Study of icy bodies in the solar system through two main targets of spatial exploration : the comet 67P/C-G and the satellite Europa
Etude des corps glacés du système solaire à travers deux cibles majeures de l'exploration spatiale : la comète 67P/C-G et le satellite Europe
The major part of my work focused on the study of the chemical composition of Europa’s surface. In order to provide additional insights in comparison to the results of the NIMS instrument onboard the Galileo spacecraft that orbited in the Jovian system from 1995 to 2003, a ground-based observations campaign was conducted with the infrared imaging spectrometer SINFONI on the VLT. Several observations using adaptive optics with a spatial resolution of about 160 km and a spectral resolution R = 1500 in the near-infrared were acquired and then combined. A specific data reduction pipeline was developed to build a global hyperspectral cube in surface reflectance. The linear modeling of each spectra of this cube leads to the first global abundance maps ever obtained for the surface of Europa. These maps confirm the presence of the two major species, namely water ice and hydrated sulfuric acid. The distribution of the hydrated sulfuric acid is centered on the trailing orbital hemisphere preferentially affected by a sulfur ion flux coming from the plasma torus produced by Io volcanic activity. Two surprising results were obtained. The first one concerns water ice, which crystalline form is about twice more abundant than the amorphous form according to the modeling results. This result, unexpected given the very high radiation rate on the surface, could be explained by a strong crystallinity gradient through the ice slab. However, it could also point out an endogenous activity possibly strong as first suggested by its poorly well-known cratered surface. The correlation between the crystalline grains distribution and the geomorphology seems in favor to the second hypothesis. The second result is related to the detection of chlorinated salts from the modeling of highly resolved spectra from SINFONI. Sulfates, first reported by several analyses of NIMS observations are marginal in the modeled composition, hence challenging their presence on the surface of Europa. The chloride distribution, as well as the one of the crystalline water ice, is correlated to geomorphology, potentially confirming significant endogenous contributions as the result of tectonic and cryovolcanic processes recently highlighted. The second part of my PhD was dedicated to the physical characteristics of the 67P/C-G’s cometary grains. The COSIMA instrument onboard the Rosetta orbiter allowed the collection, imaging and elemental chemical analysis of grains present in the immediate environment of 67P/C-G. An automated approach of the grains detection based on images taken by the camera "COSISCOPE" was set up and able to detect about 35.000 grains having an area of more than 100 µm² between August 2014 and May 2016. The resolution of 13.7 µm/pixel allowed to perform a detailed characterization of the shape and the structure of the grains, and the large number of detections permitted to obtain significant statistics on the size distribution and its evolution over the time. Two large families of grains have been identified: the compact grains, which represent only a small minority of grains mostly collected at the beginning of the mission, and aggregates, which have a very porous structure similar to those of IDPs and micrometeorites collected in Antarctica. The size distribution obtained follows an integrated power law in r-2.66. The comparison with the laws obtained at different scales by other instruments highlights differences that can be interpreted by ejection mechanisms depending on the size associated with a selection bias during the collection process in orbit.
La majeure partie de mon travail de thèse a porté sur l’étude de la composition chimique de la surface d’Europe. Afin d’apporter une plus-value par rapport aux résultats de l’instrument NIMS à bord de la sonde Galileo qui orbita dans le système jovien de 1995 à 2003, une campagne d’observations depuis le sol a été menée avec le spectromètre imageur infra-rouge SINFONI au VLT. Cinq observations en optique adaptative possédant une résolution spatiale d’environ 160 km et une résolution spectrale R=1500 dans le proche infra-rouge furent acquises. Une procédure complexe de réduction des données a été mise en place afin de construire un cube hyperspectral global en réflectance de la surface. La modélisation linéaire de chacun des spectres du cube a permis d’aboutir aux premières cartes d’abondances absolues jamais obtenues pour la surface d’Europe. Ces cartes confirment la présence des deux espèces majoritaires, la glace d’eau et l’acide sulfurique hydraté. La distribution de l’acide sulfurique est centrée sur l’hémisphère orbital arrière qui est préférentiellement impacté par un flux d’ions de soufre originaires du tore de plasma produit par l’activité volcanique d’Io. Cependant, deux résultats inattendus ont été obtenus. Le premier concerne la glace d’eau, dont la forme cristalline est près de deux fois plus abondante que la forme amorphe selon les résultats de la modélisation. Ce résultat, surprenant compte tenu du taux d’irradiation très élevé auquel la surface est soumise, pourrait s’expliquer par l’existence d’un fort gradient de cristallinité au sein de la couche de glace, mais aussi par l’existence d’une activité endogène relativement soutenue qui se traduit visuellement par une surface peu cratérisée, donc jeune. La corrélation entre la distribution des grains cristallins et la géomorphologie semble accréditer la seconde hypothèse. Le second résultat concerne la détection de sels chlorés à partir de la modélisation des spectres hautement résolus de SINFONI, et non de sulfates, remettant en cause les détections marginales annoncées par les observations de l’instrument NIMS/Galileo. La distribution des sels chlorés, tout comme celle de la glace d’eau cristalline, est corrélée à la géomorphologie, ce qui confirme le rôle important des apports endogènes. Des processus tectoniques et cryovolcaniques mis en évidence récemment pourraient être à l’origine de cette distribution. L’autre versant de ma thèse a été consacré aux caractéristiques physiques des grains cométaires de 67P/C-G. L’instrument COSIMA embarqué sur l’orbiter de la sonde Rosetta a permis la collecte, l'imagerie et l'analyse chimique élémentaire des grains présents dans l’environnement proche de 67P/C-G. Une approche automatisée de la détection des grains à partir des images prises par la caméra « COSISCOPE » a été mise en place et a permis de détecter environ 35000 grains ayant une surface de plus de 100 µm2 entre août 2014 et mai 2016. La résolution de 13.7 µm/pixel a rendu possible la caractérisation en détail de la forme et de la structure des grains, et le nombre important de détections a permis d’obtenir des statistiques robustes concernant la distribution en taille et l’évolution de celle-ci au cours du temps. Deux grandes familles de grains ont été identifiées : les grains compacts, qui ne représentent qu’une faible minorité des grains et qui ont été majoritairement collectés en début de mission, et les agrégats, qui ont une structure très poreuse similaire à celle des IDPs et des micrométéorites collectées en Antarctique. La distribution en taille obtenue suit une loi de puissance intégrale en r-2.66. La comparaison avec des lois obtenues à des échelles différentes par d’autres instruments met en évidence des différences qui peuvent être interprétées par des mécanismes d’éjection dépendant de la taille associés à un biais du processus de collecte en orbite.
