Impacts du changement climatique sur la phénologie du Pinot noir en Bourgogne - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2013
Climate change impact on Pinot noir phenology in Burgundy
Cédric Cuccia
  • Fonction : Auteur
  • PersonId : 781706
  • IdRef : 199605246
The viticulture is an important economic and cultural sector in Burgundy. The current climate change raises a number of issues including its impact on crops. In this thesis, the idea is to develop a methodology to address the problem: what are the potential impacts of changes in temperature on the phenology of Pinot noir in Burgundy for years 2031-2048?The evolution of temperatures in Burgundy since 1961 is characterized by a positive temperature shift at the end of the 1980s followed by a period where the temperature increases of about 1.5 ° C.One of the interests of this thesis is to develop, following a strategy developed during the thesis, a spatial database conducted over the period 1989-2009 to estimate the ability of the WRF model to reproduce the climate Burgundy by disaggregating large scale data. The model reproduces satisfactorily the seasonal and spatial variability in global climate despite bias (cold on the Tx and hot on the Tn).To regionalize the climate change, WRF was used to disaggregate data from the scenario SRES/A2 on the periods 1970-1987 and 2031-2048. After being evaluated and inter-compared three phenological models, using average temperatures data to simulate the dates of occurrence of phenological stages of Pinot Noir, have been applied to these decompositions.The impact of warming temperatures on the horizon 2031-2048 (SRES/A2), estimated at 1.35 ° C on average, is characterized by an earlier flowering and veraison of about 7 and 15 days respectively. The interstadial duration is also reduced of about 5 days.
La vitiviniculture est un secteur économique et culturel important en Bourgogne. L’actuel changement climatique soulève diverses questions notamment sur son impact sur les cultures. Dans cette thèse, l’idée est d’élaborer une méthodologie afin de répondre à la problématique : quels seront les impacts possibles des changements de températures sur la phénologie du Pinot noir en Bourgogne à l’horizon 2031-2048 ?L’évolution des températures en Bourgogne depuis 1961 est caractérisée par un saut positif de température à la fin des années 1980 suivi par une période où la température augmente d’environ 1,5°C.L’un des intérêts de cette thèse réside dans l’élaboration, en suivant une stratégie élaborée durant la thèse, d’une base de données spatialisée réalisée sur la période 1989-2009 afin d’estimer la capacité du modèle WRF à reproduire le climat bourguignon en désagrégeant des données climatiques de large échelle. Le modèle reproduit de façon satisfaisante le cycle saisonnier et la variabilité spatiale climatique globale aux biais près (froid sur les Tx et chauds sur les Tn).Pour régionaliser le changement climatique, WRF a été utilisé pour désagréger des données issues du scénario SRES/A2 sur les périodes 1970-1987 et 2031-2048. Après avoir été évalués et intercomparés trois modèles phénologiques utilisant les données de températures moyennes pour simuler les dates d’occurrence des stages phénologiques du Pinot noir, ont été appliqués sur ces désagrégations.L’impact de l’augmentation des températures à l’horizon 2031-2048 (SRES/A2), estimée à 1,35°C en moyenne, se caractérise par une précocité de la floraison d’au moins 7 jours et une précocité de la véraison d’au moins 15 jours. La durée interstade est également diminuée de l’ordre de 5 jours.
these_A_CUCCIA_Cedric_2013.pdf (22.52 Mo) Télécharger le fichier
tel-01495511 , version 1 (25-03-2017)
  • HAL Id : tel-01495511 , version 1
Cédric Cuccia. Impacts du changement climatique sur la phénologie du Pinot noir en Bourgogne. Géographie. Université de Bourgogne, 2013. Français. ⟨NNT : 2013DIJOS094⟩. ⟨tel-01495511⟩
650 Consultations
970 Téléchargements
