Les microplastiques : une menace en rade de Brest ? - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2017
Microplastics : a threat for the bay of Brest ?
World production of plastics has increased steadily for the past decades leading to a major contamination of the worldwide aquatic ecosystems recently estimated at more than five trillion plastic pieces floating the surface of the oceans. Microplastics (plastic particles < 5 mm) are introduced into aquatic environments directly as industrial raw material (plastic pellets, cosmetics, clothing) or indirectly via the fragmentation of larger plastics. This emerging contaminant represents an increasing ecological concern for science and society. The present study focused on the microplastic contamination of the Bay of Brest (Brittany, France), a macrotidal coastal ecosystem characterized by intense anthropogenic activity. The main objectives were: (1) to evaluate the contamination of environmental matrices (surface water, subtidal sediment and biota) by microplastics, and (2) to identify their potential role as vector of chemicals and bacteria in the bay of Brest.Methodological developments were first conducted to improve microplastic extraction from environmental matrices as well as their rapid morphological and chemical identification by Raman micro-spectrometry. The field investigations showed that the ecosystem of the bay of Brest is contaminated by microplastics with mean concentrations of 0.24 ± 0.35, and 0.97 ± 2.08 (mean ± standard deviation) in surface water and sediment, respectively. Microplastic contamination in surface water and sediment was dominated by polyethylene, polypropylene and polystyrene microparticles.Spatial microplastic distribution appeared to be related to proximity to urbanized areas and to hydrodynamic in the bay. Preliminarily results of microplastic contamination in marine bivalves demonstrated relatively low contamination (0.01 ± 0.04, and 0.08 ± 0.34 for mussels and cockles, respectively) by microplastics (mainly polyethylene and polypropylene fragments), however this could be partly related to the methodological limitation identified here (e.g. exclusion of fibers). Organic pollutant (PAH, PCB and pesticides) were detected on floating microplastics at levels (not detected – 49,763 ng g-1, mean ± SD) similar to those measured in sediment and bivalves suggesting low risks in transferring hazardous chemicals in local marine organisms upon microplastic ingestion. Finally, distinct bacterial community assemblages were demonstrated on microplastics as compared with surrounding surface water; the Vibrio genus was identified as a discriminant biomarker of the plastic matrix. Overall, this work provides a first and thorough assessment of the microplastic contamination in the bay of Brest and solid methodological recommendations for further work.
Depuis plusieurs décennies la production mondiale de plastiques ne cesse d’augmenter, menant à une contamination des écosystèmes aquatiques à l’échelle de la planète qui a été récemment estimée à plus de cinq mille milliards de débris de plastiques flottants à la surface des océans. Les microplastiques (particules de plastique < 5 mm), introduits dans l’environnement aquatique directement en tant que microparticules (granulés plastiques industriels, cosmétiques, fibres textiles) ou lors de la fragmentation de plus gros débris plastiques, représentent une préoccupation scientifique et sociétale grandissante. Ces travaux de thèse se sont focalisés sur la contamination par les microplastiques de la rade de Brest (Bretagne, France), un système côtier macrotidal où l’activité anthropique est importante. Les objectifs de ces travaux sont (1) d’évaluer la contamination des matrices environnementales (eau de surface, sédiment subtidal et biote) par les microplastiques, et (2) d’identifier leur rôle potentiel en tant que vecteurs de contaminants chimiques et de bactéries dans la rade de Brest.Pour cela, des développements analytiques ont été nécessaires afin d’améliorer leur extraction des matrices environnementales ainsi que leur caractérisation morphologique et chimique via la microspectrométrie Raman. Les observations in situ ont montré que l’ensemble de l’écosystème de la rade de Brest est contaminé par les microplastiques, avec des concentrations de 0,24 ± 0,35, et 0,97 ± 2,08 (moyenne ± écart-type). L’eau de surface et le sédiment sont contaminés par le polyéthylène, le polypropylène et le polystyrène. Leur distribution à la surface de l’eau semble être liée à l’urbanisation très présente au nord de la rade, mais également à l’hydrodynamisme de cette région marine. Les premiers résultats concernant les bivalves marins ont montré un niveau relativement faible de contamination par les microplastiques (0,01 ± 0,04 et 0,08 ± 0,34 pour les moules et les coques, respectivement), cependant cela est probablement dû aux choix méthodologiques appliqués ici (exclusion des fibres). Les observations in situ ont montré que certains polluants organiques (HAP, PCB et pesticides) étaient détectés sur les microplastiques flottants à des valeurs (non détecté – 49763 ng.g-1, moyenne ± écart-type) similaires de celles retrouvées dans les sédiments et les bivalves locaux, ce qui suggère un risque faible dans le transfert des contaminants chimiques vers les organismes marins en cas d’ingestion. Enfin, les résultats concernant la colonisation bactérienne des microplastiques flottants ont montré des communautés distinctes de celles retrouvées dans l’eau de mer environnante, et l’identification du genre Vibrio en tant que biomarqueur discriminant de cette matrice. Dans l’ensemble, ces travaux fournissent une première évaluation approfondie de l’état de contamination de la rade de Brest par les microplastiques ainsi que de solides recommandations méthodologiques pour des travaux futurs.
These-2017-EDSM-Biologie_marine-FRERE_Laura.pdf (23.41 Mo) Télécharger le fichier
tel-01619349 , version 1 (19-10-2017)
  • HAL Id : tel-01619349 , version 1
Laura Frère. Les microplastiques : une menace en rade de Brest ?. Sciences de la Terre. Université de Bretagne occidentale - Brest, 2017. Français. ⟨NNT : 2017BRES0046⟩. ⟨tel-01619349⟩
2282 Consultations
5130 Téléchargements
