Guided wave radiation in a finite-sized metallic or composite plate-like structure for its non-destructive testing
Rayonnement des ondes ultrasonores guidées dans une structure mince et finie, métallique ou composite, en vue de son contrôle non-destructif
Different models are developed to provide generic tools for simulating nondestructive methods relying on elastic guided waves applied to metallic or composite plates. Various inspection methods of these structures exist or are under study. Most of them make use of ultrasonic sources of finite size; all are sensitive to reflection phenomena resulting from the finite size of the monitored objects. The developed models deal with transducer diffraction effects and edge reflection. As the interpretation of signals measured in guided wave inspection often uses the concept of modes, the models themselves are explicitly modal. The case of isotropic plates (metal) and anisotropic (multilayer composites) are considered; a general approach under the stationary phase approximation allows us to consider all the cases of interest. For the first, the validity of a Fraunhofer-like approximation leads to a very efficient computation of the direct and reflected fields radiated by a source. For the second, special attention is paid to the treatment of caustics. The stationary phase approximation being difficult to generalize, a model (so-called “pencil model”) of more geometrical nature is proposed with a high degree of genericity. It chains terms of isotropic or anisotropic propagation and terms of interaction with a boundary. The equivalence of the stationary phase approximation and the pencil model is demonstrated in the case of the radiation and reflection in an isotropic plate, for which an experimental validation is proceeded.
Différents modèles sont développés de façon à constituer des outils génériques pour la simulation de méthodes de contrôle non-destructif par ondes élastiques guidées de plaques métalliques ou composites. Diverses méthodes de contrôle de ces structures existent ou sont à l’étude. La plupart font appel à des sources ultrasonores de taille finie ; toutes sont confrontées aux phénomènes de réflexion résultant de la taille finie des objets contrôlés. Les modèles développés traitent des phénomènes de diffraction associés aux sources et de réflexion sur un bord de plaques. Comme l’interprétation des signaux mesurés lors de contrôle par ondes guidées fait souvent appel à la notion de modes guidés, les modèles sont eux-mêmes modaux. Les cas de plaques isotropes (métalliques) et anisotropes (composites multicouches) sont considérés ; une approche générale suivant l’approximation de la phase stationnaire permet de traiter tous les cas d’intérêt. Pour les premiers, la validité d’une approximation de type Fraunhofer permet de traiter très efficacement les champs directs et réfléchis rayonnés par une source. Pour les derniers, une attention particulière est portée sur le traitement des caustiques. La méthode de la phase stationnaire étant difficile à généraliser, un modèle de pinceau, de nature plus géométrique, est proposé présentant un haut degré de généricité. Il met en cascade des termes de propagation en milieu isotrope ou anisotrope et d’interaction avec une frontière. L’équivalence de la méthode de la phase stationnaire au modèle de pinceau est démontrée pour le rayonnement et la réflexion dans une plaque isotrope, cas faisant l’objet d’une validation expérimentale.
