Non volcanic tremors : observations and modeling
Les trémors non volcaniques : observations et modélisations
The vision of the seismic cycle in subduction zones has considerably evolved over the last 10 years. New discoveries has pointed the diversity of slip behaviors in these zones with aseismic slow slip called « slow slip events » (SSE) and persistent low amplitudes vibrations called « non-volcanic tremors » (NVT). The goal of this thesis is to study the non-volcanic tremors in order to characterize these new manifestations of fault zones. We used two different approaches: 1. We first observed the non-volcanic tremors in the nature in order to characterize this phenomenon. The area of interest is the Guerrero seismic gap along the Mexican subduction zone. We develop a new detection and location method based on beamforming of correlations of seismic signals. This new method exhibits some characteristics of NVT: a complex source for a single tremor episode and a correlation between the NVT episodes and the long-term peak of movement velocity in southwards direction. Moreover, the study of the consequences of the Maule earthquake on the Mexican subduction zone showed that this earthquake triggered the 2009-2010 SSE in Guerrero. This triggering of slow slip is accompanied by strong seismic tremor actvity that are first modulated by the passing waves and then associated to the SSE. 2. We model numerically and experimentally the tremors in order to better understand their physical origin and their long-term evolution. We used a very slow friction experiment that indicates a systematic correlation between slip acceleration of a slider and emission of acoustic signals that are similar to NVT. A numerical modeling of the Mexican subduction zone is also presented and shows the possibility to reproduce NVT with a critical depinning transition.
Depuis maintenant une dizaine d'années, la vision du cycle sismique en zone de subduction a beaucoup évolué. Des découvertes récentes ont mis en évidence une grande diversité des régimes de glissement dans ces zones, avec notamment des glissements asismiques transitoires appelés « séismes lents » (SSE) et des vibrations de faibles amplitudes, persistantes dans le temps, appelées « trémors non volcaniques » (NVT). Ce travail a pour objectif l'étude des trémors non volcaniques afin de caractériser ces nouvelles manifestations des zones de faille. Nous avons abordé ce problème avec deux approches distinctes :1. Observer les trémors dans le milieu naturel afin de déterminer leurs caractéristiques. La zone étudiée correspond à la lacune sismique de Guerrero le long de la subduction mexicaine. Nous avons développé une méthode de détection et de localisation des NVT au Mexique grâce à des analyses d'antennes par formation de voie sur les corrélations. Cette méthode permet de mettre en évidence cer taines caractéristiques des NVT : une complexité des sources pour un épisode de trémors, une corrélation entre les activités de NVT et les pics de vitesse des glissements lents à plus long terme. Par ailleurs, l'étude de l'impact du séisme de Maule (2010, Chili, Mw 8.8) au Mexique montre qu'il a déclenché le second sous évènement du séisme lent de 2009-2010. Ce déclenchement d'un SSE s'ac- compagne de fortes activités de trémors, modulées par les ondes du séisme de Maule dans un premier temps, puis simplement associées au SSE.2. Modéliser les trémors expérimentalement et numériquement pour mieux com- prendre leur origine physique et leurs évolutions sur le long terme. Nous avons en particulier utilisé une expérience de frottement à faible vitesse qui indique une corrélation systématique entre les accélérations d'un glissement et l'émission de signaux qui ressemblent à des NVT. Une modélisation numérique de la zone de subduction mexicaine est également présentée et montre la possibilité de reproduire des trémors en considérant une transition d'affaiblissement critique associée à un processus de décrochage.
