Classical Losses in Soft Magnetic Composites using Homogenization Techniques - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2017
Modélisation semi-analytique des pertes par courants de Foucault dans les matériaux composites
Composite materials have been widely used in Electrical Engineering, and they have stimulated a growing number of scientific research, especially when it comes to energy savings. Soft Magnetic Composites (SMC) incorporate the attributes of different constituents. They can be designed to exhibit high permeability and to dissipate low Eddy Current (EC) losses compared to more conventional structures such as laminated steel. Nevertheless, electromagnetic properties of SMC are not easily determined. Numerical tools such as finite element method (FEM) are usually employed to provide a full-field description of SMC. As the microstructure has to be finely meshed, it brings significant numerical burden and instabilities. To overcome this restriction, semi-analytical homogenization methods are adapted and applied here. They consist in developing a complex permeability model. In the complex permeability model for SMC, the static magnetic permeability and EC losses are integrated respectively as the real and imaginary part of the complex permeability. Classical estimates are applied to determine the macroscopic effective magnetic permeability. A correct determination of the effective permeability, i.e. the real part of the complex permeability, is crucial for the estimate of EC losses. EC losses formulas are derived for SMC with periodic microstructure in 2D and 3D cases. Furthermore, different approaches of field averaging are employed to obtain lower and upper bounds on the EC losses in SMC. The complex permeability model is then applied to analyze a transformer structure. The magnetic field and EC losses distribution can be obtained on the equivalent homogenized transformer. The results are compared to the full-field calculations on the heterogeneous transformer. A good consistency is observed. Finally, the effect of mechanical stress on the magnetic permeability and loss property of SMC is studied, which leads to a coupled formula of EC loss density as a function of macroscopic stress and magnetic field.
L'emploi de matériaux composites dans le domaine du Génie Electrique est actuellement un sujet de recherche en plein essor, notamment pour des considérations d’économie d'énergie. Les composites magnétiques doux (SMC - Soft Magnetic Composites) intègrent les propriétés de leurs différents constituants. Ils sont conçus pour présenter une perméabilité élevée et avoir une faible densité de pertes par courants de Foucault (EC - Eddy Current) par comparaison aux structures plus classiques comme l'acier laminé. Néanmoins, la détermination des propriétés électromagnétiques des SMC n’est pas aisée. Une approche classique est d’appliquer les outils numériques tels que la méthode des éléments finis (FEM - Finite Element Method) pour obtenir une description complète du SMC. Cependant, la microstructure doit être finement maillée, ce qui représente un fardeau numérique significatif et des instabilités dans l'approche par FEM. Pour surmonter cette restriction, les méthodes d'homogénéisation semi-analytiques sont appliquées. Ce travail consiste d'abord à développer un modèle de perméabilité complexe pour SMC. La perméabilité magnétique et les pertes EC sont intégrées respectivement comme les parties réelle et imaginaire de la perméabilité complexe. La perméabilité magnétique effective macroscopique peut s’obtenir par des estimations classiques en homogénéisation. Une détermination correcte de la perméabilité effective, i.e. la partie réelle de la perméabilité complexe, est cruciale pour une estimation précise de pertes EC. Les formules de pertes EC sont dérivées pour des SMC à microstructure périodique dans les cas 2D et 3D. En outre, différentes approches s’appuyant sur différentes moyennes du champ magnétique permettent d’obtenir des limites inférieures et supérieures pour l’estimation des pertes EC dans les SMC. La perméabilité complexe ainsi obtenue est ensuite appliquée à une structure de transformateur. Le champ magnétique et la répartition des pertes EC peuvent être obtenus sur le transformateur équivalent (homogénéisé). Les résultats sont comparés aux calculs en champ complet du transformateur hétérogène. Un bon accord est observé. Enfin, on étudie l'effet des contraintes mécaniques sur la perméabilité magnétique et les pertes EC des SMC, ce qui conduit à une formule couplée de la densité de pertes EC en fonction de la contrainte macroscopique et du champ magnétique.
71870_REN_2017_diffusion.pdf (5.19 Mo) Télécharger le fichier
tel-01576559 , version 1 (23-08-2017)
  • HAL Id : tel-01576559 , version 1
Xiaotao Ren. Classical Losses in Soft Magnetic Composites using Homogenization Techniques. Electromagnetism. Université Paris Saclay (COmUE), 2017. English. ⟨NNT : 2017SACLS159⟩. ⟨tel-01576559⟩
406 Consultations
321 Téléchargements
