Functional integration of newborn neurons into established neuronal circuits in the zebrafish larva visual system - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2015
Intégration fonctionnelle des neurones nouveaux-nés dans des circuits déjà établis dans le système visuel de la larve de poisson zèbre
In the vertebrate brain, mechanisms leading to the incorporation of newborn neurons into already functional networks still remain poorly understood. Indeed, since most of the studies have been performed at the single-cell level, a detailed description of the circuit dynamics is lacking. To investigate this phenomenon, I have developed a pioneer methodology using the zebrafish larva as an experimental model and a multidisciplinary approach combining genetics, two-photon microscopy and optogenetics to monitor the developing activity of genetically targeted newborn neurons and the surrounding matured networks, in an intact and non-anesthetized vertebrate. Using this technique I have described for the first time, and in the time course of several days, the developmental dynamics of the functional properties of newborn neurons before and during their incorporation into the mature tectal circuit, the zebrafish most complex layered structure and highest visual center. Overall, these results suggest a developmental sequence of events during which newborn neurons capable of generating intrinsic activity dynamics first connect to their pre-synaptic sensory organ (the retina). At a second stage, the newborn neurons gradually incorporate into the tectal mature circuit showing sparse correlations with mature neurons. At a third stage, the spatial organization of the correlation between the newborn and the mature neurons is refined, becoming denser. I thus suggest that the newborn neurons first connect to a large population of sparsely located mature neurons and subsequently distant connections are pruned, permitting the newborn-labeled neuron to acquire a stable and robust functional signature (e.g. sharp receptive fields). In the recent years, treatments based on the transplantation of neural tissue have been developed to target neurodegenerative diseases such as Parkinson's disease. Because these therapies face the problem of poor survival and long-term functional incorporation, this study may provide better understanding of neuronal circuits formation and might pave the way to improve the efficiency of stem-cells-based treatments for human-brain reparation.
Au cours du développement cérébral des vertébrés, le processus permettant à des neurones nouveaux-nés de s'incorporer dans des réseaux déjà établis est mal compris. En effet, la majorité des études ayant été réalisées à l'échelle de la cellule, une description détaillée de la dynamique des circuits au cours de ce phénomène est manquante. Pour l'étudier, j'ai développé une méthode innovante utilisant la larve de poisson zèbre comme modèle expérimental et une approche pluridisciplinaire combinant la génétique, la microscopie bi-photonique et l'optogénétique pour suivre le développement de l'activité de neurones nouveaux-nés et des réseaux matures voisins dans un vertébré intacte et non-anesthésié. En utilisant cette technique j'ai décrit pour la première fois, pendant plusieurs jours consécutifs, le développement des propriétés fonctionnelles de neurones nouveaux nés avant et pendant leur incorporation dans les circuits du toit optique, la structure cérébrale la plus complexe du poisson zèbre permettant l'intégration l'information visuelle. Les résultats obtenus suggèrent une séquence de développement durant laquelle les neurones morphologiquement immatures spontanément actifs se connectent en premier à la rétine. Dans un second temps, ces neurones s'incorporant graduellement au circuit mature en montrant des corrélations avec des neurones matures éparses. Troisièmement, l'organisation spatiale des corrélations entre les neurones nouveaux-nés est raffinée et devient plus dense. Ces résultats suggèrent que les neurones nouveaux-nés se connectent dans un premier temps a une population éparse de neurones matures avant que les connections a longue distance disparaissent permettant aux neurones en développement d'obtenir une signature fonctionnelle robuste (ex. réponses restreintes spatialement). Récemment, des traitements basés sur la transplantation des tissues neuronaux ont été développées pour certaines maladies neuro-dégénératives (ex. maladie de Parkinson). Cependant ces thérapies sont actuellement limitées par le faible taux de survie et l'incorporation des neurones injectés. Ces travaux apportent une meilleure compréhension des mécanismes à l’œuvre lors de la formation de circuits neuronaux et pourront peut-être permettre d'améliorer l'efficacité des traitements utilisant des cellules souches pour réparer le cerveau humain.
2015PA066691.pdf (8.52 Mo) Télécharger le fichier
tel-01592257 , version 1 (23-09-2017)
  • HAL Id : tel-01592257 , version 1
Jonathan Boulanger-Weill. Functional integration of newborn neurons into established neuronal circuits in the zebrafish larva visual system. Neurons and Cognition [q-bio.NC]. Université Pierre et Marie Curie - Paris VI, 2015. English. ⟨NNT : 2015PA066691⟩. ⟨tel-01592257⟩
264 Consultations
195 Téléchargements
