Effet de la dérive génétique et de la sélection sur la durabilité de la résistance des plantes aux virus - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2016
Effect of genetic drift and selection on plant resistance durability to viruses
Plants can be fully protected from their pathogens when they carry major resistance genes, but the efficiency of these genes is limited by the emergence and spread of adapted, resistance-breaking pathogen variants. This thesis studies how evolutionary forces imposed by the plants on pathogen populations may increase the durability of major resistance genes. Using plant viruses as a biological model, this thesis investigates the effect of genetic drift and selection, from the within-host to the host population level. Firstly, a stochastic epidemiological SI model at the field level showed that genetic drift could be particularly beneficial for crop yield when the fitness cost associated with virus adaptation to resistance was intermediate in susceptible plants. Then, the design and validation of a mechanistic-statistical model based on deterministic Lotka-Volterra equations and stochastic Dirichlet-multinomial processes allowed to disentangle the effects of genetic drift from those of selection on temporal data of within-host competition between virus variants. The intensities of genetic drift and selection acting on virus populations were shown to be controlled genetically by the hosts. Finally, a correlation analysis between these estimations of genetic drift and selection intensities and an experimental estimation of the durability of a major resistance gene showed that strong genetic drift during the early stages of plant infection led to an increase in resistance durability. These results open new perspectives for more durable management of plant resistance, by breeding plant varieties inducing strong genetic drift on pathogen populations
Une plante peut être totalement protégée d'un agent pathogène grâce à un gène majeur de résistance, mais ce dernier peut être rapidement contourné suite à l'apparition et à la propagation de variants pathogènes adaptés. Cette thèse s'intéresse aux mécanismes évolutifs permettant le ralentissement de ce contournement chez les virus de plantes en agissant sur deux forces évolutives majeures, la dérive génétique et la sélection, depuis le niveau de l'hôte jusqu'à celui de la parcelle. D'abord, un modèle épidémiologique stochastique de type SI au niveau d'une parcelle agricole a montré que la dérive génétique pouvait être particulièrement bénéfique au rendement agricole lorsque l'adaptation du virus au gène majeur induit un coût de fitness intermédiaire dans les plantes sensibles. Ensuite, la conception et la validation d'un modèle basé sur des équations déterministes de Lotka-Volterra et des processus stochastiques Dirichlet-multinomiaux a permis de distinguer les effets de la dérive génétique et ceux de la sélection sur des données temporelles de compétition intra-plante entre variants viraux, et de mettre en évidence le contrôle génétique de ces effets par les plantes. Enfin, une analyse de la corrélation entre ces estimations des intensités de dérive génétique et de sélection et une estimation expérimentale de la durabilité d'un gène majeur a montré qu'une forte dérive génétique lors des stades précoces de l'infection augmentait la durabilité du gène majeur. Ces résultats ouvrent des perspectives pour une gestion plus durable de la résistance des plantes, par la sélection de variétés de plantes induisant une forte dérive génétique sur les populations d'agents pathogènes
2016NICE4024.pdf (8.57 Mo) Télécharger le fichier
tel-02796455 , version 2 (28-05-2017)
tel-02796455 , version 1 (05-06-2020)
  • HAL Id : tel-02796455 , version 2
Elsa Rousseau. Effet de la dérive génétique et de la sélection sur la durabilité de la résistance des plantes aux virus. Sciences agricoles. Université Nice Sophia Antipolis, 2016. Français. ⟨NNT : 2016NICE4024⟩. ⟨tel-02796455v2⟩
828 Consultations
1434 Téléchargements
