Synthèses et analyses structurales d’oligomères d’ATCs : une nouvelle famille de γ-aminoacides hétérocycliques pour la conception de foldamères - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2015
Syntheses and structural analyses of ATCs oligomers : a new family of heterocyclic γ-aminoacids for foldamers conception
The work described herein is devoted to the synthesis and the structural characterization of a new family of heterocyclic constrained γ-amino acids, named ATCs (4-Amino-(methyl)-1,3-Thiazole-5-Carboxylic acids). These building-blocks are built around a thiazole ring inserted between the Cα-Cβ carbons allowing the limitation of the ζ dihedral angle value to 0°. The presence of two diversification points both on the γ asymmetric carbon and on the position 2 of the aromatic ring, allows a large structural diversification of the ATCs. Series of oligomers consisting in dimers, tetramers and hexamers soluble in halogenated solvents, alcools and water have been synthesized according to peptide chemistry. The conformations of the sequences have been studied by various NMR experiments associated to modelling studies led under NMR constraints. The ATC oligomers adopt a right 39 helical shape, owning a pitch of 11.8 Å which has been confirmed by crystallography. The helix is stabilized by a conserved hydrogen bond pattern between CO(i)…NH(i+2) occurring all along the sequence axis. Circular dichroism measures have been done to check the conformational stability of the architectures. In the second part of the manuscript, we demonstrate by NMR and theoretical computing that when included in a short peptide sequence, ATCs could act as turns. The derived application consists in optimizing the biological behaviour of the ATC moiety as a turn mimetic thanks to the design and the antibacterial evaluation of a gramicidin S analogue. Based on our knowledge about the three-dimensional structure of ATC oligomers, the last part of this work deals with our efforts to develop inhibitors of protein-protein interaction STAT6-NCoA-1.
Le travail décrit dans ce manuscrit est consacré à la synthèse et à la caractérisation structurale d'une nouvelle famille de γ-amino acides hétérocycliques contraints, les ATCs (acides 4-Amino-(méthyl)-1,3-Thiazole-5-Carboxyliques). Ces monomères sont construits autour d'un noyau thiazole inséré entre les carbones Cα-Cβ permettant de limiter la valeur de l'angle dièdre ζ à 0°. La présence de deux points de substitution, sur le carbone γ asymétrique et en position 2 du noyau aromatique, autorise une large diversification structurale des ATCs. Des séries d'oligomères, i.e. dimères, tétramères et hexamères solubles dans les solvants organiques halogénés, dans les alcools et dans l'eau ont été synthétisées par couplages peptidiques. La conformation adoptée par ces séquences a été déterminée en solution par RMN 1D et 2D associées à des techniques de modélisation sous contraintes RMN. Nous avons montré que les oligomères d'ATCs s'arrangeaient en hélices 39 droites, présentant un pas de 11,8 Å. La conformation hélicoïdale est stabilisée par un réseau de liaisons hydrogène de type CO(i)…NH(i+2) s'établissant tout au long de la séquence, faisant entrer les oligomères d'ATCs dans le monde des foldamères. Des mesures de dichroïsme circulaire ont permis d'apprécier la stabilité conformationnelle des édifices et l'analyse à l'état solide par diffraction des rayons X a confirmé l'arrangement observé par RMN. Dans une seconde partie nous avons étudié le rôle structurant d'un motif ATC placé au sein d'une petite séquence peptidique. Nous montrons au travers d'expériences RMN et de calculs théoriques que la configuration du monomère d'ATC conditionne la conformation de peptides hybrides αγαα en solution. En termes d'application nous décrivons l'utilisation du motif ATC comme mime de coude pour concevoir un analogue fonctionnel de la gramicidine S, un cyclodécapeptide symétrique antibactérien. La dernière partie de ce travail concerne nos efforts pour développer, à partir des connaissances acquises quant à la structure tridimensionnelle des oligomères d'ATCs, des inhibiteurs de l'interaction protéine-protéine STAT6-NCoA-1.
2015_MATHIEU_archivage.pdf (13.03 Mo) Télécharger le fichier
tel-01513215 , version 1 (24-04-2017)
  • HAL Id : tel-01513215 , version 1
Loic Mathieu. Synthèses et analyses structurales d’oligomères d’ATCs : une nouvelle famille de γ-aminoacides hétérocycliques pour la conception de foldamères. Polymères. Université Montpellier, 2015. Français. ⟨NNT : 2015MONT3514⟩. ⟨tel-01513215⟩
192 Consultations
323 Téléchargements
