Développement de ligands multivalents de nature glycomimétiques dirigés contre les récepteurs lectines de type-C - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2016
Development of glycomimetic-based multivalent ligands targeting C-type lectin receptors
The innate and acquired immunity components work together to provide efficient protection of organisms. Dendritic cells, sentinel cells of the immunity, are able to capture pathogens through their receptors on the surface and they can present the antigens to lymphocytes T in order to stimulate specific adaptive immune responses. Among these receptors, there is a family named C-type lectin receptors (CLRs), which has an important role in the recognition of pathogenic oligosaccharide motifs. CLRs can be hijacked by many pathogens including HIV. DC-SIGN, one of the CLRs, interacts with the virus and promotes its dissemination. Unlike DC-SIGN, langerin, another CLR, has a protective role against the HIV infection. In this context, DC-SIGN became a promising therapeutic target but it shares ligand specificities with langerin.This work aims to develop highly specific antagonists against DC-SIGN in order to compete with the multivalent glycosylated gp120 protein of HIV. Using the study of the two lectins binding sites as starting point, a rational approach has been exploited to develop highly selective glycomimetics against DC SIGN. The SPR technique was used to investigate multivalent platforms with different valencies as well as ligand presentation in space. The amazing improvement of the affinity observed in some cases can be linked to different mechanisms of multivalent interactions, leading to an avidity phenomenon. On a selected scaffold (RODs), we characterized the different mechanisms responsible for the affinity and/or avidity gains, using a combination of different biophysical techniques (SPR, ITC, fluorescence polarization, AUC). In this work, we highlighted that the topology of this structure can influence the mechanisms of interactions. Overall, different multivalent ligands showed unique affinities for DC-SIGN, reaching the nanomolar affinity range, and they represent the best inhibitors to date.Finally, another CLR has been recently identified as one of the protein involved in the HIV infection as well as DC-SIGN. In a future perspective of glycomimetic development, structural and functional characterization has been done on this new actor involved in the HIV issue.
Les composantes innée et acquise de l'immunité travaillent ensemble pour assurer une protection efficace de l'organisme. Les cellules dendritiques, cellules sentinelles de l’immunité capturent via des récepteurs de surface les agents pathogènes et les présentent aux lymphocytes T pour stimuler les réponses immunitaires adaptatives spécifiques. Une famille de ces récepteurs, nommée Récepteurs Lectines de type C (CLRs) ont un rôle important dans la reconnaissance de motifs oligosaccharides des pathogènes. Leurs fonctions sont parfois détournées par certains pathogènes à leur avantage et notamment le VIH. La reconnaissance du virus par DC-SIGN, une des CLRs, favorise la dissémination du virus. A l’inverse, la langerine, autre CLR, est considérée comme une barrière naturelle au VIH. Ainsi, DC-SIGN est devenue une cible thérapeutique prometteuse mais sa reconnaissance des ligands osidiques est largement partagée par la langerine.Ce travail vise à développer des antagonistes de DC-SIGN spécifiques et de hautes affinités permettant de rivaliser avec la présentation multivalente des glycosylations de gp120 du VIH avec DC-SIGN. Une approche rationnelle a été employée dans le développement de ligands glycomimétiques hautement sélectifs pour DC-SIGN à partir de l’étude du site de liaison des deux CLRs. Puis, des plates-formes de présentations de ces glycomimétiques, de valences et de géométries différentes, sont comparées par SPR. Les améliorations spectaculaires d'affinités parfois observées sont liées à différents mécanismes d’interactions multivalentes responsables d’un phénomène d’avidité.Sur une des architecture de présentation sélectionnée (RODs), un travail de caractérisation fine des mécanismes responsables de ce gain d’affinité et/ou d’avidité a été conduit par la combinaison de plusieurs techniques biophysiques (SPR, ITC, polarisation de fluorescence et AUC). L’influence de la topologie de cette structure sur les mécanismes d’interactions est ainsi mise en évidence. Par les travaux menés, plusieurs ligands multivalents ont montré des affinités sans précédent pour DC SIGN atteignant des affinités du nanomolaire et représentant les meilleurs inhibiteurs connus à ce jour.Associé au développement d’antagonistes multivalents, une CLR (DCIR) a été identifiée récemment comme impliquée dans la dissémination du VIH, comme DC¬SIGN. Dans une perspective future de développement de glycomimétique, des travaux ont été menés sur la caractérisation structurale et fonctionnelle de ce nouvel acteur dans la problématique VIH.
PORKOLAB_2016_archivage_2.pdf (35.66 Mo) Télécharger le fichier
tel-01497502 , version 1 (28-03-2017)
  • HAL Id : tel-01497502 , version 1
Vanessa Porkolab. Développement de ligands multivalents de nature glycomimétiques dirigés contre les récepteurs lectines de type-C. Biophysique. Université Grenoble Alpes, 2016. Français. ⟨NNT : 2016GREAV013⟩. ⟨tel-01497502⟩
541 Consultations
459 Téléchargements
