Communication térahertz sans fil à haut débit avec un transistor à haute mobilité électronique comme détecteur - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2014
High data-rate wireless terahertz communication using a High-electron-mobility transistor as detector
One of the major objectives of communication systems is the ability to transmit data at the highest possible rates. The ever-growing user demand for wireless communication already exceeds capacities of present networks.In order to solve this problem, we introduce communication systems based on terahertz (THz) high-frequency carriers, whose frequencies are high enough to support data-rates higher than a hundred of gigahertz. In particular, we are interested in the development and the integration of a high data-rate detector intended for THz wireless communication.We use a GaAs High-electron-mobility transistor (HEMT) as detector. Unlike existing detectors such as Schottky diodes, the transistor studied in this thesis offers advantages in terms of cost, compactness and performances. In particular, the output impedance is more suitable for high data-rate integrated circuits whose input impedance is 50 Ohm. We present the characterization of the detector in terms of sensitivity and modulation bandwidth, demonstrating for the first time its ability to be used for high data-rate communications. The transistor's integration, essential for real communications, is detailed.A wireless THz communication is demonstrated around 0.200 THz and 0.309 THz. For the first time, an error-free transmission at data-rates up to 8.2 Gbps is demonstrated, using a GaAs plasma wave HEMT and a 0.309 THz carrier frequency. Finally, we present new transistors with integrated antenna, allowing communications at higher data-rates and with a longer range, thanks to a better sensitivity.
Un des objectifs majeurs des systèmes de communication est de pouvoir transmettre des données aux plus hauts débits possibles. La demande croissante des utilisateurs pour la communication sans fil à haut débit excède déjà les possibilités des réseaux actuels. Afin de répondre à cette problématique, nous présentons des systèmes de communication basés sur des fréquences porteuses térahertz (THz), fréquences suffisamment élevées pour supporter des débits supérieurs à la centaine de gigahertz. En particulier, nous nous intéressons au développement et à l'intégration d'un détecteur haut débit destiné à la communication THz sans fil. Nous utilisons comme détecteur un transistor GaAs à haute mobilité électronique (HEMT). Contrairement aux détecteurs existants tels que les diodes Schottky, le transistor étudié offre des avantages en ce qui concerne le coût, la compacité et les performances. En particulier, l'impédance de sortie est mieux adaptée aux circuits intégrés hauts débits d'impédance d'entrée de 50 Ohm. Nous présentons une caractérisation de ce détecteur en sensibilité et en bande passante de modulation, démontrant pour la première fois sa capacité à être utilisé pour des communications à haut débit. L'intégration du transistor, indispensable à la réalisation de communications réelles, est détaillée. Une communication THz sans fil est démontrée à des fréquences de 0,200 THz et 0,309 THz. Pour la première fois, une transmission de données sans erreur a été démontrée jusqu'à un débit de 8,2 Gbps avec un transistor GaAs HEMT à une fréquence porteuse de 0,309 THz. Enfin, nous présentons de nouveaux transistors avec antenne intégrée permettant des communications à plus haut débit et de plus grande portée, grâce à une meilleure sensibilité.
42702_TOHME_2014_archivage_cor.pdf (5.52 Mo) Télécharger le fichier
tel-01546421 , version 1 (23-06-2017)
  • HAL Id : tel-01546421 , version 1
Lucie Juery. Communication térahertz sans fil à haut débit avec un transistor à haute mobilité électronique comme détecteur. Electronique. Université Montpellier II - Sciences et Techniques du Languedoc, 2014. Français. ⟨NNT : 2014MON20115⟩. ⟨tel-01546421⟩
352 Consultations
452 Téléchargements
