Study under simulated condition of the secondary organic aerosol from the photooxydation of n-dodecane : Impact of the physical-chemical processes
Etude en atmosphère simulée de la formation d'Aérosol Organique Secondaire issue de la photooxydation du n-dodécane : impact des paramètres environnementaux
Secondary Organic Aerosol (SOA), the major fraction of the submicron aerosol, plays a key role on health, environment and climate. The evaluation of its impacts is a real challenge for the scientific community. Our current knowledge of SOA formation processes and chemical composition is still very deficient and limit the development of atmospheric models to quantify the impacts of SOA on air quality and climate system. Therefore, the aim of this work is to produce a set of experimental data to use to constrain and improve the models. To do that, the SOA formation has been studied from the photooxidation of a model precursor, n-dodecane, in the CESAM environmental chamber. The chemical composition has been investigated by spectrometric and chromatographic techniques which allowed us to identify the reaction products constituting the gaseous and particulate phases. In particular, new condensed phase mechanisms have been proposed to explain the formation of carboxylic acids and lactones, identified for the first time. These could be implemented in the models. A wide variety of environmental conditions, such as temperature, relative humidity and the presence/absence of preexisting particles, have been taken into account in this work. The study of the temperature influence has shown a low sensitivity of this parameter on the SOA production. While the study relative humidity effect has shown that adding water to the reaction system beyond 5% lowers SOA yields by almost a factor of 2 in comparison to dry conditions. The SOA formation potential, under these conditions, has been evaluated, and resulted in parameterizations which could be useful for modelers. Furthermore, a characterization of the wall effects in CESAM, i.e. gas and particulate phase wall losses, has been carried out
L’aérosol organique secondaire (AOS), fraction majoritaire de l’aérosol submicronique, joue un rôle important sur la santé, l’environnement et le climat. L’évaluation de son impact constitue un véritable enjeu pour la communauté scientifique. Toutefois, nos connaissances actuelles sur les processus de formation d’AOS et sa composition chimique sont encore très lacunaires, et en l’occurrence, limitent le développement des modèles atmosphériques permettant de quantifier les impacts des AOS sur la qualité de l’air et le système climatique. Ainsi, l’objectif de ce travail est de produire un ensemble de données expérimentales fournissant des points de contrainte afin d’évaluer et d’améliorer les modèles. Pour ce faire, la formation d’AOS a été étudiée à partir de la photooxydation d’un précurseur modèle, le n-dodécane, dans la chambre de simulation atmosphérique CESAM. La composition chimique a été élucidée par des techniques spectrométriques et chromatographiques permettant d’identifier les différentes espèces constituant la phase gazeuse et particulaire. En particulier, de nouveaux mécanismes en phase condensée ont été proposés afin d’expliquer la formation des acides carboxyliques et des lactones, identifiés pour la première fois dans l’AOS d’un alcane. Ces derniers pourront être implémentés dans les modèles. Une grande diversité de conditions environnementales, telles que la température, l’humidité relative et la présence/absence de particules préexistantes, a été prise en compte dans ces travaux. Notamment, l’étude de l’influence de la température a mis en évidence une faible sensibilité de ce paramètre sur les rendements de production d’AOS. Tandis que l’étude sur l’effet de l’humidité relative, elle, a montré que l’ajout d’eau dans le système réactionnel au-delà de 5% abaisse les rendements d’AOS de près d’un facteur 2 en comparaison à des conditions sèches. Ainsi, la formation potentielle d’AOS sous ces différentes conditions a permis d’aboutir à des paramétrisations directement utilisables par les modélisateurs. Une caractérisation des effets de paroi dans CESAM, i.e. les pertes en phase gazeuse et particulaire, a également été menée
