Modélisation du comportement des cartouches de protection respiratoire : exposition à des atmosphères complexes de vapeurs organiques et effet des cycles d’utilisation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2016
Modelling of the behaviour of respiratory cartridge filter : exposure in complex atmosphere of organic vapours and effect of reuse cycles
François Vuong
  • Fonction : Auteur
  • PersonId : 784528
  • IdRef : 204766494
Volatile organic compounds (VOC) represent a chemical risk for workers. Respiratory protective cartridges are effective equipment against vapours exposure. The objective of the present PhD thesis is the modelling of cartridge exposure in more complex situations: presence of vapours mixture and reuse cycle, from a dynamic adsorption experimental study in column bed. Further to the contribution of R. Chauveau (PhD thesis -24/11/2014), the present manuscript extends the study vapours mixtures adsorption on activated carbon. The second section is devoted to model a cycle use in 3 steps (exposure - storage – reuse), for 6 VOC: acetone, acetonitrile, 2-butanone, cyclohexane, dichloromethane and ethanol. VOC mixtures exposure and kinetic study by the method of perturbative chromatography have been carried out. The service life is correctly predicted for acetone/ethanol and cyclohexane/heptane mixtures. A deviation has been observed for ethanol/cyclohexane mixture because the adsorption equilibrium has not been accurately reproduced by model. These works have also pointed out inconsistency in the preventive approach which assimilates a mixture exposure to single vapour exposure by the most volatile compound at concentration the sum of that of all components of the mixture. Regarding the risks related to cartridge reuse, immediate breakthrough upon reuse (IBUR) has been experimentally recorded. This behaviour can be described by a static diffusion model. The mass transfer in the particle by surface diffusion is the main reason. The risk of IBUR is higher for fast diffusing VOC: acetonitrile, acetone and dichloromethane. An assessment is suggested in order to distinguish the properties of the system which can influence the occurrence of IBUR
Les vapeurs de composés organiques volatils (COV) représentent un risque chimique pour les travailleurs. Les cartouches de protection respiratoires sont un moyen efficace contre les expositions à ces vapeurs. L’objectif de cette thèse est la modélisation de l’exposition des cartouches dans les situations complexes : présence d'un mélange de vapeurs et cycle d’utilisation, à partir d’une étude expérimentale basée sur l’adsorption dynamique sur colonne. Suite à la contribution de R. Chauveau (thèse UL – 24/11/2014) la présente thèse poursuit l’étude sur la modélisation de l’adsorption des mélanges de vapeurs. Des expositions à des mélanges de COV et une étude cinétique par la méthode chromatographique perturbative ont été effectuées. Le deuxième volet est consacré à la modélisation d’un cycle d’utilisation en 3 étapes (exposition - stockage – réutilisation), pour 6 COV : acétone, acétonitrile, 2-butanone, cyclohexane, dichlorométhane et éthanol. Les temps de claquage ont pu être prédits correctement pour les mélanges acétone/éthanol et cyclohexane/heptane. Une déviation est observée pour le mélange éthanol/cyclohexane car l’équilibre d’adsorption n’a pu être reproduit avec précision par les modèles et parce que la présence d’une covapeur influe grandement sur les cinétiques d’adsorption en mélange. Les travaux ont révélé des failles dans l’approche préventive consistant à assimiler une exposition de mélanges à une exposition à celle du composé le plus volatil en lui affectant la concentration totale du mélange. En ce qui concerne les risques liés à une réutilisation des cartouches, des percées immédiatement après réutilisation (IBUR) ont été observées expérimentalement. Ce comportement a pu être décrit par un modèle de diffusion statique. Le risque d’IBUR est élevé pour les COV diffusant rapidement : l’acétonitrile, l’acétone et le dichlorométhane. Une évaluation est proposée pour distinguer les propriétés du système qui influencent l’apparition de l’IBUR
DDOC_T_2016_0255_VUONG.pdf (5.8 Mo) Télécharger le fichier
tel-01619367 , version 1 (19-10-2017)
  • HAL Id : tel-01619367 , version 1
François Vuong. Modélisation du comportement des cartouches de protection respiratoire : exposition à des atmosphères complexes de vapeurs organiques et effet des cycles d’utilisation. Génie des procédés. Université de Lorraine, 2016. Français. ⟨NNT : 2016LORR0255⟩. ⟨tel-01619367⟩
203 Consultations
765 Téléchargements
