Study of ZnO nanostructure for environment application : gas sensing and water purification
Étude des nanostructures de ZnO pour leur application dans l'environnement : détection de gaz et dépollution de l'eau
Zinc oxide (ZnO) is a remarkable and very promising wide-gap II-VI semiconductor in the development of new materials for renewable energy and for the environment. Thanks to its many interesting physical, chemical and optoelectronic properties, this multifunctional material is used in many application fields such as solar cells, light emitting diodes, gas sensors, and water & air purification by photocatalytic effect, etc.In this thesis, we were interested in optimizing the synthesis of ZnO nanowires (ZnO NWs) by hydrothermal method. A two-step process has been optimized allowing us to obtain ZnO NWs having excellent morphological and structural properties, with very good reproducibility. A new synthesis method “Electrospinning” has been developed and the micro- & nanofibers containing ZnO nanocristallites can be obtained by this process. The combination of the two synthesis methods results a hierarchical nanostructure of ZnO (NWs/NFs) with an effective surface much larger than the classical one (ZnO NWs).Two applications have been developed in this thesis. Firstly, three reducing gases sensing tests have been carried out on the two types of ZnO nanostructures. Then, a photocatalytic water purification study has been carried out on a ZnO nanowire array under UV irradiation for the three dyes (MB, MO and AR14). In order to improve the photocatalysis performance, two new methods have been developed. The first is to set up a microfluidic system using microreactors containing ZnO NWs as a photocatalyst, thus the depollution time has been considerably shortened. The second method is based on the ZnO doping in order to improve the photocatalysis efficiency
L’oxyde de zinc (ZnO) est un semi-conducteur II-VI remarquable et très prometteur dans le développement des nouveaux matériaux pour l’énergie renouvelable et pour l’environnement. ZnO est l’un des rares matériaux multifonctionnels. Grâce à ses nombreuses propriétés physiques, chimiques et optoélectroniques très intéressantes, lui confèrent d’être un matériau utilisé dans différents domaines d’applications telles que les cellules solaires, les diodes électroluminescentes, les capteurs de gaz, la dépollution de l’eau et de l’air par effet photocatalytique, etc.Dans cette thèse, nous nous sommes intéressés tout d’abords à optimiser l’élaboration de nanofils de ZnO (ZnO NWs) par méthode hydrothermale. Un procédé à deux étapes a été optimisé qui nous a permis d’obtenir des nanofils de ZnO ayant des excellentes propriétés morphologiques et structurales, avec une très bonne reproductibilité. Une nouvelle méthode d’élaboration, dite Electrospinning, a été mise au point. Ce procédé nous permet d’obtenir des micro- et nanofibres contenant des nanocristallites de ZnO. La combinaison des deux méthodes de synthèse nous a permis d’obtenir des nanostructures hiérarchiques de ZnO (NWs/NFs) possédant une surface effective beaucoup plus importante que la nanostructure classique (ZnO NWs).Deux applications ont été développées dans cette thèse. Dans un premier temps, des tests de détection de trois gaz réducteurs ont été réalisés sur les deux types de nanostructures de ZnO. Par la suite, une étude de purification de l’eau par effet photocatalytique a été réalisée sur un réseau de nanofils de ZnO sous irradiation UV pour les trois colorants (MB, MO et AR14). Afin d'améliorer la performance de la photocatalyse, deux nouvelles méthodes ont été développées. La première consiste à mettre en place un système microfluidique en utilisant des microréacteurs contenant des nanofils de ZnO comme photocatalyseur permettant ainsi à raccourcir considérablement le temps de dépollution. La seconde méthode est basée sur un procédé de dopage de ZnO permettant ainsi d’améliorer l'efficacité de la photocatalyse
