The heparan sulfate sulfotranferase 3-OST3A (HS3ST3A) : an enzyme involved in the maturation of glycosaminoglycans as a novel tumor regulator in breast cancer
L’héparane sulfate 3-O-sulfotransférase 3A (3-OST3A) : une enzyme de maturation des glycosaminoglycanes en tant que nouveau régulateur tumoral dans le cancer du sein
Heparan sulfate proteoglycans (HSPG) are ubiquitous macromolecules located at the cell plasma membrane and in extracellular matrices playing a key role in the control of cell-matrix interactions and in the tumor micro-environment. Their biosynthesis is performed by a complex enzymatic machinery involving glycosyltransferases and sulfotransferases, the latter adding a sulfate group at different residue positions of the polysaccharide chain. These modifications provide to the HSPG the ability to interact with many ligands such as growth factors and their receptors, and to regulate multiple pathophysiological processes such as cell proliferation and survival, angiogenesis and tumor development. I focused on a sulfotransferase family, the heparan sulfate 3-O-sulfotransferases (HS3STs) responsible for a rare, terminal modification of HS chains. Specifically, we investigated the HS3ST3A isoform whose role in tumor development has been previously demonstrated by our team. Here I explored the role of HS3ST3A in breast cancer. My studies demonstrate that HS3ST3A gene is epigenetically regulated in a panel of breast cancer cell lines. Cell proliferation and apoptosis assays in cellulo showed that HS3ST3A exerts an oncogenic or tumor suppressor effect in a cell-dependent context. A clinical study performed in a cohort of breast cancer patients showed that a high expression level of HS3ST3A in tumors is associated with reduced relapse-free survival in HER2+ patients. For the first time, we report a functional role of HS3ST3A as a tumor regulator of breast cancer cells behavior and this study allows considering it as a prognostic marker of the HER2 breast cancer evolution. The last part of my work attempted to understand the mechanisms that explain the deleterious consequences of the high expression level of HS3ST3A on the aggressiveness of HER2+ breast cancer. In this regard, my results suggested that the HS3ST3A may induce HER2 receptor activation following the formation of the ternary complex HS 3-O-sulphated/FGF-7/FGFR2IIIb in SKBR3 (HER2+) cells
Les protéoglycanes à héparane-sulfates (HSPGs) sont des macromolécules ubiquitaires situées à la surface des cellules et au sein des matrices extracellulaires jouant un rôle clé dans le contrôle des interactions cellules-matrice et du micro-environnement tumoral. Leur biosynthèse est assurée par une machinerie enzymatique complexe impliquant des glycosyltransférases et sulfotransférases, lesquelles ajoutent des motifs sulfatés en différentes positions des résidus de la chaîne glucidique. Ces modifications confèrent aux HSPGs la capacité d’interagir avec de nombreux ligands comme les facteurs de croissance et leurs récepteurs permettant de réguler divers processus physiopathologiques tels que la prolifération et la survie cellulaires, l’angiogenèse et le développement tumoral. J’ai focalisé mon étude sur une famille de sulfotransférases, les 3-O-sulfotransférases (3-OSTs) responsables d’une modification rare et terminale des chaînes de HS et en particulier sur l’isoforme 3A (3-OST3A) dont le rôle dans le développement tumoral a été précédemment mis en évidence par notre équipe. L’objectif de ce travail de thèse est d’explorer le rôle de la 3-OST3A dans la régulation du développement du cancer du sein. Ces travaux mettent en évidence que le gène 3-OST3A est régulé épigénétiquement dans un panel de lignées cellulaires cancéreuses mammaires. Les tests cellulaires de prolifération et d’apoptose montrent que la 3-OST3A exerce une action oncogénique ou suppresseur de tumeur dépendante de la signature moléculaire des cellules cancéreuses mammaires. Au niveau clinique, un fort taux d’expression de la 3-OST3A dans les tumeurs est corrélé négativement avec la survie des patientes atteintes d’un cancer du sein de sous-type HER2+. Ces travaux sont les premiers à mettre en évidence un rôle fonctionnel de la 3-OST3A en tant que régulateur du comportement tumoral des cellules cancéreuses mammaires et permettent de l’envisager comme marqueur pronostique de l’évolution du sous-type de tumeur mammaire HER2. La poursuite de cette étude a pour objectif de comprendre les mécanismes qui expliquent les conséquences délétères de la forte expression de la 3-OST3A sur l’agressivité du cancer du sein HER2+. Mes résultats suggèrent que la 3-OST3A induirait l’activation du récepteur HER2 par une voie dépendante de la formation du complexe ternaire HS 3-O-sulfatés/FGF-7/FGFR2IIIb dans les cellules SKBR3, un modèle de cellules cancéreuses mammaires surexprimant le récepteur HER2 responsable du caractère agressif du cancer du sein HER2+
