Meta-analysis applied to Multi-agent Software Engineering
Méta-analyse pour le génie logiciel des systèmes multi-agents
From a general point of view this thesis addresses an automatic path to build a solution choosing a compatible set of building blocks to provide such a solution to solve a given problem. To create the solution it is considered the compatibility of each available building block with the problem and also the compatibility between each building block to be employed within a solution all together. In the particular perspective of this thesis the building blocks are meta-models and the given problem is a description of a problem that can be solved using software using a multi-agent system paradigm. The core of the thesis proposal is the creation of a process based on a multi-agent system itself. Such a process analyzes the given problem and the available meta-models then it matches both and thus it suggests one possible solution (based on meta-models) for the problem. Nevertheless if no solution is found it also indicates that the problem can not be solved through this paradigm using the available meta-models. The process addressed by the thesis consists of the following main steps: (1) Through a process of characterization the problem description is analyzed in order to locate the solution domain and therefore employ it to choose a list of most domain compatible meta-models as candidates. (2) There are required also meta-model characterization that evaluate each meta-model performance within each considered domain of solution. (3) The matching step is built over a multi-agent system where each agent represents a candidate meta-model. Within this multi-agent system each agent interact with each other in order to find a group of suitable meta-models to represent a solution. Each agent use as criteria the compatibility between their represented candidate meta-model with the other represented meta-models. When a group is found the overall compatibility with the given problem is evaluated. Finally each agent has a solution group. Then these groups are compared between them in order to find the most suitable to solve the problem and then to decide the final group. This thesis focuses on providing a process and a prototype tool to solve the last step. Therefore the proposed path has been created using several concepts from meta-analysis, cooperative artificial intelligence, Bayesian cognition, uncertainty, probability and statistics.
Considérant un point de vue général de cette thèse aborde le problème de trouver, à partir d'un ensemble de blocs de construction, un sous-ensemble qui procure une solution à un problème donné. Ceci est fait en tenant compte de la compatibilité de chacun des blocs de construction par rapport au problème et l'aptitude d'interaction entre ces parties pour former ensemble une solution. Dans la perspective notamment de la thèse sont les blocs de construction de méta-modèles et le problème donné est une description d'un problème peut être résolu en utilisant un logiciel et d'être résolu en utilisant un système multi-agents. Le noyau de la proposition de thèse est un processus qui analyse un problème donné et puis il proposé une solution possible basée sur système multi-agents pour ce problème. Il peut également indiquer que le problème ne peut être résolu par ce paradigme. Le processus adressée par la thèse consiste en les étapes principales suivantes: (1) A travers un processus de caractérisation on analyse la description du problème pour localiser le domaine de solutions, puis choisissez une liste de candidats des méta-modèles. (2) Les caractérisations de méta-modèles candidats sont prises, ils sont définis dans plusieurs domaines de la solution. On fait la chois parmi le domaine trouvé dans la étape précédant. (3) On crée un système multi-agents où chaque agent représente un candidat méta-modèle. Dans cette société les agents interagissent les uns avec les autres pour trouver un groupe de méta-modèles qui est adapté pour représenter une solution donnée. Les agents utilisent des critères appropriés pour chaque méta-modèle à représenter. Il évalue également la compatibilité des groupes créés pour résoudre le problème de décider le groupe final qui est la meilleure solution. Cette thèse se concentre sur la fourniture d'un processus et un outil prototype pour résoudre plutôt la dernière étape de la liste. Par conséquent, le chemin proposé a été créé à l'aide de plusieurs concepts de la méta-analyse, l'intelligence artificielle de coopération, de la cognition bayésienne, incertitude, la probabilité et statistique.
