Effet des auto-anticorps anti-SRP et anti-HMGCR sur le muscle strié squelettique - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2016
Anti-SRP (signal recognition particle) and anti-HMGCR (3-Hydroxy-3-Methylglutaryl-CoA Reductase) auto-antibody effects on skeletal muscle
Immune mediated necrotizing myopathy (IMNM) is recognized as a separate entity among inflammatory myopathies. IMNM is a severe disabling muscle disease requiring prolonged combination of corticosteroid and immunosuppressive drugs. IMNM is morphologically defined by predominant muscle fiber necrosis and no or little inflammation, and is associated with important variation of the size of the fiber. However pathogenic mechanisms involved in muscle necrosis and muscle atrophy are largely unknown. IMNM may be associated with either anti-SRP or anti-HMGCR auto-antibodies (aAbs). The titer of these aAbs, targeting ubiquitous cytoplasmic proteins, is correlated with the disease activity suggesting their pathogenic role. In this thesis, we described the morphology of skeletal muscle alterations occurring in both conditions of anti-SRP+ or anti-HMGCR+ patients, studied the role of the Abs in (i) the necrosis mechanisms and the associated inflammation; (ii) by analyzing the atrophy and the regeneration mechanisms. Muscle histological analysis of anti-SRP+ and anti-HMGCR+ patients showed a random distribution of necrotic fibers that was more pronounced in anti-SRP+ patients. Creatine Phosphokinase levels; myolysis indicator, and muscle regeneration were correlated with the proportion of necrotic fibers. Inflammation was regularly observed in IMNM muscle patients. Macrophages were the most abundant but T cells densities were in a quarter of cases in the same range as myositis controls. CD68+iNOS+ macrophages and a Th-1 immune environment were also observed and involved in ongoing myophagocytosis. Of note, macrophages with alternative activation were also detected. Humoral immunity with activation of the classical pathway of the complement cascade was observed in IMNM. Positive membrane staining for SRP and HMGCR proteins, on some muscle fibers, was detected both in vitro and in muscle biopsies of IMNM patients. An important proportion of small fibers corresponding to both atrophic and regenerating fibers was observed in anti-SRP+ and anti-HMGCR+ patients. In vitro, anti-SRP and anti-HMGCR aAbs induced muscle fibers atrophy and increased the transcription of MAFbx and Trim63. In addition, the muscle fiber atrophy was associated with high level of inflammatory cytokines such TNF, IL-6 and ROS. Muscle regeneration in vitro was also affected by impairing the myoblasts fusion in presence of anti-SRP and anti-HMGCR Abs. This default was associated with a decrease production of anti-inflammatory cytokines: IL-4 and IL-13. Of note, the addition of IL-4 and/or IL-13 totally rescued the fusion. Together those data suggest that these aAbs have a pathogenic effect on muscle. Anti-SRP and anti-HMGCR are involved in muscle atrophy and affect the regeneration. The role of these aAbs in muscle damages occurring in IMNM was highlighted and emphasizes the potential interest of targeted therapies.
Les myopathies nécrosantes auto-immunes (MNAI) appartiennent au groupe des myopathies inflammatoires idiopathiques. Les MNAI sont des maladies musculaires sévères pouvant conduire à un déficit musculaire définitif et handicapant. Pour rétablir une force normale et prévenir le handicap, des traitements prolongés associant corticothérapie et immunosuppresseurs sont nécessaires. Les MNAI sont définies histologiquement par la prédominance de fibres musculaires en nécrose qui contraste avec l’absence ou la faible abondance d'inflammation musculaire. Les mécanismes impliqués dans la nécrose comme ceux impliqués dans les séquelles atrophiques sont en revanche inconnus. Les MNAI peuvent être associées à des auto-anticorps (aAc) soit anti-SRP, soit anti-HMGCR. Ces aAc ciblent des protéines cytoplasmiques ubiquitaires. Leurs titres sont corrélés avec l'activité de la maladie, suggérant ainsi le rôle pathogène de ces aAc. Dans ce travail de thèse, nous avons émis l’hypothèse que les aAc pouvaient être impliqués dans les lésions musculaires observées aux cours des MNAI anti-SRP+ et anti-HMGCR+. Durant cette étude, nous avons eu pour objectifs : (i) de caractériser et de quantifier la nécrose musculaire et l’inflammation associée, ainsi que les mécanismes physiopathologiques impliqués (rôle des aAc) ; (ii) d’analyser la régénération et l’atrophie musculaire et l’effet des aAc sur ces phénomènes. L'analyse histologique des biopsies musculaires des patients MNAI a montré que la proportion des fibres musculaires en nécrose était plus importante chez les patients anti-SRP+. Les taux sériques de créatine phosphokinase étaient corrélés avec la proportion de fibres nécrotiques, montrant ainsi que ce taux est un bon marqueur de l’activité de la maladie. De façon inattendue, une inflammation musculaire était régulièrement observée. En particulier, la densité lymphocytaire T était dans un quart des cas comparable à celle des autres myopathies inflammatoires. Cette densité cellulaire était de plus corrélée au pourcentage de fibres en nécrose. L’infiltrat inflammatoire était néanmoins composé principalement de macrophages. Des macrophages CD68+ iNOS+, impliqués dans des phénomènes de myophagocytoses dans un environnement Th-1 étaient régulièrement observés. Des macrophages avec un phénotype suggérant une activation alternative par l’immunité humorale ont aussi été observés. Dans ce sens, la présence de dépôts de complexe d’attaque membranaire à la surface des fibres musculaires, mais aussi des dépôts de C1q et d’IgG montraient l’activation de la voie classique du complément au cours des MNAI. De plus, la détection des protéines SRP et HMGCR sur certaines fibres musculaires immatures (in vitro et in vivo) suggérait le rôle pathogène des aAc. Concernant les mécanismes de régénération et les phénomènes d’atrophie musculaire, l’analyse des biopsies musculaires a révélé l’importance de l’irrégularité du diamètre des fibres avec une prédominance de petites fibres. Ces petites fibres correspondaient à la fois à des fibres en régénération et à des fibres en nécrose. In vitro, les Ac anti-SRP et anti-HMGCR induisent une atrophie musculaire en augmentant la transcription de MAFbx et Trim63. En outre, l'atrophie des fibres musculaires a été associée à un niveau élevé de cytokines inflammatoires comme TNF, IL-6 et ROS. Concernant l’étude de la régénération musculaire, in vitro, la présence des aAc réduisait la fusion des myoblastes. Ce défaut était associé à une diminution de la production de cytokines anti-inflammatoires IL-4 et IL-13. L’ajout d'IL-4 et/ou d’IL-13 permettait de corriger la fusion des myoblastes. Dans ce travail, les données recueillies convergent pour suggérer le rôle pathogène des aAc anti-SRP et anti-HMGCR dans les lésions musculaires nécrotiques mais aussi dans la régénération musculaire et l’atrophie. Ces données nouvelles soulignent l’importance de traitements ciblés au cours des MNAI.
2016PA066389.pdf (3.57 Mo) Télécharger le fichier
tel-01589654 , version 1 (18-09-2017)
  • HAL Id : tel-01589654 , version 1
Louiza Arouche-Delaperche. Effet des auto-anticorps anti-SRP et anti-HMGCR sur le muscle strié squelettique. Immunologie. Université Pierre et Marie Curie - Paris VI, 2016. Français. ⟨NNT : 2016PA066389⟩. ⟨tel-01589654⟩
540 Consultations
885 Téléchargements
