Modélisation de la variabilité des temps de parcours et son intégration dans des algorithmes de recherche du plus court chemin stochastique - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2016
Travel time variability modeling and integration into stochastic shortest path problem algorithms
The travel time representation has a major impact on user-oriented routing information. In particular, congestion detection is not perfect in current route planners. Moreover, the travel times cannot be considered as static because of events such as capacity drops, weather disturbances, or demand peaks. Former researches focused on dynamic travel times, i.e. that depend on departure times, in order to improve the representation details, for example concerning the periodicity of congestions. Real-time information is also a significant improvement for users aiming to prepare their travel or aiming to react to on-line events. However these kinds of model still have an important drawback : they do not take into account all the aspects of travel time variability. This dimension is of huge importance, in particular if the user risk aversion is considered. Additionally in a multimodal network, the eventual connections make the travel time uncertainty critical. In this way the current PhD thesis has been dedicated to the study of stochastic travel times, seen as distributed random variables.In a first step, we are interested in the travel time statistical modeling as well as in the travel time variability. In this goal, we propose to use the Halphen family, a probability law system previously developed in hydrology. The Halphen laws show the typical characteristics of travel time distributions, plus they are closed under addition under some parameter hypothesis. By using the distribution moment ratios, we design innovative reliability indexes, that we compare with classical metrics. This holistic approach appears to us as a promising way to produce travel time information, especially for infrastructure managers.Then we extend the analysis to transportation networks, by considering previous results. A set of probability laws is tested during the resolution of the stochastic shortest path problem. This research effort helps us to describe paths according to the different statistical models. We show that the model choice has an impact on the identified paths, and above all, that the stochastic framework is crucial. Furthermore we highlight the inefficiency of algorithms designed for the stochastic shortest path problem. They need long computation times and are consequently incompatible with industrial applications. An accelerated algorithm based on a deterministic state-of-the-art is provided to overcome this problem in the last part of this document. The obtained results let us think that route planners might include travel time stochastic models in a near future.
La représentation des temps de parcours est un enjeu influençant la qualité de l’information transmise aux usagers des réseaux de transport. En particulier, la congestion constitue un inconvénient majeur dont la prise en compte n’est pas toujours maîtrisée au sein des calculateurs d’itinéraires. De même, les évènements comme les réductions de capacité, les perturbations climatiques, ou encore les pics de fréquentation incitent à dépasser la définition statique des temps de parcours. Des travaux antérieurs se sont focalisés sur des temps dynamiques, i.e. dépendants de la date de départ, de manière à affiner le détail de la représentation, et à prendre notamment en compte le caractère périodique des congestions. La considération d’informations en temps réel est aussi une amélioration indéniable, que ce soit lors de la préparation du trajet, ou lorsqu’il s’agit de s’adapter à des perturbations rencontrées en cours de route. Ceci dit, aussi fines qu’elles soient dans les calculateurs disponibles, ces modélisations présentent un inconvénient majeur : elles ne prennent pas en compte toutes les facettes de la variabilité des temps de parcours. Cette variabilité est très importante, en particulier si l’on considère le niveau d’aversion au risque des usagers. En outre, dans un réseau multimodal, les correspondances éventuelles rendent encore plus critique l’incertitude associée aux temps de parcours. En réponse à ces enjeux, les présents travaux de thèse ont ainsi été consacrés à l’étude de temps de parcours stochastiques, i.e. vus comme des variables aléatoires distribuées.Dans une première étape, nous nous intéressons à la modélisation statistique des temps de parcours et à la quantification de leur variabilité. Nous proposons l’utilisation d’un système de lois développé dans le domaine de l’hydrologie, la famille des lois de Halphen. Ces lois présentent les caractéristiques typiques des distributions de temps de parcours, elles vérifient par ailleurs la propriété de fermeture par l’addition sous certaines hypothèses afférentes à leurs paramètres. En exploitant les ratios de moments associés aux définitions de ces lois de probabilité, nous mettons également au point de nouveaux indicateurs de fiabilité, que nous confrontons avec la palette d’indicateurs classiquement utilisés. Cette approche holistique de la variabilité des temps de parcours nous semble ainsi ouvrir de nouvelles perspectives quant au niveau de détail de l’information, notamment à destination des gestionnaires de réseaux.Par la suite, nous étendons le cadre d’analyse aux réseaux, en utilisant les résultats obtenus à l’étape précédente. Différentes lois de probabilité sont ainsi testées dans le cadre de la recherche du plus court chemin stochastique. Cette première étude nous permet de dresser un panorama des chemins identifiés en fonction du choix de modélisation. S’il est montré que le choix du modèle est important, il s’agit surtout d’affirmer que le cadre stochastique est pertinent. Ensuite, nous soulevons la relative inefficacité des algorithmes de recherche du plus court chemin stochastique, ceux-ci nécessitant des temps de calcul incompatibles avec un passage à l’échelle industrielle. Pour pallier cette difficulté, un nouvel algorithme mettant en oeuvre une technique d’accélération tirée du cadre déterministe est développé dans la dernière partie de la thèse. Les résultats obtenus soulignent la pertinence de l’intégration de modèles stochastiques au sein des calculateurs d’itinéraires.
Delhome_thesis_2016_fix_9qHo70KT.pdf (10.82 Mo) Télécharger le fichier
tel-01576746 , version 1 (23-08-2017)
  • HAL Id : tel-01576746 , version 1
Raphaël Delhome. Modélisation de la variabilité des temps de parcours et son intégration dans des algorithmes de recherche du plus court chemin stochastique. Infrastructures de transport. Université de Lyon, 2016. Français. ⟨NNT : 2016LYSET010⟩. ⟨tel-01576746⟩
434 Consultations
843 Téléchargements
