Contribution de la future mission altimétrique à large fauchée SWOT pour la modélisation hydrologique à grande échelle - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2017
Contribution of the wide-swath altimetry mission SWOT to improve large-scale hydrological modeling
Scientific objective of this PhD work is to improve water fluxes estimation on the continental surfaces, at interanual and interseasonal scale (from few years to decennial time period). More specifically, it studies contribution of remotely-sensed measurements to improve hydrology model. Notably, this work focuses on the incoming SWOT mission (Surface Water and Ocean Topography, launch scheduled for 2021) for the study of the continental water cycle at global scale, and using the land surface model ISBA-TRIP. In this PhD work, I explore the potential of satellite data to correct both input parameters of the river routing scheme TRIP and its state variables. To do so, a data assimilation platform has been set to assimilate SWOT virtual observation as well as discharge estimated from real nadir altimetry data. Beforehand, it was necessary to do a sensibility analysis of TRIP model to its parameters. The aim of such study was to highlight what are the most impacting parameters on SWOT-observed variables and therefore select the ones to correct via data assimilation. The sensibility analysis (ANOVA) has been led on TRIP main parameters. The study has been done over the Amazon basin. The results showed that the simulated water levels are sensitive to local geomorphological parmaters exclusively. On the other hand, the simulated discharges are sensitive to upstream parameters (according to the TRIP river routing network) and more particularly to the groundwater time constant. Finally, water anomalies present sensitivities similar to those of the water levels but with more pronounced temporal variations. These results also lead me to do some choices in the implementation of the assimilation scheme and have been published. Therefore, in the second part of my PhD, I focused on developing a data assimilation platform which consists in an Ensemble Kalman Filter (EnKF). It could either correct the model input parameters or directly its state. A series of twin experiments is used to test and validate the parameter estimation module of the platform. SWOT virtual-observations of water heights and anomalies along SWOT tracks are assimilated to correct the river manning coefficient, with the possibility to easily extend to other parameters. First results show that the platform is able to recover the “true” Manning distribution assimilating SWOT-like water heights and anomalies. In the state estimation mode, daily assimilation cycles are realized to correct TRIP river water storage initial state by assimilating ENVISAT-based discharge. Those observations are derived from ENVISAT water elevation measures, using rating curves from the MGB-IPH hydrological model (calibrated over the Amazon using in situ gages discharge). Using such kind of observation allows going beyond idealized twin experiments and also to test contribution of a remotely-sensed discharge product, which could prefigure the SWOT discharge product. The results show that discharge after assimilation are globally improved : the root-mean-square error between the analysis discharge ensemble mean and in situ discharges is reduced by 28 \%, compared to the root-mean-square error between the free run and in situ discharges (RMSE are respectively equal to 2.79 x 103 m3/s and 1.98 x 103 m3/s).
L'objectif scientifique de ce travail de thèse est d'améliorer l'estimation des flux d'eau à la surface des continents, à l'échelle saisonnière et interannuelle (de quelques années à décennale). En particulier, il s'agit d'étudier l'apport de données satellites, notamment de la future mission SWOT (Surface Water and Ocean Topography, lancement prévu en 2021), pour l'étude de la partie continentale du cycle de l'eau à l'échelle globale, à l'aide du modèle global de surfaces continentales ISBA-TRIP (Intéractions Sol-Biosphère-Atmosphère/Total Runoff and Integrating Pathways). Dans ce travail de thèse, j'explore le potentiel des données d’altimétrie satellitaire, pour corriger certains paramètres du modèle de routage de rivière TRIP et aussi pour corriger ses variables d'état. Pour ce faire, une plateforme d'assimilation de données virtuelles SWOT, mais aussi de données d'altimètres nadirs actuels a été mise en place. Mais avant l'assimilation de ces données de télédétection, il a été nécessaire de faire une analyse de sensibilité du modèle TRIP à ses paramètres, pour déterminer quels paramètres ont le plus d'influence sur les observables SWOT et qui donc pourront être corrigés. L'analyse de sensibilité (ANOVA) a alors été menée sur les principaux paramètres de TRIP. L'analyse de sensibilité a été menée sur le bassin de L'Amazone et les résultats ont été publiés. Les résultats ont montré que les hauteurs d'eau simulées sont sensibles aux paramètres géomorphologiques locaux exclusivement tandis que les débits simulés sont sensibles à l'ensemble des paramètres amont (selon le réseau de routage TRIP) et surtout au paramètre lié au temps de résidence des eaux souterraines. Enfin, les anomalies de hauteurs présentent des sensibilités similaires aux hauteurs d'eau mais avec des variations temporelles plus marquées. Ces résultats nous ont permis de faire les choix algorithmiques dans le cadre de l'assimilation de données. Ensuite, je me suis concentrée sur le développement de la maquette d'assimilation de données consistant en un Filtre de Kalman d'Ensemble (EnKF) et permet de faire soit de l'estimation de paramètres, soit de l'estimation d'état. La maquette en « estimation de paramètres » est testée et validée par une série d'expériences jumelles. On a assimilé des pseudo-observations de hauteurs et d'anomalies d'eau le long des traces du satellite SWOT, afin de corriger les coefficients de Manning du lit de la rivière, avec possibilité d'étendre à d'autres paramètres. Les premiers résultats montrent que la maquette est capable de retrouver la bonne distribution des coefficients de Manning en assimilant les hauteurs d'eau et les anomalies. Pour l'estimation d'état, on réalise des étapes d'assimilation journalières pour corriger le stock d'eau initial (condition initiale du modèle), en assimilant des débits estimés à partir de séries altimétriques de côtes d'eau ENVISAT. A partir de courbe de tarage hauteurs d'eau-débits calibrées sur le bassin de l'Amazone avec le modèle hydrologique MGB-IPH, les côtes d'eau ont été transformées en « débits altimétriques » que l'on assimile alors dans la maquette. Ces expériences d'estimation d'état nous permettent de sortir du cadre idéalisé des expériences jumelles en assimilant des données réelles, mais nous permet aussi de tester l'apport d'un premier jeu de données de débits provenant de mesures satellites, qui préfigure le futur produit de débit SWOT. Les résultats montrent que les erreurs sur le débits sont globalement améliorées : le run libre donne un RMSE de 2,79x103 m3/s (73,6 %) par rapport aux données in situ disponible sur le bassin et le run corrigé un RMSE de 1,98 x 103 m3/s (53,9 %).
CharlotteEmery_these.pdf (25.19 Mo) Télécharger le fichier
tel-01523481 , version 1 (16-05-2017)
tel-01523481 , version 2 (25-05-2018)
  • HAL Id : tel-01523481 , version 1
Charlotte Emery. Contribution de la future mission altimétrique à large fauchée SWOT pour la modélisation hydrologique à grande échelle. Interfaces continentales, environnement. Université Toulouse 3 Paul Sabatier (UT3 Paul Sabatier), 2017. Français. ⟨NNT : ⟩. ⟨tel-01523481v1⟩
547 Consultations
384 Téléchargements
