Élaboration par ablation laser en milieu liquide de nanoparticules métalliques : caractérisation et modélisation des réponses plasmoniques des nanoparticules d’or et d’argent - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2016
Generation of metallic nanoparticles by Pulsed-Laser Ablation in Liquids : Characterization and modelling of the plasmonics responses of gold and silver nanoparticles
Metal nanoparticles (NPs) exhibit unique optical properties (OP) coming from the collective oscillations of their electrons. This effect is translated by the emergence of a band of plasmon, the characteristics which can be modulated by the size, the shape and the nature of the NPs as well as by the environment of the host. There are many methods for the preparation of NPs, and one of them is the pulsed-laser ablation in liquid (PLAL). This technique offers some advantages such as simplicity, versatility and surface NP without contamination (reducing agent residues and/or stabilizers). Its main drawbacks are the lacks of productivity and control of the NP size and shape. This work is devoted to elaboration of Ag NPs by PLAL and theoretical investigation of their OP. We give here the results about the optimization of elaboration parameters leading to obtaining reproducible and controlled distributions of Ag NPs. The OP of these NPs are measured and compared to specific physical models based on the effective medium theory (EMT). Classical EMT such as Maxwell Garnett approximation allows describing the OP of monodisperse NPs. However, conventional preparation routes unavoidably conduct to NPs showing a shape and a size distribution which induces drastic changes in the OP. A SDEMT model which considers the shape dispersion is proposed for the calculation of the effective dielectric function and absorption coefficient of colloidal solution of metal NPs in water. Contrary to the conventional theory, this model gives a better description of the measured absorption and ellispometry spectra of sample containing Ag and Au NPs
Les nanoparticules métalliques (NPs) présentent des propriétés optiques (PO) uniques provenant de l’oscillation collective de leurs électrons. Cet effet se traduit par l'émergence d'une bande plasmon dont les caractéristiques peuvent être modulées par la taille, la forme, la nature des NPs et le milieu hôte. Il existe de nombreuses méthodes pour la préparation de ces NPs, l'une d'entre elles est l'ablation laser en milieu liquide (ALML). Cette technique offre certains avantages comme la simplicité, l’adaptabilité et des NPs dépourvues de contamination. Ses principaux inconvénients sont la productivité et le contrôle de la taille et de la forme des NPs. Ce travail est consacré à l'élaboration de NPs d’Ag par l’ALML et à l'étude théorique de leurs PO. Nous donnons dans ce manuscrit, les résultats de l'optimisation des paramètres d'élaboration conduisant à l'obtention de distributions en NPs reproductibles et contrôlées. Les PO de ces NPs sont mesurées et comparées à des modèles physiques spécifiques basés sur la théorie des milieux effectifs (EMT). L'EMT, telle que le modèle de Maxwell-Garnett, permet de décrire les PO de NPs monodisperses. Cependant, les voies de préparation classiques conduisent inévitablement vers des NPs montrant une distribution de forme et de taille qui induit des changements drastiques sur leurs PO. Le modèle SDEMT est proposée pour le calcul de la fonction diélectrique effective et du coefficient d'absorption de solutions colloïdales de NPs métalliques. Contrairement à Maxwell-Garnett, ce modèle donne une meilleure description des spectres d'absorption et d’ellipsométrie mesurés sur des échantillons contenant des NPs d’Ag et d’Au
DDOC_T_2016_0320_RESANO_GARCIA.pdf (6.63 Mo) Télécharger le fichier
tel-01544984 , version 1 (22-06-2017)
  • HAL Id : tel-01544984 , version 1
Amandine Resano-Garcia. Élaboration par ablation laser en milieu liquide de nanoparticules métalliques : caractérisation et modélisation des réponses plasmoniques des nanoparticules d’or et d’argent. Matière Condensée [cond-mat]. Université de Lorraine, 2016. Français. ⟨NNT : 2016LORR0320⟩. ⟨tel-01544984⟩
296 Consultations
350 Téléchargements
