Monitoring and Security for the RPL-based Internet of Things - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2016
Supervision et sécurité pour l'Internet des Objets utilisant le protocole de routage RPL
Anthéa Mayzaud
The growing interest for the Internet of Things (IoT) has resulted in the large scale deployment of Low power and Lossy Networks (LLN). These networks are strongly constrained in terms of resources and communicate using unstable links. In this context, existing routing protocols for traditional networks do not cope with all these constraints. The IETF has proposed a new routing protocol called RPL based on IPv6 and specifically designed for these environments. The RPL protocol is however exposed to a large variety of attacks. The deployment of security mechanisms may also be quite expensive for the nodes. Therefore, LLN networks present new challenges in terms of monitoring and security. In this thesis we propose to investigate a security-oriented monitoring approach for addressing the trade-off between security and cost in the IoT. In a first stage, we assess security threats faced by these networks by identifying and classifying attacks through a dedicated taxonomy. We also quantify the consequences of two major attacks called DAG inconsistency attacks and version number attacks causing over-consumption of node resources. We then focus our work on security solutions for RPL-based IoT. We propose a local strategy for addressing DAG inconsistency attacks. In order to detect complex attacks such as version number attacks and to complement our node-level approach, we design a security-oriented distributed monitoring architecture for RPL networks. This solution allows us to preserve constrained nodes energy by performing monitoring and detection activities on dedicated nodes. We quantify the performance and the cost of this architecture and the deployed detection modules.
L'intérêt grandissant pour l'Internet des Objets (IdO) s'est traduit par le déploiement à grande échelle de réseaux dits LLN. Ceux-ci sont fortement contraints en matière de ressources et communiquent via des liens instables. Les protocoles de routages existants pour les réseaux traditionnels ne sont pas adaptés à ces caractéristiques. L'IETF a proposé un nouveau protocole de routage appelé RPL fondé sur IPv6 et spécifiquement conçu pour ces environnements. Cependant, il est exposé à de nombreuses attaques et la mise en place de mécanismes de sécurité représente un coût considérable. Les réseaux LLN introduisent donc de nouveaux enjeux quant à leur supervision et leur sécurité. Dans le cadre de cette thèse, nous étudions une approche de supervision pour la sécurité de l'IdO tout en limitant son coût. Nous évaluons tout d'abord les menaces auxquelles sont soumis les réseaux RPL en les classifiant au travers d'une taxonomie. Nous quantifions également les conséquences de deux attaques appelées l'attaque d'incohérence DAG et l'attaque du numéro de version. Nous nous concentrons ensuite sur les solutions pour la sécurité dans les réseaux RPL. Nous proposons une stratégie locale qui limite les attaques d'incohérences DAG et nous présentons une architecture de supervision distribuée orientée sécurité pour détecter des attaques complexes comme les attaques sur le numéro de version et compléter notre approche locale. Celle-ci nous permet de préserver l'énergie des nœuds en effectuant les activités de surveillance et de détection sur des nœuds dédiés. Nous quantifions ensuite les performances de cette architecture ainsi que la stratégie de détection proposée.
DDOC_T_2016_0207_MAYZAUD.pdf (8.28 Mo) Télécharger le fichier
tel-01528815 , version 1 (29-05-2017)
  • HAL Id : tel-01528815 , version 1
Anthéa Mayzaud. Monitoring and Security for the RPL-based Internet of Things. Cryptography and Security [cs.CR]. Université de Lorraine, 2016. English. ⟨NNT : 2016LORR0207⟩. ⟨tel-01528815⟩
562 Consultations
1181 Téléchargements
