Ambisonie d'ordre élevé en trois dimensions : captation, transformations et décodage adaptatifs de champs sonores - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2016
Three Dimensional Higher Order Ambisonics : Sound Field Capture, Transformations and Adaptive Decoding
Sound field synthesis is an active research domain with various musical, multimedia or industrial applications. In the latter case, the accurate reconstruction of the sound field is targeted, which involves answering several scientific questions. Using arrays of microphones and loudspeakers, the capture, synthesis and accurate reconstruction of sound fields are theoretically possible. However, for practical applications, the arrangement of the loudspeakers and the acoustic influence of the restitution room are critical factors to consider in order to ensure the accurate reconstruction of the sound field.In this context, this thesis proposes methods and techniques for the capture, transformations and accurate reconstruction of sound fields in three dimensions based on the Higher Order Ambisonics (HOA) method. A spherical configuration for the array of microphones and loudspeakers is proposed. It follows a fifty-node Lebedev grid that enables the capture and reconstruction of the sound field up to order 5 with HOA formalism. The limitations of this approach, such as the spatial aliasing, are studied in detail.A transformation operation of the sound field is also proposed. The formulation is established in the spherical harmonics domain and enables a directional filtering on the sound field prior to the decoding step.For the reconstruction of the sound field, and original approach, also established in the spherical harmonics domain, can take into account the acoustic influence of the restitution room and the defects of the playback system. This treatment then adapts the synthesis of sound fields to the restitution room, maintaining the theoretical formalism established in free field.Finally, an experimental validation of methods and techniques developed in the thesis is made. In this context, a digital signal processing toolkit is developed. It process in real-time the microphones, ambisonics, and loudspeaker signals for the sound field capture, transformations, and decoding.
La synthèse de champs sonores est un domaine de recherche actif trouvant de nombreuses applications musicales, multimédias ou encore industrielles. Dans ce dernier cas, la reconstruction précise du champ sonore est souhaitée, ce qui implique de répondre à un certains nombre de questionnements scientifiques. À l'aide de réseaux de microphones et de haut-parleurs, la captation, la synthèse et la reconstruction précise de champs sonores sont théoriquement possibles. Seulement, pour des applications pratiques, la disposition des haut-parleurs et l'influence acoustique du lieu de restitution sont des facteurs cruciaux à prendre en compte pour s'assurer de la bonne reconstruction du champ sonore.Dans ce contexte, cette thèse de doctorat propose des méthodes et des techniques pour la captation, la transformation et la reconstruction précise de champs sonores en trois dimensions en se basant sur la méthode ambisonique d'ordre élevé. Une configuration sphérique pour le réseau de microphones et de haut-parleurs est proposée. Elle suit un maillage de Lebedev à cinquante points qui permet la captation et la reconstruction du champ sonore jusqu'à l'ordre 5 avec le formalisme ambisonique. Les limitations de cette approche, tel le repliement spatial, sont étudiés en détails.De plus, une opération de transformation du champ sonore est présentée. Elle est établie dans le domaine des harmoniques sphériques et permet d'effectuer un filtrage directionnel avant le décodage pour privilégier certaines directions dans le champ sonore, suivant une fonction de directivité choisie.Pour la reconstruction, une approche originale, également établie dans le domaine des harmoniques sphériques, permet de prendre en compte l'influence acoustique du lieu de restitution, ainsi que les défauts du système de restitution. Ce traitement permet alors d'adapter la synthèse de champs sonores au lieu de restitution, en conservant le formalisme théorique établi en champ libre.Finalement, une validation expérimentale des méthodes et des techniques développées au cours de la thèse est faite. Dans ce contexte, une suite logicielle de synthèse et traitement en temps-réel des champs sonore est développée.
TheseLECOMTE_CINES.pdf (144.32 Mo) Télécharger le fichier
tel-01544953 , version 1 (22-06-2017)
  • HAL Id : tel-01544953 , version 1
Pierre Lecomte. Ambisonie d'ordre élevé en trois dimensions : captation, transformations et décodage adaptatifs de champs sonores. Acoustique [physics.class-ph]. Conservatoire national des arts et metiers - CNAM, 2016. Français. ⟨NNT : 2016CNAM1076⟩. ⟨tel-01544953⟩
659 Consultations
251 Téléchargements
