Le cuivre de l'Anti-Atlas, un problème complexe : synthèse des occurrences cuprifères de la boutonnière de Bou Azzer-El Graara et nouvelles données (Anti-Atlas, Maroc) - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2016
The Anti-Atlas copper, a complex problem : synthesis of copper occurrences in the Bou Azzer-El Graara inlier and new data (Anti-Atlas, Morocco)
The Anti-Atlas belt is a large geological province. It is composed by a Precambrian basement and a Neoproterozoic to Paleozoic sedimentary cover. More than 200 copper occurrences are localized in this cover. Since the 2000s, with the increase of global copper demand, these mineralizations have a great economic interest for mining company. Besides economic interests, the scientific understanding of these mineralizations in this area are not clear. It does not exist a global model to explain the formation of these deposits. Our study is focus on the Bou Azzer-El Graara inlier (central Anti-Atlas). We proposed to realize a synthesis of copper deposits in this area based on four axes: (1) a field study at the ore bodies’ scale, (2) a mineralogical and textural characterization of these mineralizations, (3) a statistical approach applied to rock total data bases of these deposits, (4) a study of fluid inclusions associated to the ore gangue minerals. Results showed that the whole of mineralizations in the Neoproterozoic to Cambrian cover have a same stockwork texture and a same mineralogy at all scales of observations and that, independently of the ore bodies morphology. This stockwork is synchronous of folded and faulted zones. It is too synchronous of Precambrian basement faults movements during the Variscan compression. These movements are link to deep brines circulations responsible of copper mineralizations localized in the Precambrian basement and in the Neoproterozoic to Cambrian cover of this inlier.
L’Anti-Atlas marocain est une vaste province géologique composée d’un socle précambrien et d’une couverture sédimentaire tardi-néoprotérozoïque à paléozoïque. Plus de 200 occurrences cuprifères sont répertoriées dans cette couverture. Avec l’augmentation de la demande mondiale en cuivre depuis les années 2000, ces minéralisations, considérées non rentables dans les années 1980, sont désormais d’intérêt économique majeur pour les compagnies minières. Outre cet intérêt économique, ces occurrences restent un mystère scientifique du point de vue de leur genèse. En effet, les quelques études existantes sur ces objets ne permettent pas d’établir un modèle métallogénique clair expliquant la formation de ces concentrations à cuivre. Notre étude est centrée sur la boutonnière de Bou Azzer-El Graara (Anti-Atlas central). Elle propose de réaliser une synthèse des minéralisations de ce secteur basée sur quatre axe : (1) une étude de terrain à l’échelle des objets minéralisés, (2) une caractérisation minéralogique et texturale des minéralisations, (3) une approche statistique appliquée aux bases de données roche totale de ces occurrences, (4) une étude des inclusions fluides des minéraux de gangue associés au cuivre. Les résultats ont montré que l’ensemble des minéralisations de la couverture avait une texture en stockwork et une minéralogie identique auto-similaire à toute les échelles d’observation, et ce indépendamment de la morphologie des corps. Ce stockwork est contemporain de zones plissées et faillées. Il est contemporain du mouvement de failles du socle Précambrien rejouant au Varisque et induisant la circulation de saumures profondes minéralisant le socle précambrien comme la couverture néoprotérozoïque à cambrienne de cette boutonnière.
hugo-bourque_3629.pdf (44.79 Mo) Télécharger le fichier
tel-01549132 , version 1 (28-06-2017)
  • HAL Id : tel-01549132 , version 1
Hugo Bourque. Le cuivre de l'Anti-Atlas, un problème complexe : synthèse des occurrences cuprifères de la boutonnière de Bou Azzer-El Graara et nouvelles données (Anti-Atlas, Maroc). Sciences de la Terre. Université d'Orléans, 2016. Français. ⟨NNT : 2016ORLE2055⟩. ⟨tel-01549132⟩
975 Consultations
1179 Téléchargements
