Nouvelles approches diagnostiques du choc anaphylactique aux curares - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2016
New diagnostic approaches for anaphylaxis dependent on neuromuscular blocking agents
Diagnosis of intra-anesthetic acute hypersensitivity reactions (AHR) is challenging because of elevated incidences of differential diagnoses. Risk factors remain mostly unknown and there is no reliable clinical sign to help physicians in establishing a rapid diagnosis. In 25% of cases, immunologic exploration cannot identify the culprit agent through the exploration of the IgE-mediated pathway. Several animal and human studies suggest a role of IgG in the physiopathology of anaphylaxis, which could explain these uncharacterized AHR. This PhD has focused on two cohorts of patients: the first cohort allowed the exploration of phenotypic links in relation to bronchospasm occurrence; the second cohort analyzed clinical markers of severe AHR and the alternative pathway involving IgG against neuromuscular blocking agents (NMBA). Analysis of risk factors identified a NMBA as the culprit agent of the intra-anesthetic AHR to be the only factor statistically associated with bronchospasm. We propose that a hypocapnia below 20 mmHg may be a novel and useful tool for physicians for the rapid diagnosis of severe intra-anesthetic AHR. Among the second cohort of patients, NMBA-specific IgG were identified and associated with clinical severity, suggesting that they may participate in the severity of NMBA-AHR in association with IgE. The chemical structure of a given NMBA may dictate the mechanism of anaphylaxis to this particular NMBA: an IgE/IgG-pathway for succinylcholine and rocuronium, whereas atracurium may be rather linked to spontaneous histamine release mechanisms. Altogether, our results might improve diagnosis efficacy at the time of the AHR and during immunologic explorations.
Etablir le diagnostic d'une réaction d'hypersensibilité aiguë (RHA) peropératoire est difficile du fait de l'incidence supérieure des diagnostiques différentiels. Les facteurs de risques en sont mal établis. Il n'existe pas de signe clinique fiable aidant à un diagnostic rapide. Alors que 25% des explorations immunologiques classiques ne mettent pas en évidence un mécanisme IgE-médié, des études animales et humaines suggèrent un rôle des IgG dans ces RHA non caractérisées. Ce travail s'est basé sur deux cohortes de patients : la première pour étudier des phénotypes en lien avec l'apparition d'un bronchospasme, la seconde pour analyser des marqueurs diagnostiques au bloc opératoire et explorer un mécanisme alternatif impliquant les IgG. La survenue d'un bronchospasme au cours d'une RHA peropératoire n'est pas associée à un antécédent d'asthme mais au curare comme agent étiologique. La mise en évidence de la valeur diagnostique d'une hypocapnie inférieure à 20 mmHg dans le caractère sévère de la RHA devrait aider les cliniciens à l'établissement rapide du diagnostic. La présence d'IgG spécifiques anti-curares était associée à la survenue d'une RHA sévère suggérant une participation des IgG à la gravité de la RHA en association avec les IgE. En fonction du curare administré, le mécanisme de la RHA semble différent : implication d'anticorps (IgE et/ou IgG) dans 90% pour succinylcholine et rocuronium mais uniquement 50% pour atracurium suggérant une importante contribution de l'histamino-libération dans ces réactions. L'ensemble de ces travaux devraient permettre d'améliorer les performances diagnostiques en temps réel et à distance lors de la survenue d'une RHA peropératoire.
these_archivage_9903485o.pdf (6.64 Mo) Télécharger le fichier
tel-01452781 , version 1 (02-02-2017)
  • HAL Id : tel-01452781 , version 1
Aurélie Gouel-Chéron. Nouvelles approches diagnostiques du choc anaphylactique aux curares. Immunologie. Université Pierre et Marie Curie - Paris VI, 2016. Français. ⟨NNT : 2016PA066289⟩. ⟨tel-01452781⟩
521 Consultations
912 Téléchargements
