Physiological and molecular studies of Mucor adaptation to cheese matrices
Etudes physiologiques et moléculaires de l'adaptation des Mucor aux matrices fromagères
In the cheese industry context, Mucor species exhibit an ambivalent behavior, as some species are essential technological organisms contributing to the required organoleptic characteristics of some cheeses while some others can be spoiling agents. The present study aimed at better understanding this ambivalence and investigating the putative adaptation mechanisms to cheese existing in Mucor technological species. Morphology and radial growth of 7 representative Mucor species: technological, contaminant and non-cheese related (plant endophyte) species were monitored on different media (synthetic, cheese-mimicking media and cheese) in function of key parameters for cheese manufacture (temperature, aw, pH). Cardinal values were determined on synthetic medium and as a result a predictive model was proposed and validated on cheese matrices for the temperature parameter. Interestingly, cheese technological species exhibited higher optimal growth rates on cheese related matrices than on synthetic media, while the opposite was observed for non-technological species. A comparative proteomic approach allowed unraveling the main metabolic pathways playing a role in growth of 4 of the 7 studied strains on both synthetic medium and cheese-mimicking medium. This proteomic study also highlighted the occurrence of 35 proteins specifically expressed by the technological strains M. lanceolatus UBOCC-A-109153 on the cheese-mimicking medium. Putative competitive and adaptative advantages of these hypothetical adaptation markers will be tested through additional investigations.
Dans le contexte fromager, les champignons filamenteux du genre Mucor ont un rôle ambivalent. En fonction du fromage considéré, ils peuvent être assimilés à des microorganismes d’altération responsables de défauts de fabrication ou au contraire contribuer au développement des qualités organoleptiques des produits. Dans le cadre de ce travail, nous avons souhaité confirmer et objectiver la dichotomie classiquement faite en industrie fromagère entre espèces technologiques et espèces contaminantes, et investiguer les mécanismes d’adaptation potentiels mis en oeuvre chez les espèces technologiques. La morphologie et la croissance radiale de 7 souches représentatives d’espèces technologiques, contaminantes et non-fromagères (endophyte) de Mucor ont été étudiées sur différents milieux (synthétique, mimant le fromage et fromager) en fonction de facteurs clés du processus de production des fromages (température, aw, pH). Les valeurs cardinales de croissance ont été déterminées sur milieu synthétique, un modèle prédictif a été proposé et validé sur matrices fromagères pour le facteur température et la meilleure faculté de croissance des souches technologiques sur milieux fromagers par rapport au milieu synthétique a été démontrée. Une approche de protéomique comparée a permis de décrire les voies métaboliques mises en jeu par 4 de ces souches dans les deux types d’environnement, fromager et non-fromager, et 35 protéines spécifiquement surexprimées par la souche technologique M. lanceolatus UBOCC-A-109153 sur milieu mimant le fromage ont été identifiées. Les avantages compétitifs associés à ces potentiels marqueurs d’adaptation vont faire l’objet d’investigations complémentaires.
These-2016-SICMA-Biologie_sante-MORIN_SARDIN_Stephanie.pdf (17.79 Mo)
Télécharger le fichier
