Spectroscopie diélectrique hyperfréquence de cellules individualisées sous électroporation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2017
Microwave dielectric spectroscopy of single cells under electroporation
Electroporation is a physical process that consists in applying electric field pulses to transiently or permanently permeabilize the plasma membrane. This phenomenon is of great interest in the clinical field as well as in the industry because of its various applications, in particular electrochemotherapy which combines electrical pulses with the administration of a cytotoxic molecule in the treatment of tumors. The evaluation of this phenomenon is raditionally carried out using optical and biochemical methods (microscopy, flow cytometry, biochemical test). They are very effective but require the use of a wide range of fluorochromes and markers, which can be laborious and costly to implement, while being invasive to the cells. In recent years, the development of new biophysical tools for the study of electroporation has taken place, such as dielectrophoresis and impedance spectroscopy (low frequency). In addition to the ease of implementation, these methods are of interest in the study of membrane modifications of the cell. Hence the advantage of operating beyond the GHz, in the range of microwaves, for which the cytoplasmic membrane becomes transparent and the intracellular content is exposed. The extraction of the relative permittivity as a result of the electromagnetic field / biological cell interaction then reflects the cell state. This technique, microwave dielectric spectroscopy, is a relevant method for analyzing the effects of electroporation on cell viability. Moreover, it does not require any use of the exogenous molecules (non-invasive) and the measurements are directly carried out in the culture medium of the cells. Two objectives were defined during this thesis whose work is located at the interface between three scientific fields: cellular biology, microwave electronics and micro-technologies. The first objective concerns the transposition of conventional electroporation to the micrometric scale, which has shown an efficiency as efficient as the first. The second part of the work concerns the study by HighFrequency dielectric spectroscopy of cells subjected to different electrical treatments (combined or not with a cytotoxic molecule). This work presents a statistical power and shows a very good correlation (R2> 0.94) with standard techniques used in biology, which biologically validates the HF analysis method in the context of electroporation. This work also shows that microwave dielectric spectroscopy proves to be a powerful technique capable of revealing cell viability following chemical and / or electrical treatment. They open the way to 'non-invasive' analysis by hyper-frequency dielectric spectroscopy of electroporated cells in situ.
L'électroporation est un procédé physique qui consiste à appliquer des impulsions de champ électrique pour perméabiliser de manière transitoire ou permanente la membrane plasmique. Ce phénomène est d'un grand intérêt dans le domaine clinique ainsi que dans l'industrie en raison de ses diverses applications, notamment l'électrochimiothérapie qui combine les impulsions électriques à l'administration d'une molécule cytotoxique, dans le cadre du traitement des tumeurs. L'analyse de ce phénomène est traditionnellement réalisée à l'aide des méthodes optique et biochimique (microscopie, cytométrie en flux, test biochimique). Elles sont très efficaces mais nécessitent l'utilisation d'une large gamme de fluorochromes et de marqueurs dont la mise en œuvre peut être laborieuse et coûteuse tout en ayant un caractère invasif aux cellules. Durant ces dernières années, le développement de nouveaux outils biophysiques pour l'étude de l'électroporation a pris place, tels que la diélectrophorèse et la spectroscopie d'impédance (basse fréquence). Outre une facilité de mise en œuvre, ces méthodes représentent un intérêt dans l'étude des modifications membranaires de la cellule. De là vient l'intérêt d'opérer au-delà du GHz, dans la gamme des micro-ondes, pour laquelle la membrane cytoplasmique devient transparente et le contenu intracellulaire est exposé. L'extraction de la permittivité relative suite à l'interaction champ électromagnétique/cellules biologiques reflète alors l'état cellulaire. Cette technique, la spectroscopie diélectrique hyperfréquence, se présente comme une méthode pertinente pour analyser les effets de l'électroporation sur la viabilité cellulaire. De plus, elle ne nécessite aucune utilisation des molécules exogènes (non-invasivité) et les mesures sont directement réalisées dans le milieu de culture des cellules. Deux objectifs ont été définis lors de cette thèse dont les travaux se situent à l'interface entre trois domaines scientifiques : la biologie cellulaire, l'électronique hyperfréquence et les micro-technologies. Le premier objectif concerne la transposition de l'électroporation conventionnelle à l'échelle micrométrique, qui a montré une efficacité aussi performante que la première. La deuxième partie du travail concerne l'étude par spectroscopie diélectrique HyperFréquence de cellules soumises à différents traitements électriques (combinés ou non à une molécule cytotoxique). Ces travaux présentent une puissance statistique et montrent une très bonne corrélation (R2 >0 .94) avec des techniques standards utilisées en biologie, ce qui valide 'biologiquement' la méthode d'analyse HF dans le contexte d'électroporation. Ces travaux montrent en outre que la spectroscopie diélectrique hyperfréquence s'avère être une technique puissante, capable de révéler la viabilité cellulaire suite à un traitement chimique et/ou électrique. Ils ouvrent la voie à l'analyse 'non-invasive' par spectroscopie diélectrique HyperFréquence de cellules électroporées in-situ.
2017TOU30011B.pdf (6.37 Mo) Télécharger le fichier
tel-01499406 , version 1 (31-03-2017)
tel-01499406 , version 2 (20-02-2018)
  • HAL Id : tel-01499406 , version 2
Amar Tamra. Spectroscopie diélectrique hyperfréquence de cellules individualisées sous électroporation. Ingénierie biomédicale. Université Paul Sabatier - Toulouse III, 2017. Français. ⟨NNT : 2017TOU30011⟩. ⟨tel-01499406v2⟩
552 Consultations
1196 Téléchargements
