proposons de spécifier des contrats de QoS nommés Service Level Agreements (SLA) dans le domaine de l’IoT. Ceux-ci définissent les indicateurs clés de performance (KPI) de délai de transit et de taux de livraison pour le trafic provenant d’objets connec- tés distribués géographiquement. Dans un second temps, nous détaillons les fonctionnalités nécessaires à la mise en œuvre des SLA sur le réseau opéré, sous la forme d’une archi- tecture de gestion de SLA. Nous envisageons l’admission de nouveaux flux, l’analyse des performances courantes et la configuration des relais de l’opérateur. Sur la base d’une technologie robuste, multi-saut, IEEE Std 802.15.4-2015 mode TSCH, nous proposons un mécanisme d’observation de réseau permettant de vérifier les différents KPI. Nous utilisons les trames de données existantes comme support de collecte afin de réduire le surcoût en termes de ressources de communication. Nous comparons différentes stratégies de piggybacking afin de trouver un compromis entre la performance et l’efficacité de l’observation. Puis nous détaillons KAUSA, un algorithme d’allocation de ressources sous contraintes de QoS multi-flux. Nous dédions des ressources temps-fréquences ajustées saut-par-saut pour chaque message. KAUSA prend en compte les interférences, la fiabilité des liens radio et la charge attendue afin d’améliorer la répartition des ressources allouées et ainsi prolonger la durée de vie du réseau. Nous montrons les gains et la validité de nos contributions par simulation, sur la base de scénarios réalistes de trafic et d’exigences.
Manuscrit-Doctorat-Gaillard-SLA-IoT.pdf (10.44 Mo) Télécharger le fichier
tel-01429025 , version 1 (06-01-2017)
tel-01429025 , version 2 (08-01-2017)
tel-01429025 , version 3 (09-01-2017)
tel-01429025 , version 4 (29-03-2018)
  • HAL Id : tel-01429025 , version 2
Guillaume Gaillard. Opérer les réseaux de l'Internet des Objets à l'aide de contrats de qualité de service (Service Level Agreements). Réseaux et télécommunications [cs.NI]. INSA Lyon, 2016. Français. ⟨NNT : ⟩. ⟨tel-01429025v2⟩
947 Consultations
2111 Téléchargements
