Wind accretion onto compact objects - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2016
Accrétion par vent sur objet compact
Ileyk El Mellah
  • Fonction : Auteur
  • PersonId : 1013827
X-ray emission associated to accretion onto compact objects displays important levels of photometric and spectroscopic time-variability. When the accretor orbits a Supergiant star, it captures a fraction of the supersonic radiatively-driven wind which forms shocks in its vicinity. The amplitude and stability of this gravitational beaming of the flow conditions the mass accretion rate responsible, in fine, for the X-ray luminosity of those Supergiant X-ray Binaries. The capacity of this low angular momentum inflow to form a disc-like structure susceptible to be the stage of well-known instabilities remains at stake. Using state-of-the-art numerical setups, we characterized the structure of a Bondi-Hoyle-Lyttleton flow onto a compact object, from the shock down to the vicinity of the accretor, typically five orders of magnitude smaller. The evolution of the mass accretion rate and of the bow shock which forms around the accretor (transverse structure, opening angle, stability, temperature profile...) with the Mach number of the incoming flow is described in detail. The robustness of those simulations based on the High Performance Computing MPI-AMRVAC code is supported by the topology of the inner sonic surface, in agreement with theoretical expectations. We developed a synthetic model of mass transfer in Supergiant X-ray Binaries which couples the launching of the wind accordingly to the stellar parameters, the orbital evolution of the streamlines in a modified Roche potential and the accretion process. We show that the shape of the permanent flow is entirely determined by the mass ratio, the filling factor, the Eddington factor and the alpha force multiplier. Provided scales such as the orbital period are known, we can trace back the observables to evaluate the mass accre- tion rates, the accretion mechanism (stream or wind-dominated) and the shearing of the inflow, tracer of its capacity to form a disc around the accretor.
L’émission X associée à l’accrétion sur un objet compact présenter une important variabilité photométrique et spectroscopique. Quand l’accréteur est en orbite autour d’une étoile Supergéante, il capture une fraction du vent stellaire supersonique qui forme des chocs dans son voisinage. L’amplitude et la stabilité de cette focalisation gravitationnelle conditionnent le taux d’accrétion de masse responsable, in fine, de la luminosité X des Binaires X Supergéantes (SgXB). La capacité de ce flot à faible moment angulaire à former un disque susceptible de présenter des instabilités est en jeu. Grâce à des setups numériques sophistiqués, nous caractérisons la structure du flot de Bondi-Hoyle-Lyttleton sur un objet compact, depuis le choc jusqu’au voisinage de l’accréteur, typiquement 5 ordres de grandeur plus petit. L’évolution du choc détaché qui se forme autour de l’accréteur (structure transverse, angle d’ouverture, stabilité, profil de température) avec le nombre de Mach est détaillé. La fiabilité de ces simulations basées sur le code hautes performances MPI-AMRVAC est étayée par la topologie de la surface sonique, en accord avec les attentes théoriques. Nous développons un modèle synthétique de transfert de masse dans les SgXB qui couple le lancement du vent, les paramètres stellaires, l’évolution orbital du flot et l’accrétion. Nous montrons que la forme du flot est entièrement détermimée par les facteur de remplissage et d’Eddington, le rapport de masse et le multiplieur de force alpha. Avec les paramètres d’échelle, nous pouvons en déduire, eg, la luminosité X, le processus d’accrétion et le cisaillement du flot.
PhD_manuscript_v6.pdf (19.15 Mo) Télécharger le fichier
tel-01569866 , version 1 (27-07-2017)
tel-01569866 , version 2 (27-07-2017)
tel-01569866 , version 3 (31-08-2017)
  • HAL Id : tel-01569866 , version 1
Ileyk El Mellah. Wind accretion onto compact objects. High Energy Astrophysical Phenomena [astro-ph.HE]. Université Paris Diderot (Paris 7) Sorbonne Paris Cité, 2016. English. ⟨NNT : ⟩. ⟨tel-01569866v1⟩
374 Consultations
142 Téléchargements
