Comportements et rôles des métaux lourds au cours de la pyro-gazéification de la biomasse : études expérimentales et thermodynamiques - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2016
Behaviors and roles of heavy metals during thermochemical conversion of biomass : experimental and thermodynamic studies
Despite its availability, contaminated biomass is not widely used for energy production due to its high contamination with heavy metals. Understanding the role and behavior of those heavy metals in the pyro-gasification process is a major scientific challenge for optimizing the thermochemical valorization of contaminated biomass. For this purpose, experimental and thermodynamic approaches were used. To carry out this work, a methodology for inserting the studied metal (nickel) in the wood matrix was developed without modifying its structure and controlling the composition and homogeneity of the studied samples. The pyro-gasification tests in a fixed bed reactor have shown that nickel has a catalytic performance even at low concentrations (between 0.016 and 0.086 mol / kg wood). The analysis of gas and solid products confirmed that the increase of Ni content in the wood generated a decrease in the samples pyro-gasification temperature by 100°C. In parallel, a thermodynamic study was conducted to confirm the experimental results and improve the understanding of heavy metals behaviors during pyro-gasification reactions. Thermodynamic calculations based on the Gibbs free energy minimization of a system consisting of 28 elements provide speciation and distribution in the different phases of heavy metals, including Ni. These calculations and specific analyses have made it possible to determine the chemical and physical speciation of nickel during pyro-gasification and thus provide a theoretical basis for its catalytic activity as a function of temperature.
Malgré sa disponibilité, la biomasse de troisième génération est peu utilisée pour la production d’énergie en raison notamment de sa forte contamination en métaux lourds. Afin d’améliorer la compréhension du comportement et de l’éventuel rôle catalytique ou inhibiteur de ces métaux au cours de la pyro-gazéification, et optimiser ainsi la valorisation énergétique de la biomasse contaminée, une approche intégrée expérimentale et thermodynamique a été utilisée. Pour mener à bien ces travaux, une méthode d’insertion dans le bois du métal spécifiquement étudié pour son rôle catalytique, le nickel, a été développée. Cette méthode permet de maîtriser la composition et l’homogénéité des échantillons étudiés, sans altérer la structure du bois. Les essais de pyro-gazéification de bois brut et contaminés dans un réacteur à lit fixe, montrent que, même à faibles teneurs en nickel (entre 0,016 et 0,086 mol/ kg de bois), celui-ci a une activité catalytique importante. Les analyses des phases gaz et solides confirment que l’augmentation de la teneur en Ni dans le bois favorise les réactions de pyro-gazéification qui ont ainsi lieu à des températures plus basses (d’environ 100 °C). En parallèle, une étude thermodynamique a été réalisée afin de conforter les résultats expérimentaux et d’aider à mieux comprendre le comportement des métaux lourds présents dans le bois. Les calculs thermodynamiques, basés sur la minimisation de l’enthalpie libre de Gibbs d’un système constitué de 28 éléments (C, H, O, N et 24 éléments mineurs ou traces), fournissent la spéciation et la répartition dans les différentes phases (gaz, liquides et cendres) des métaux lourds, dont le Ni. Ces calculs, et des analyses spécifiques, ont notamment permis de déterminer la spéciation chimique et physique du nickel au cours de la pyro-gazéification et fournir ainsi une base théorique à son activité catalytique en fonction de la température.
SaidMarwaDiff.pdf (5.13 Mo) Télécharger le fichier
tel-01541337 , version 1 (19-06-2017)
  • HAL Id : tel-01541337 , version 1
Marwa Said. Comportements et rôles des métaux lourds au cours de la pyro-gazéification de la biomasse : études expérimentales et thermodynamiques. Génie des procédés. Ecole des Mines d'Albi-Carmaux, 2016. Français. ⟨NNT : 2016EMAC0015⟩. ⟨tel-01541337⟩
429 Consultations
1114 Téléchargements
