Caractérisation et origine des magmas alcalins et des fluides sous le massif volcanique du Jbel Saghro, Anti Atlas, Maroc - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2015
Characterization and origin of alcaline magmas and fluids beneath the Jbel Saghro volcanic field, Anti Atlas, Morocco
René Chamboredon
  • Fonction : Auteur
  • PersonId : 784456
  • IdRef : 204656656
Volatile-rich, silica-undersaturated alkaline lavas record the important role of fluids during fluid-rock and magma-rock interactions in the mantle, which are key processes to understand the dynamics of the convective mantle and lithosphere-asthenosphere interactions in intracontinental settings. The aim of this thesis is to bring new constraints on the genesis of alkaline magmas by characterizing the crystallization conditions, the source and the partial melting processes taking part in the genesis of olivine nephelinites, pyroxene nephelinites and basanites from the Jbel Saghro volcanic field in the Moroccan Anti Atlas.The petrological and geochemical study of rocks and minerals coupled with the analysis of fluid inclusions constrains the pre-eruptive conditions of Saghro nephelinites to 1.7–2.2 GPa and ~1350 °C. Minerals show that nephelinitic magmas are rich in volatile elements (Cl, F, S), and fluid inclusions indicate that magmas were saturated with a CO2-rich fluid at pressures > 590 MPa. The various mineralogical assemblages and the presence of peridotite xenoliths suggest a rapid ascent for olivine nephelinites and more complex processes at depth for pyroxene nephelinites.Fractional crystallization and partial melting modelling of Saghro mafic lavas indicate that they are low-degree melts (0.6–2.5 %) of an amphibole-bearing carbonated peridotite enriched in incompatible elements, at the garnet-spinel transition (~80–85 km). Saghro nephelinites display a temporal evolution with a slight increase of the degree of melting and a decrease of the amount of residual amphibole from the oldest (olivine nephelinites, 9.6 Ma) to the most recent (pyroxene nephelinites, 2.9 Ma). Basanites form a system that is independent from nephelinites and are slightly higher-degree melts. Important variations in their chemical composition suggest variable amounts of fractional crystallization during ascent.The peculiar characteristics of Saghro nephelinites and basanites (enrichment in incompatible elements, negative anomalies in K, Zr, Hf and Ti, high Ca/Al and Zr/Hf ratios) indicate that their source was affected by carbonatitic metasomatism. The influence of this metasomatism is stronger for pyroxene nephelinites than for olivine nephelinites. These results suggest fluid-rock interactions beneath the Northwest African Craton, leading to the formation of a metasomatized mantle by CO2-rich carbonatitic components at the lithosphere-asthenosphere transition. The origin of the metasomatism inducing source enrichment and the formation of amphibole veins could be attributed to the melting of relict subducted oceanic lithosphere. The relatively low melting temperatures (< 1350 °C) suggest the absence of a thermal anomaly beneath the Jbel Saghro, and thus support a lithosphere delamination model as precursor of Saghro volca0,3nism. However, the increasing degree of partial melting over time, also observed in the Middle Atlas, together with the isotopic and geochemical similarities with Canary Islands alkaline lavas does not allow us to discard the influence of a deviation of the Canary mantle plume beneath northwest Africa.
Les laves alcalines sous-saturées riches en éléments volatils sont les marqueurs du rôle important des fluides dans le manteau et des interactions fluide-roche et magma-roche, processus clés pour comprendre la dynamique du manteau convectif et les interactions asthénosphère-lithosphère en domaine intracontinental. L’objectif de cette thèse est d’apporter de nouvelles contraintes sur la genèse des magmas alcalins en caractérisant les conditions de cristallisation, la source et les processus de fusion partielle à l’origine des néphélinites à olivine, des néphélinites à pyroxène et des basanites du champ volcanique du Jbel Saghro dans l’Anti-Atlas marocain.L’étude pétrologique et géochimique des roches et des minéraux, couplée à l’analyse des inclusions fluides a permis de contraindre les conditions pré-éruptives des néphélinites de Saghro à 1.7–2.2 GPa et ~1350 °C. Les minéraux montrent que les magmas néphélinitiques sont riches en éléments volatils (Cl, F, S), et les inclusions fluides indiquent que les magmas étaient saturés en fluide riche en CO2 à des pressions > 590 MPa. Les différents assemblages minéralogiques des néphélinites et la présence de xénolites péridotitiques suggèrent une ascension rapide des néphélinites à olivine et des processus plus complexes en profondeur pour les néphélinites à pyroxène.La modélisation des processus de cristallisation fractionnée et de fusion partielle des laves mafiques de Saghro a permis de déterminer qu’elles sont issues de faibles taux de fusion partielle (0.6–2.5 %) d’une péridotite carbonatée enrichie en éléments incompatibles, au niveau de la transition grenat–spinelle (~80–85 km) et en présence d’amphibole. Les néphélinites de Saghro montrent une évolution temporelle avec une légère augmentation du taux de fusion et une diminution de la quantité d’amphibole au résidu des plus anciennes (néphélinites à olivine, 9.6 Ma) aux plus récentes (néphélinites à pyroxène, 2.9 Ma). Les basanites forment un système indépendant des néphélinites et sont issues de taux de fusion plus élevés. Les fortes variations dans leur composition chimique suggèrent qu’elles ont subi de la cristallisation fractionnée lors de leur ascension.Les caractéristiques particulières des néphélinites et basanites de Saghro (enrichissement en éléments incompatibles, anomalies négatives en K, Zr, Hf et Ti, rapports Ca/Al et Zr/Hf élevés) indiquent que leur source a subi un métasomatisme principalement carbonatitique. L’influence de ce métasomatisme est plus forte pour les néphélinites à pyroxène que pour les néphélinites à olivine, impliquant une évolution temporelle de l’intensité du métasomatisme. Ces résultats suggèrent des interactions fluide-roche sous le craton Nord-Ouest Africain, entraînant la formation d'un manteau métasomatisé par des composants carbonatitiques riches en CO2 au niveau de la transition lithosphère-asthénosphère. L’origine du métasomatisme provoquant l’enrichissement de la source et la formation de veines d’amphibole pourrait être liée à la fusion de reliquats de croûte océanique subductée. Les températures de fusion relativement faibles (< 1350 °C) suggèrent l’absence d’anomalie thermique sous le Jbel Saghro, et favorisent donc un modèle de délamination de la lithosphère comme initiateur du volcanisme. Cependant, l’augmentation du taux de fusion partielle au cours du temps, également observée dans le Moyen Atlas, et les similitudes isotopiques et géochimiques avec les laves alcalines des îles Canaries ne permettent pas d’exclure une influence du panache des Canaries sur la source du volcanisme alcalin du Jbel Saghro.
53752_CHAMBOREDON_2015_archivage_cor.pdf (13.16 Mo) Télécharger le fichier
tel-01615888 , version 1 (12-10-2017)
  • HAL Id : tel-01615888 , version 1
René Chamboredon. Caractérisation et origine des magmas alcalins et des fluides sous le massif volcanique du Jbel Saghro, Anti Atlas, Maroc. Sciences de la Terre. Université Montpellier, 2015. Français. ⟨NNT : 2015MONTS070⟩. ⟨tel-01615888⟩
625 Consultations
1546 Téléchargements
