Etude des flux d'évapotranspiration en climat soudanien : comportement comparé de deux couverts végétaux au Bénin - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2014
Evapotranspiration fluxes in sudanian climate : behavior of two contrasted vegetation covers in Benin
Assessing the impact of climate and anthropic changes on the water and energy cycles, mainly rely on the quantification of the transfer between the various land covers and the atmosphere. Nevertheless the land – atmosphere interactions in the West African monsoon dynamic is not yet well understood because of the lack of observations in this region. This thesis focuses on the analysis of the sensible and latent heat fluxes under Sudanian climate. The two studied land covers are a clear forest (Bellefoungou) and a cultivated area (Nalohou), located in northern Benin, during four years (2007-2010). The study sites are a part of the hydro – meteorological AMMA – CATCH observatory.Turbulent fluxes were measured with the eddy covariance technique.The flux partitioning was investigated through the evaporative fraction (EF) and the Bowen ratio (β) at diurnal, seasonal and inter-annual scales. Surface characteristics (surface and aerodynamical conductance) and the decoupling factor were calculated to interpret the dynamic of the actual evapotranspiration.The analysis was performed according to four different stages of the monsoon cycle: dry and wet seasons drying and moistening intermediate stages. At diurnal and seasonal scales, actual evapotranspiration was always higher on the forest than on the cultivated area. It remained non zero during the dry season at Nalohou despite surface conditions which were not favorable to this process. During the wet season, after the monsoon onset, EF remained steady with a mean seasonal value of 0.75 at Bellefoungou and 0.70 at Nalohou for the four studied years. The Bowen ratio was 0.4 and 0.6 respectively, thus the sensible heat flux was significant on the two contrasted vegetation covers during the wet season. The contrasted roughness length of the two vegetation covers led to a highest aerodynamic conductance at the clear forest site. The mixed of crop/fallow was shown to be more efficient than the clear forest regarding wet season transpiration. At the inter-annual scale, no relationship can be evidenced between evapotranspiration and annual rainfall for the studied period (2007-2010), which was rather rainy. Nevertheless, the net radiation explains the main part of turbulent fluxes inter-annual variation.Finally, complete surface atmosphere decoupling was never observed. This property of the surface – atmosphere interface underlines the key role of the surface conditions in the actual evapotranspiration. Our results provide a first estimate of the latent and sensible heat fluxes over a clear forest and a mixed crop/fallow under sudanian climate. They are relevant to land surface models parametrisation or evaluation and to a robust quantification of the water resources for agriculture, the main economic activity in this region.
L'impact des modifications climatiques et de l'augmentation de la démographie sur le cycle de l'eau et de l'énergie dans la région ouest africaine passe par la quantification des échanges entre les différents couverts de la surface continentale et l'atmosphère. Toutefois, la compréhension du rôle des interactions entre la surface et l'atmosphère dans la dynamique de la mousson ouest africaine est limitée par le manque d'observations dans cette région. Cette thèse porte sur l'étude des flux turbulents, en particulier l'évapotranspiration réelle, en climat soudanien. Les deux couverts étudiés sont une forêt claire (site de Bellefoungou) et une mosaïque de culture/jachère (site de Nalohou), situés dans la région du Nord – Bénin. On dispose de quatre années de mesures (2007 à 2010). Les sites d'étude font partie de l'observatoire hydro – météorologique AMMA – CATCH.Les données de flux turbulents de l'atmosphère ont été mesurées avec la technique d'eddy covariance. La partition énergétique des flux a été examinée à travers la fraction évaporative (EF) et le rapport de Bowen (β) aux échelles diurne, saisonnière et inter-annuelle. Des caractéristiques de surface (conductance de surface et aérodynamique) et le coefficient de découplage ont été calculés pour interpréter la dynamique de l'évapotranspiration réelle.L'analyse des résultats est basée sur un découpage du cycle saisonnier suivant quatre phases du cycle de la mousson : la saison sèche, la saison humide, les phases d'humidification et d'assèchement de l'atmosphère. Aux échelles diurne et saisonnière, on montre que le taux d'évapotranspiration réelle de la forêt est toujours supérieur à celui de la mosaïque de culture/jachère quelle que soit la saison. L'évapotranspiration réelle demeure non nulle en saison sèche sur le site de Nalohou malgré les conditions de surface peu favorables à ce processus. En saison humide, après le saut de mousson, la partition énergétique des flux atteint un régime stationnaire avec une moyenne égale à 0,75 à Bellefoungou et 0,70 à Nalohou pour les 4 années étudiées. Le rapport de Bowen pris dans le même ordre est environ de 0,4 et 0,6 traduisant ainsi, en dépit des conditions humides, la part non négligeable du flux de chaleur sensible sur les deux couverts végétaux. La différence de rugosité entre les deux couverts végétaux entraîne une conductance aérodynamique nettement supérieure à Bellefoungou par rapport à Nalohou. On montre également que la végétation du site de Nalohou est plus efficace en transpiration pendant la saison humide que celle du site de Bellefoungou. A l'échelle inter-annuelle, on n'a pas pu mettre en évidence une relation entre flux de chaleur latente et pluviométrie pour les quatre années étudiées qui sont toutes des années excédentaires. Cependant nous avons observé que le rayonnement net explique la majeure partie de la variabilité inter-annuelle des flux turbulents.Enfin, nous avons également montré avec le coefficient de découplage que la surface soudanienne et l'atmosphère restent couplées toute l'année. Ce fonctionnement de l'interface surface – atmosphère reflète le rôle majeur que jouent les conditions de surface dans la variabilité saisonnière de l'évapotranspiration réelle. Les résultats issus de cette étude donnent une première estimation des flux de chaleur latente et de chaleur sensible sur une forêt claire et une mosaïque de culture/jachère en climat soudanien. Ils sont d'une importance capitale pour la paramétrisation et la validation des modèles de surface ainsi que pour la quantification robuste de la ressource en eau disponible en surface pour l'agriculture, principale activité génératrice de revenus des populations locales.
39215_MAMADOU_2014_archivage.pdf (34.33 Mo) Télécharger le fichier
tel-01548277 , version 1 (27-06-2017)
  • HAL Id : tel-01548277 , version 1
Ossénatou Mamadou. Etude des flux d'évapotranspiration en climat soudanien : comportement comparé de deux couverts végétaux au Bénin. Sciences de la Terre. Université de Grenoble; Université d'Abomey-Calavi (Bénin), 2014. Français. ⟨NNT : 2014GRENU019⟩. ⟨tel-01548277⟩
276 Consultations
234 Téléchargements
