Robust classifcation methods on the space of covariance matrices. : application to texture and polarimetric synthetic aperture radar image classification - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2017
Classification robuste sur l'espace des matrices de covariance : application à la texture et aux images de télédétection polarimétriques radar à ouverture synthétique
In the recent years, covariance matrices have demonstrated their interestin a wide variety of applications in signal and image processing. The workpresented in this thesis focuses on the use of covariance matrices as signatures forrobust classification. In this context, a robust classification workflow is proposed,resulting in the following contributions.First, robust covariance matrix estimators are used to reduce the impact of outlierobservations, during the estimation process. Second, the Riemannian Gaussianand Laplace distributions as well as their mixture model are considered to representthe observed covariance matrices. The k-means and expectation maximization algorithmsare then extended to the Riemannian case to estimate their parameters, thatare the mixture's weight, the central covariance matrix and the dispersion. Next,a new centroid estimator, called the Huber's centroid, is introduced based on thetheory of M-estimators. Further on, a new local descriptor named the RiemannianFisher vector is introduced to model non-stationary images. Moreover, a statisticalhypothesis test is introduced based on the geodesic distance to regulate the classification false alarm rate. In the end, the proposed methods are evaluated in thecontext of texture image classification, brain decoding, simulated and real PolSARimage classification.
Au cours de ces dernières années, les matrices de covariance ont montré leur intérêt dans de nombreuses applications en traitement du signal et de l'image.Les travaux présentés dans cette thèse se concentrent sur l'utilisation de ces matrices comme descripteurs pour la classification. Dans ce contexte, des algorithmes robustes de classification sont proposés en développant les aspects suivants.Tout d'abord, des estimateurs robustes de la matrice de covariance sont utilisés afin de réduire l'impact des observations aberrantes. Puis, les distributions Riemannienne Gaussienne et de Laplace, ainsi que leur extension au cas des modèles de mélange, sont considérés pour la modélisation des matrices de covariance.Les algorithmes de type k-moyennes et d'espérance-maximisation sont étendus au cas Riemannien pour l'estimation de paramètres de ces lois : poids, centroïdes et paramètres de dispersion. De plus, un nouvel estimateur du centroïde est proposé en s'appuyant sur la théorie des M-estimateurs : l'estimateur de Huber. En outre,des descripteurs appelés vecteurs Riemannien de Fisher sont introduits afin de modéliser les images non-stationnaires. Enfin, un test d'hypothèse basé sur la distance géodésique est introduit pour réguler la probabilité de fausse alarme du classifieur.Toutes ces contributions sont validées en classification d'images de texture, de signaux du cerveau, et d'images polarimétriques radar simulées et réelles.
ILEA_IOANA_2017_CORR.pdf (34.45 Mo) Télécharger le fichier
tel-01511645 , version 1 (21-04-2017)
  • HAL Id : tel-01511645 , version 1
Ioana Ilea. Robust classifcation methods on the space of covariance matrices. : application to texture and polarimetric synthetic aperture radar image classification. Other. Université de Bordeaux; Universitatea tehnică (Cluj-Napoca, Roumanie), 2017. English. ⟨NNT : 2017BORD0006⟩. ⟨tel-01511645⟩
364 Consultations
103 Téléchargements
