Carrier profiling of ZnO nanowire structures by scanning capacitance microscopy and scanning spreading resistance microscopy - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2016
Profilage porteur de structures de nanofils ZnO par microscopie à capacité de balayage et microscopie à dispersion
Lin Wang
Based on atomic force microscope (AFM), scanning capacitance microscopy (SCM) and scanning spreading resistance microscopy (SSRM) have demonstrated high efficiency for two dimensional (2D) electrical characterizations of Si semiconductors at nanoscale and then have been extensively employed in Si-based structures/devices before being extended to the study of some other semiconductor materials. However, ZnO, a representative of the third generation semiconductor material, being considered a promising candidate for future devices in many areas, especially in opto-electronic area, has rarely been addressed. Recently, extensive research interests have been attracted by ZnO NWs for future devices such as LED, UV laser and sensor. Therefore, a good understanding of electrical properties of the NWs is in need. In this context, this thesis work is dedicated to the 2D electrical characterization of ZnO NWs with the focus of carrier profiling on this kind of nanostructure in the effort of their p-type doping. For this purpose, a planarization process has been developed for the NWs structure in order to obtain an appropriate sample surface and perform SCM/SSRM measurements on the top of the NWs. For quantitative analysis, Ga doped ZnO multilayer staircase structures were developed serving as calibration samples. Finally, residual carrier concentrations inside the CBD and MOCVD grown ZnO NWs are determined to be around 3×10^18 cm^-3 and 2×10^18 cm^-3, respectively. The results from SCM/SSRM characterization have been compared with that from macroscopic C-V measurements on collective ZnO NWs and the differences are discussed. In addition to carrier profiling on NWs structure, applications of SCM/SSRM on some other ZnO-based nanostructures are also investigated including ZnO:Sb films, ZnO/ZnO:Sb core-shell NWs structure, ZnO/ZnMgO core-multishell coaxial heterostructures.
Ce travail de thèse porte sur l'application des techniques Scanning Capacitance Microscopy (SCM) et Scanning Spreading Resistance Microscopy (SSRM) pour la caractérisation électrique de nanofils de ZnO avec l'objectif d'en déterminer le dopage par profilage des porteurs libres suite à des essais de dopage de type p. Afin de pouvoir utiliser un référentiel planaire nécessaire à ces mesures par sonde locale, un procédé de remplissage par dip-coating et de polissage a été spécialement développé sur des champs de nanofils quasi-verticaux. De plus, dans le but de parvenir à un étalonnage des mesures SCM et SSRM, nous avons conçu et fait fabriquer des échantillons étalons de dopage de type n, contenant des niveaux de Ga en escalier de densité variable de 2×10^17 à 3×10^20 cm^-3. Les mesures sur des coupes transversales de ces deux de structures multicouches ont permis, pour la première fois sur ZnO d'établir un étalonnage des mesures SCM et SSRM et de déterminer le dopage intrinsèque électriquement actif de couches 2D nanométriques, résultat difficilement atteignable par d'autres techniques d'analyse. Des résultats inattendus de concentration résiduelle de porteur de l'ordre de 2×10^18 et 3×10^18 cm^-3 ont été trouvés sur les nanofils de ZnO crus par MOCVD et par CBD respectivement. Outre la caractérisation électrique microscopique des nanofils par SCM et SSRM, des techniques macroscopiques classiques ont été utilisées pour caractériser des assemblées importantes de nanofils de ZnO. L'origine de la difference entre les résultats de deux genres de technique a été discutée. Nous avons aussi étudié les effets des dopages ex-situ par diffusion du phosphore (procédé SOD) et des dopages in situ par incorporation d'antimoine (Sb) pendant la croissance MOCVD. Les résultats majeurs sont obtenus pour l'antimoine, en utilisant des couches ZnO: Sb 2D et des nanofils cœur-coquille ZnO/ZnO: Sb, ou l'hypothèse d'une compensation partielle du dopage n résiduel par un centre accepteur créé par le dopage Sb semble pouvoir être établie raisonnablement.
these.pdf (16.52 Mo) Télécharger le fichier
tel-01494694 , version 1 (23-03-2017)
  • HAL Id : tel-01494694 , version 1
Lin Wang. Carrier profiling of ZnO nanowire structures by scanning capacitance microscopy and scanning spreading resistance microscopy. Electronics. Université de Lyon, 2016. English. ⟨NNT : 2016LYSEI031⟩. ⟨tel-01494694⟩
289 Consultations
318 Téléchargements
