The role of the microstructure in granular material instability - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2016
Le rôle de la microstructure dans l'instabilité de matériau granulaire
Granular materials consist of dense pack of solid grains and a pore-filling element such as a fluid or a solid matrix. The grains interact via elastic repulsion, friction, adhesion and other surface forces. External loading leads to grain deformations as well as cooperative particle rearrangements. The particle deformations are of particular importance in many industry applications and research subjects, such as powder metallurgy and soil mechanics. The response of granular materials to external loading is complex, especially in case when failure occurs: the mode of the failure can be diffuse or localized, and the development of specimen pattern can be drastically different when the specimen can no longer sustain external loading. In this thesis, a thorough numerical analysis based on a discrete element method is carried out to investigate the macroscopic and microscopic behavior of granular materials when a failure occurs. The numerical simulations include the vanishing of the second-order work instability criterion to detect failure. Furthermore, it is proved that the vanishing of second-order work coincides with the change from a quasi-static regime to a dynamic regime in the response of the specimen. Then, microstructure evolution is investigated. Evolution of force-chains and grain-loops are investigated during the deformation process until reaching the failure. The second-order work is once again taken into account to elucidate the local aspect that governs the failure, taking place at the particle scale. The collapse of the discrete specimen when it turns from quasi-static to dynamic regime is accompanied with a burst in kinetic energy. This rise of kinetic energy occurs when the internal stress cannot balance with the external loading when a small perturbation is added to the boundary, resulting in a difference between the internal and external second-order works of the system. The mesostructures have a symbiosis relationship with each other and their evolution decides the macroscopic behavior of the discrete system. The distribution of the collapse of force-chain correlates with the vanishing of the second-order work at the grain scale. The mesostructures play an important role in the instability of granular media. The second-order work can be used as an effective criterion to detect the instability of the system on both the macroscale and microscale (grain scale).
Les matériaux granulaires se composent de grains solides et d’un constituant remplissant les pores, tel qu’un fluide ou une matrice solide. Les grains interagissent au travers de répulsions élastiques, auxquelles s’ajoutent des mécanismes de friction, d’adhérence et d’autres forces surfaciques. La sollicitation externe conduit à la déformation des grains ainsi qu’à des réarrangements de particules. Les déformations des milieux granulaires sont d’une importance capitale dans de nombreuses applications industrielles et dans la recherche, comme par exemple dans la métallurgie des poutres ou en mécanique des sols. La réponse des matériaux granulaires sous chargement externe est complexe, en particulier lorsqu’une rupture se produit: le mode de rupture peut être diffus ou localisé, et l’aspect de peut varier drastiquement lorsque celui-ci ne peut plus soutenir la charge externe. Dans le cadre de cette thèse, une analyse numérique basée sur une méthode des éléments discrets est réalisée pour étudier les comportements macroscopique et microscopique des matériaux granulaires à la rupture. Ces simulations numériques prennent en compte le critère du travail du second ordre afin de prédire la rupture. De plus il est montré que l’annulation du travail du second ordre coïncide avec la transition d’un régime statique vers un régime dynamique. Ensuite, le comportement matériaux granulaires est analysé à l’échelle micro-structurelle. L’évolution des chaines des forces et des cycles des grains est étudiée durant le processus de déformation jusqu’à la rupture. Le travail du second ordre est également pris en compte pour examiner l’aspect local qui régit la rupture à l’échelle locale. L’effondrement de l’échantillon discret quand il passe du régime quasi-statique vers le régime dynamique est accompagné d’une bouffée d’énergie cinétique. Cette augmentation de l’énergie cinétique est générée lorsque la contrainte interne ne permet pas d’équilibrer la force externe sous l’action d’une petite perturbation, ce qui entraîne une différence entre les travaux du second ordre interne et externe du système. Les mésostructures démontrent une relation symbiotique entre elles, et leur évolution gouverne le comportement macroscopique du système discret. La distribution de l’effondrement des chaînes de forces est parfaitement corrélée avec l’annulation du travail du second ordre à l’échelle de particules. Les mésostructures jouent un rôle important dans l’instabilité des milieux granulaires. Le travail du second ordre peut être utilisé comme un critère pertinent et robuste pour détecter l’instabilité du système que ce soit à l’échelle macroscopique ou microscopique (échelle de particule).
These_NGUYEN-Hien_DocINSA.pdf (20.63 Mo) Télécharger le fichier
tel-01497828 , version 1 (29-03-2017)
tel-01497828 , version 2 (22-02-2018)
  • HAL Id : tel-01497828 , version 1
Nho Gia Hien Nguyen. The role of the microstructure in granular material instability. Structural mechanics [physics.class-ph]. Université de Lyon, 2016. English. ⟨NNT : ⟩. ⟨tel-01497828v1⟩
188 Consultations
62 Téléchargements
